Quick heads-up before we start: this is a pure hobby project. I can’t code, and my YAML/HA knowledge was pretty modest until recently. The whole thing came together with Claude (an AI by Anthropic), who I bugged relentlessly for weeks with “why doesn’t this work,” “can you do that differently,” and “no, that’s not what I meant.” Without that patience, this idea would never have become a finished tool.
The nudge to just try it came from simon42 – thanks for the tip to just start building something with an AI instead of overthinking it first. Turned out to work.
And a big extra thank-you to ISI, who spent countless late nights testing and caught a ton of bugs before they could ever reach you. ![]()
HATG — Home Assistant Theme Generator
One theme, every card under control.
HATG is a dedicated panel in your Home Assistant sidebar for building complete themes visually — for Home Assistant itself, for Bubble Card, for Mushroom and for global tweaks via card-mod. No jumping between YAML files, no guessing which variable hits which card: you set colours, shapes and states in one place, HATG distributes them across all three worlds and shows you the result live — optionally right inside your real dashboard.
Every one of the 515 fields was verified against the actual source code of Home Assistant, Bubble Card and Mushroom. Only variables that genuinely exist are included — what you set is what arrives.
Contents: Installation · Your first theme in five minutes · The start page · All sections · Card-mod presets · HA Live · Saving & importing · Good to know · FAQ
Installation
Via HACS (recommended)
Open HACS → three-dot menu, top right → Custom repositories
Enter the URL:
https://github.com/Piranha1605/ha-theme-generator— category Integration -
Search for HATG in HACS and download it
Restart Home Assistant
Settings → Devices & Services → Add integration → search for “HATG”
HATG then appears as its own entry in the sidebar. That’s it — no further configuration needed.
Manual
Copy the folder
custom_components/hatg/from the repository toconfig/custom_components/hatg/ -
Settings → Devices & Services → Add integration → “HATG”
Optional but recommended: card-mod
The Card-mod presets page and the card-mod-card / card-mod-root fields only take effect with card-mod installed (also available through HACS). HATG works fully without card-mod — those building blocks simply stay silent.
Tip for advanced users: to make card-mod styles apply outside dashboards too (in the sidebar on settings pages, for instance), register card-mod as a frontend module as well. The exact resource URL is listed under Settings → Dashboards → ⋮ → Resources:
frontend:
extra_module_url:
- /hacsfiles/lovelace-card-mod/card-mod.js?hacstag=YOUR_NUMBER
Restart Home Assistant afterwards, and update the number after every card-mod update.
Open HATG and give your theme a name on the start page
Choose light or dark — every control always writes to the currently active mode; the ⇄ button copies a setting into the other one
Set the base colours: primary, accent, background, card and text colour. Hundreds of derived fields follow automatically
In the Basis block, define border colour, corner radius (outer and inner separately) and shadow
Under States, pick the colours for on, off and unavailable — they are distributed to Home Assistant, Bubble Card and Mushroom at once
Optionally choose a background: a gradient or your own image from the gallery, with an opacity slider
Save at the top right → the theme is written to
config/themes/and Home Assistant reloads it automatically -
Select the new theme under Settings → Profile
The start page — from broad to fine
The start page is built as a guided entry point: the few values that shape a theme at the top, and below them the blocks that turn those into a complete design.
Base colours
Five colours and one radius — that’s all the beginning needs. Every colour field offers a hex/RGB/RGBA switch, a native colour wheel and a text field for the raw value. Small rows of dots beside them show which derived fields will follow along.
Basis: border, radius, shadow
Three rows define the basic shape of all cards and pass it on to Bubble Card (including every card type) and Mushroom:
| Row | Fields | Special behaviour |
| Border colour | 5 | also rebuilds the composite bubble-border |
| Radius | 26 | separate inputs for outer and inner — nested elements such as icons and sub-buttons automatically get 4 px less, keeping the roundings concentric |
| Shadow | 13 | one value for all card shadows, sub-buttons included |
States: on / off / unavailable / icon background
Four rows, each with identical controls — and each distributing its value across all three worlds:
State on — 51 fields. Covers Home Assistant’s complete resolution chain (
state-<domain>-<state>down tostate-active-color), plus the Bubble active colours and the Mushroom state fields. Fields expecting RGB triplets are converted automatically -
State off — 15 fields for the idle state
State unavailable — 2 fields (Bubble and Mushroom offer no dedicated variables for this state)
Icon background — 7 fields for the icon chips of Bubble and Mushroom
Each row has three tools:
Chain icon — decouples Bubble and Mushroom when they should deliberately keep their own colours
Refresh button — rewrites the value onto all fields in the row and reports the count (“State on: 51 fields updated”). Useful when individual fields revert to their base colour after an import
⇄ button — transfers the row into the other mode (light ↔ dark)
Semantic colours — weather, alarm, battery, lock, climate modes — are deliberately left untouched: there the colour carries meaning and should not follow the accent colour.
Background with image gallery
Besides gradients (sunrise, night sky, radial) you can set your own image. The gallery shows every image already uploaded to config/themes/Wallpaper/ as a clickable preview — upload once, reuse in every theme. Identical duplicates are detected by checksum, flagged and removable in one click. The opacity slider lays a colour veil over the image — from full strength down to “background colour only”, live in the preview.
