Hello dear community, I’m really hopeful someone can help save my config…
I’m running HA in a VirtualBox VM on an old Mac Mini. Everything’s been working smoothly until last week when I (foolishly) clicked ‘Update’ in the UI and walked away. I returned to the room some minutes later and the entire MacOS had rebooted! After logging into MacOS I saw the dreaded prompt “Your computer restarted because of a problem…” . This made me immediately think "Oh, **** ", and sure enough, HA hasn’t been accessible since.
The VM boots up and looks normal, I get the big banner and no obvious errors along the way, but the UI both via browser and mobile app do not load.
In the VM I see:
OS Version: Home Assistant OS 9.4
Home Assistant Core: 2023.2.4
I started with the most basic troubleshooting step of a graceful reboot of both the VM and the MacOS host. No change. I tried running some basic CLI commands in the HA, telling it to look for updates, to inspect its config, and no luck.
If I list the backups I see the ‘partial’ backup the system made before the failed update, but I cannot to restore that. I get an immediate response ‘Processing… Done. Error: Unknown error, see supervisor’, and if I use ‘supervisor logs’ I see the last entry that says ‘ERROR (MainThread) [supervisor.backups.manager] us is only a partial backup!’ . Unfortunately I don’t know how to view the logs completely, only the glimpse that I can see on the screen.
I do have a backup listed from 2021 as ‘full’, but I’m nervous to restore that and loose a lot of my config I’ve made since then.
This is where I’m stuck. I’ve done a bunch of Googling and unfortunately the few leads that I find are beyond my technical ability. Can anybody provide a real “hand holding” response with some ideas? In the end, I think I’m technical enough to get myself into trouble, but not get out again
My only goal is really to save my config (integrations, automations, dashboards, etc.) by any means. I would gladly create a new installation (spin up a new VM?) if I could copy out those files from the old one…I just don’t know how
Thank you all in advance for any ideas!!
