I have gotten so far as to where I can launch HASS and connect to its web interface but it seems to have issues installing any dependencies, thus Discovery is not working, and I edited my config file to enable Wemo and it gives me the same errors.
Here is the log generated from the web interface:
2017-09-05 11:58:51 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds. 2017-09-05 11:58:52 ERROR (Thread-7) [homeassistant.util.package] Unable to install package netdisco==1.1.0: Command "/srv/homeassistant/bin/python3.5 -u -c "import setuptools, tokenize;__file__='/var/tmp/pip-build-um_ffcjo/netifaces/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /var/tmp/pip-c6t5tqzy-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.5/netifaces" failed with error code 1 in /var/tmp/pip-build-um_ffcjo/netifaces/ 2017-09-05 11:58:52 ERROR (MainThread) [homeassistant.setup] Not initializing discovery because could not install dependency netdisco==1.1.0 2017-09-05 11:58:52 ERROR (MainThread) [homeassistant.setup] Setup failed for discovery: Could not install all requirements. 2017-09-05 11:59:02 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds. 2017-09-05 11:59:02 ERROR (Thread-18) [homeassistant.util.package] Unable to install package pywemo==0.4.19: Command "/srv/homeassistant/bin/python3.5 -u -c "import setuptools, tokenize;__file__='/var/tmp/pip-build-3hgnhnyl/netifaces/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /var/tmp/pip-ouq17ui8-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.5/netifaces" failed with error code 1 in /var/tmp/pip-build-3hgnhnyl/netifaces/ 2017-09-05 11:59:02 ERROR (MainThread) [homeassistant.setup] Not initializing wemo because could not install dependency pywemo==0.4.19 2017-09-05 11:59:02 ERROR (MainThread) [homeassistant.setup] Setup failed for wemo: Could not install all requirements.
I am unsure where the error falls, I imagine its permissions/dependencies along with the fact I am working in a virutalenv
I am not too bad with Linux/FreeBSD and have done a lot of manual jail setup via SSH but this is my first endeavor into using python and virtualenv’s as well as creating new users/groups within those environments.
I have tried to add root to the homeassistant group and homeassistant to the wheel group and other such things to see if it was permissions based, no luck so far.
create location for VM storage on HOSTt; i.e. /srv/raid/docker/homeassistant/config
after install docker on HOST, create the docker VM docker create --restart=always -p 8123:8123 -v /srv/raid/docker/homeassistant/config:/config --name=hass_Version# homeassistant/homeassistant:Version#
3.start the Docker VM from command line or if there is GUI use that.
-p 8123:8123
this means HOST Port 8123 will be used for VM port 8123
you need only define ports for incoming connections…outgoing traffic just works
-v is similar to port telling that Host folder /srv…/config will be VM folder /config
this is persistent data that you want saved. Anything not defined is basically wiped at Container Restart
That is basically it.
Define incoming ports
Define storage
RUN
zwave and all other components are included. Just need to add into config.yaml
upgrade is as easy as “docker stop hass_version” and run above commands with new version numbers. Delete old container or keep it in case of errors after upgrade.
Just one thing to add is to also delete the old images.
HA images are 1+ Gb.
You can install portainer which is a very easy lightweight docker web UI.
Easily allows to delete stopped containers and old images:
docker run -d -p 9000:9000 -v /var/run/docker.sock:/var/run/docker.sock portainer/portainer
Freenas 10 had native docker, freenas 11 currently does not. People that use them/like them are building linux vm’s and then doing docker inside of that.
I hate adding extra layers of complexity but being that the jail is not working for me, I will look into it.
If I am already going to do a Linux VM I may as well just sort of do the native linux install of HASS IMO, but if there are any solid reasons to also add the docker layer inside the VM I would be willing to entertain it.
I’m running freenas (9.x) in a VM on ESXi, so I have the option to create other VMs in parallel.
I held off from updating to freenas 11 due to the debacle with v10/coral.
Do you think it’s currently worth upgrading from 9.x to 10?
No, 10 is considered a failure 11 is what you would/should upgrade too if you have any reason to do so.
If 9x is working fine and doing all you need you have no real reason to upgrade.
It was a typo in my post. I meant 9 to 11
Yeah v10 really was a massive failure. I wonder how many people deserted (or were put off adopting) the platform after that?
I think I will hold off upgrade until 11.1 when the docker and UI overhaul comes.
I love my FreeNAS jails.
One thing is if you migrated to 11 and created a new jail using IOCAGE - I’ve found they often don’t create a working resolv.conf file in the jail for some reason.
In the jail in question
ee /etc/resolv.conf
And for a generic google dns lookup,
nameserver 8.8.8.8
nameserver 8.8.4.4
Press ESCAPE then enter to end, enter to save, and that’s all, you don’t even have to reboot.
