I’m trying to configure Alexa with Hasska. I’ve followed all the instructions from a youtube video, and checked with the (not completed yet) documentation.
When I try from the lambda page, the function is successfully executed, and all the devices are returned, however, when I turn on the skill and link it to my Amazon account, the discovery is run, but no device is returned, and I don’t know why…
Did someone use hasska (mike-grant version, compatible with version 3) and knows why this may happen?
Hass version: 0.82.1 running in docker
SSL cert with letsencrypt
Dynamic DNS with Synology DNS
Can I enable any kind of logging that helps me figure out what’s going on?
Edit: I can see this in logs when I execute the test in lambda, but no when I ask alexa to look for new devices…
2018-12-16 02:41:44 DEBUG (MainThread) [ homeassistant.components.api ] STREAM 140248668589712 FORWARDING <Event alexa_smart_home[L]: request=namespace=Alexa.Discovery, name=Discover, response=namespace=Alexa.Discovery, name=Discover.Response>
I’ve checked the thread (the issue is different, for me everything seems to be working, but I don’t get the devices found) and the guide, and everything seems OK… but it still doesn’t work.
