Extremely new to HA and im realizing just how deep this pool I just jumped in is…
So I am attempting to setup my new Heiman HS2WD-E zigbee siren with my new installation of zigbee2mqtt. I have been following the instructions laid out in:
At one point in the article the author mentions to create 3 entities for Alarmo to reference. 2 for basic ON/OFF function and 1 to act as a toggle on the dashboard.
I am attempting to create a script using the YAML editor and inputting
#Turn ON the Heiman Siren Alarm
alias: Heiman Siren Turn On
sequence:
- service: mqtt.publish
topic: 'zigbee2mqtt/Main level alarm siren/set'
payload: '{"warning": {"mode": burglar, "level": very_high, "strobe_level": high, "strobe": true, "strobe_duty_cycle": 10, "duration": 1800}}'
mode: single
icon: mdi:alarm-light-off
unfortunately When I try to save this script I get a error of “unable to determine action @ data[‘sequence’][0]”
Could someone please point out what is causing this error and where I can go to read up more about how to trouble shoot it on my own in the future? Like I said, still really new and trying to learn as best as I can, but I feel a bit in over my head to start with.
Your siren doesn’t expose entities for those values? My Zigbee siren exposes all its parameters as entities, I just have scripts that set them to the values I want then turn it on. No MQTT required.
No as far as I can tell they don’t seem to expose any entities… I can go into zigbee2mqtt and push a command that turns them on, but I can’t seem to find any other entities populated by the system. I was surprised by this, but again, can’t seem to find any real documentation supporting how it really should be…
THANK YOU! You solved a error that I didnt know I had. good lord it would have taken me forever to learn that. Turns out my issue was that I was going a bit too far through the script wizard before switching it to YAML… I feel like im gonna be learning for years to try and figure this out. Should probably start learning python beyond the extreme basics.
One last question, I am hoping to use this scrip to fire the same package to multiple sirens. My thinking is to copy the entire block between Sequence and Mode. Like this:
