HassOS 3 released! Raspberry Pi 4 support
That diagram is a good start, but it doesn’t properly show the role of docker, in my opinion (only being shown at the bottom, when in reality HA, the supervisor, and the addons all run under docker).
Why not.
If the ability is already installed into every version of HA there ought to be someway to access the hassio functionality since I already also have a functioning supervisor.
Even granting that the code base might be the same if the end result is different then again isn’t the distinction between the two important?
Just because Windows professional version is packaged along with all Windows install files you can’t say that Windows Home is the same version as Windows Pro.
Agree, but regardless of docker, it is the supervisor container that controls them and their interaction HA and the add-ons are just other containers. The ha container is the same one used here as the one I use for a plain docker install of HA.
It’s part of supervisor. Your supervisor isn’t linked to the HA container.
ex4
What’s missing here and how do I get it there?
I figure since we are just posting diagrams I might as well join in… :wink:
My pet issue of showing it all inside docker…
I have a working supervisor. How do I point it to my existing HA in docker?
and since they aren’t linked then how does HA know to look for a supervisor container to know when to add the hassio functionality or not.
I know that if I delete the hassio container and not disable the supervisor container it will immediately create a new hassio container even tho the other HA container is in the same docker instance and functioning. So the supervisor can’t just be looking for HA in general but a specific “version” (for lack of a better term now).
If nothing else this is at least helping my understanding and it might just help some new person that is helplessly lost.
I’ll admit not knowing that the hassio & non-hassio images were the same so I concede that point.
If the people “in the know” can’t (or won’t…) explain this to someone who has been using HA for over 2 years now then how is a new person going to be expected to understand any of the differences and nuance that is involved?
It isn’t ever conveyed in this way that I’ve seen https://www.docker.com/resources/what-container
It’s right on their home page.
Home assistant, all the addons, and the supervisor are all “App[s]” in the sense of the above image.
Perhaps enclosing them all in a “cloud” for docker (as I did) isn’t the most standardized representation, however the image before I modified it implied that only the supervisor communicated with docker, not that HA, the addons, and the supervisor were all running inside docker.
Again, this is just my opinion. We all seems to see and conceptualize things differently. I’m trying to keep in mind what the average “noob” user will understand best; but I’m not him so I can’t really say for sure what’s best.
How about “Hassio on Debian, Ubuntu, etc.” and “Hassio on HassOS” (or just HassOS since “Hassio on HassOS” is in itself redundant)?
“Hassio in Docker” is redundant and not any clearer than just saying Hassio since (as you said) the Hassio install method utilizes Docker regardless of the host OS that it’s installed on (again, Debian, Ubuntu, HassOS, etc.)
Saying “Hassio in Docker” implies there is a method of running Hassio that doesn’t involve Docker, but there isn’t.
This whole thing kind of reminds me of saying ATM Machine instead of just ATM or PIN Number instead of just PIN lol
Wonderful way of phrasing it.
But the front page, and all documentation regarding installation just refers to it as Hassio.
When NewBie123 installs hassio, and has any issues, they come to the forums and just say “I installed hassio and I have issue X”.
Depending on the issue, we might need to know HOW hassio was installed. Sometimes they go on to say “I just installed hassio like the website told me”.
Only the website explains every method of installation even if it doesn’t explain the differences in detail.
So now we’re back to “How did you install it?”.
It’s a vicious cycle. So much repitition around here…
Yes, so it’s just back to improving the documentation on the primary documentation pages to better represent the differences between Home-Assistant, HassIO, and HassOS.
This is something I think we all agree on.
This can all be a PR submitted before 2020.
That’s a fair point, but I suppose the next question could be “are you running Raspbian/Debian/Ubuntu + Hassio or did you just flash the image on an SD card/SSD?” The answer to that question should get you what you need.
I’d also imagine anyone running Raspbian/Debian/Ubuntu + Hassio probably knows that’s an important detail to mention (but… that is merely an assumption after all).
Just like it’s also an assumption that everyone is running their install on a RPi, which is where we get back to that vicious cycle of questions that we see SO MANY new threads about :rofl:
I actually don’t mind that idea however it’s incomplete no?
Hassio on/in Docker on Debian… Whereas HassOS it’s clear. The actual hardware isn’t important - HassOS is the same regardless of how it’s installed. It’s only hassio that raises questions for more info.
Also very true lol
Yes indeed. Sometimes you might have to distinguish between hassos on rpi, hassos on nuc, hassos on tinkerboard, hassos on rpi4 etc as there are many hassos image builds Installation - Home Assistant
21 posts were split to a new topic: Hassio containers? / How do version numbers work?
