Resolution !!! Thanks for your help !!!
Iam using pi 3+ and Hassio version: 0.73.1 64 bit OS
Iam tring to start the wifi without success. I did the following configuration.
Etcher flasher from windows.
Using windows OS
- I using notepad++ I set the encoding to ANSI and set the line eding to UNIX. Also checked in hexa the file content the line ends with 0A hexa.
- format an USB stick and label it as “CONFIG” (that’s what I didn’t do in the first place, but that’s crucial).
3 Create a folder “network” on the USB stick and place your resin file in this folder. - Createing file hassos-wifi (with no extension)
- Adding the following data:
[connection]
id=my-network
uuid=72111c67-4a5d-4d5c-925e-f8ee26efb3c3
type=802-11-wireless
[wifi]
mode=infrastructure
ssid=Roby
[wifi-security]
auth-alg=open
key-mgmt=wpa-psk
psk=my_pw
[ipv4]
method=manual
address1=192.168.1.190/24,192.168.1.1
dns=8.8.8.8;8.8.4.4;
6 Put USB stick in RPI and reboot.
7 At that point, the file gets added to the RPI config and you can remove the USB stick.