All sections at a glance
The sidebar organises all 515 fields into thematic sections — Bubble Card with its own subpage per card type:
| Section | Contents |
| Base colours & text | Colour palette, state colours, fonts & typography |
| HA framework | Cards, header, sidebar, input fields, switches, sliders, dialogs |
| Bubble Card | Cards & backgrounds, select, buttons, sub-buttons, separator, popup & dialog, horizontal buttons stack, climate, cover, media player, calendar |
| Mushroom | Cards, icons, chips, sliders, toggles, state colours |
| All fields | The complete list with full-text search, colour, type and word-fragment filters plus multi-select for bulk changes |
| Code editor | Every value as text — type instead of click, changes apply instantly |
| Card-mod presets | Global card-mod building blocks in one click, plus your own presets |
| Plugins | Copy-and-paste snippets for individual cards (Bubble slider, glass effects, state-dependent design) |
All fields — finding instead of searching
The word-fragment filter combines building blocks such as color, background or button with narrowing tags (bubble, climate, stack) — so even among 515 variables the right one is found in seconds. With multi-select, entire groups of fields get the same value in a single step.
Code editor
For everyone who prefers typing: all fields as text with syntax highlighting, grouped by section. Plus the free-form card-mod fields (card-mod-card, card-mod-root) and a free field for your own theme entries that HATG doesn’t know — they survive saving and export unchanged.
Card-mod presets — global effects in one click
Ready-made card-mod building blocks applied globally to the theme with a single click — marked inside card-mod-card, for light and dark simultaneously, individually removable at any time. No copying, no pasting into individual cards.
Five built-in presets are included: card colour gradient, glow shadow, border with glowing edge, glass effect (blur) and relief. All of them cover native HA cards and every Bubble card type (climate, cover, media player, select, calendar, popup, horizontal buttons stack); Mushroom is already served through the theme variables. Wrapper cards such as headings, Mushroom chips and Bubble sub-buttons deliberately stay frameless.
Your own presets: via “New preset” you can create your own CSS blocks — with a name, a description and bracket validation on save. They are stored in config/themes/hatg-cardmod-vorlagen.json, so they survive theme and browser changes and are part of your backup. Activating, combining and the automatic refresh detection all work just like the built-in ones.
Refresh instead of going stale: the preset CSS lives in your theme file, not in the panel. When a HATG update ships newer versions, a notice bar appears — one click on “Refresh” brings all active blocks up to date. Hand-written CSS is left untouched.
Plugins — building blocks for individual cards
Some effects don’t belong in the theme globally but on exactly one card: slider shapes, glass variants, state-dependent card design (traffic-light effect), sub-button glow states. The plugins page provides them as copy-and-paste snippets with a preview image and an explanation — several can be selected and copied as one combined snippet.
HA Live — your real dashboard as a preview
The built-in demo preview reacts instantly to every change — with pixel-accurate recreations of real HA cards, every component verified against the original frontend source. When that isn’t enough: HA Live shows your actual Home Assistant dashboard right inside the panel — not a mockup but the real interface, in a phone, tablet or desktop frame. “Save draft” reloads the themes automatically, and one click on “Refresh” reveals the new colours.
[IMAGE 12]
Saving, loading, importing
Save writes the theme as a YAML file to
config/themes/and triggersfrontend.reload_themes— the result is immediately selectable under Settings → Profile -
Save draft creates a working copy; your progress survives leaving the panel
Open lists every theme in
config/themes/for direct editing -
Import reads any existing theme — including flat themes without a
light:/dark:split. Unknown fields are preserved and re-attached on export, and old card-mod field names are migrated automatically -
Reapply derivations (in the save menu) resets fields whose value already matches the derivation back to “automatic” — they then follow their base colour again
The export is valid YAML (verified with the same parser Home Assistant uses), with card-mod fields correctly placed at the flat level.
Good to know
Light and dark are separate worlds. Every control writes only to the currently active mode. Adjusting in light and then checking in dark shows no change — the ⇄ button transfers deliberately into the other mode
Badges show the origin of each value: automatic = follows a derivation, custom = set by you
Undo: the undo button (or Ctrl/Cmd+Z) reverts the last change — including bulk changes as a whole
Validation before export checks every value against its expected format and flags outliers before they end up in the theme
After a HATG update, do one hard reload (Ctrl/Cmd+Shift+R) so the browser picks up the new panel version
FAQ
Do I need Bubble Card or Mushroom?
No. HATG produces fully valid Home Assistant themes. The Bubble and Mushroom fields simply lie dormant until those cards are installed — they don’t interfere.
Does HATG work with my existing theme?
Yes. HATG reads any theme via import. Unknown fields aren’t lost; they’re re-attached on export.
Why does nothing change on my dashboard even though I saved?
The three most common reasons: (1) a different theme is active under Settings → Profile. (2) You edited the other mode (light/dark) than the one your device uses. (3) The browser is holding an old version in cache — do one hard reload.
What happens to my themes during a HATG update?
Nothing — themes live in config/themes/, custom card-mod presets in config/themes/hatg-cardmod-vorlagen.json, background images in config/themes/Wallpaper/. All outside the integration folder, all update-safe, all covered by your backup.
The card-mod presets have no effect.
card-mod needs to be installed for that. The active theme also has to be the one saved by HATG — the CSS lives in the theme file.
Can I remove HATG again?
Any time. The generated themes are ordinary YAML files and keep working without HATG.
Support
HATG is built in spare time. If it saves you time or makes your dashboard nicer:
Found a bug or have a wish? → GitHub issues: Issues · Piranha1605/ha-theme-generator · GitHub
Repository: GitHub - Piranha1605/ha-theme-generator: Home Assistant Theme Generator with HACS support · GitHub
