I want to install a heatpump system air-air. Mostly for climate cooling in the summer though, but i would like to have a system that can do both.
But, running such a system can be costly in electricity, so i want to integrate it with my Home Assistant, that has sensors for my solar system, that has solar cells, battery pack and inverter.
Also i have a Netatmo system that measures temperature.
Basically i want to set up som If This Then That rules and control the Heatpump this way.
For example…If the battery is atleast 80% full, AND the solar cells produce X kwh more than the house is using, AND the temperature in the house is above 25C.
In that case i want to be able to start the heatpump in cooling mode, and have it run until the temperature gets to, for example 24C
So i have sensors for temperature, battery state, temperature and so on, so all i need is a heatpump with integration so that i can control it via Home Assistant.
Prefereably one where i have a switch / sensor for every option the heatpump has. (I might want to have it do humidity control as well).
Anyone has a tip on what i will need to make this happen…Is there any products that have official support for HA and if not, is what is my best bet…If any, to make this happen ?
