I’ve created a sub-flow to identify then group together Sonos speakers that are active on the network. Once they’ve been identified and grouped, a loop is used to set the volume on each using a message passed to the loop from the calling flow. As written, the sub-flow is working.
I’m flummoxed by one thing though! I can’t figure out why when trying to use ‘payload’ in the msg field of the ‘array-loop node’ (Loop Through List) an error occurs (This flow contains some nodes that are not configured properly) and I’m unable to Deploy the sub-flow. To make the node function, a message named ‘msg.loop_through’ (msg.loop_through = msg.payload) is created in the function node named “Set Master and Group Members”. This message is, from what I can see, identical to msg.payload. Here’s the catch! When ‘loop_through’ is used in the msg field of the ‘array-loop node’, the sub-flow continues, exiting back to the calling flow.
I’d like to eliminate the loop_through message and use the payload msg instead. Why am I unable to use that message in the msg field of the ‘array-loop node’ ?
Here’s a couple of screen shots and the sub-flow that’s working.
[{"id":"4ed4def360353223","type":"subflow","name":"Ungroup Sonos Speakers","info":"","category":"","in":[{"x":100,"y":140,"wires":[{"id":"677f323de579408b"}]}],"out":[{"x":680,"y":140,"wires":[{"id":"f03f45a21b75fd46","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"a3c3ed4e88946a44","type":"comment","z":"4ed4def360353223","name":"Ungroup Sonos Speakers","info":"","x":170,"y":80,"wires":[]},{"id":"677f323de579408b","type":"ha-get-entities","z":"4ed4def360353223","name":"ID Sonos Speakers","server":"fcf9b76b.256a88","version":0,"rules":[{"property":"entity_id","logic":"is","value":"(?<=media_player)(.*)(?=_sonos$)","valueType":"re"}],"output_type":"array","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":250,"y":140,"wires":[["f03f45a21b75fd46"]],"info":"The name of all Sonos speakers installed in the house ends with _sonos. Use a filter to identify and build an array of all active speakes."},{"id":"f03f45a21b75fd46","type":"api-call-service","z":"4ed4def360353223","name":"Unjoin Sonos Speakers","server":"fcf9b76b.256a88","version":5,"debugenabled":false,"domain":"media_player","service":"unjoin","areaId":[],"deviceId":[],"entityId":[],"data":"{\"entity_id\": $join(payload.entity_id,\",\")}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":510,"y":140,"wires":[[]]},{"id":"fcf9b76b.256a88","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"},{"id":"2daf88a8cb1e7dfd","type":"subflow","name":"Group Sonos Speakers","info":"","category":"","in":[{"x":100,"y":140,"wires":[{"id":"019bb764bb26a988"}]}],"out":[{"x":1540,"y":140,"wires":[{"id":"88d2898f6579fa51","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"c77a899029985c0d","type":"comment","z":"2daf88a8cb1e7dfd","name":"Group Sonos Speakers","info":"","x":160,"y":80,"wires":[]},{"id":"019bb764bb26a988","type":"subflow:4ed4def360353223","z":"2daf88a8cb1e7dfd","name":"","x":290,"y":140,"wires":[["8fa424986cca3c5d"]]},{"id":"fad4e56c0cae913a","type":"function","z":"2daf88a8cb1e7dfd","name":"Set Master and Group Members","func":"msg.loop_through = msg.payload\nmsg.group_members = [];\n\nfor (var i = 0; i < msg.payload.length; i++) {\n if(i === 0){\n msg.sonos_master = msg.payload[i].entity_id;\n }else{\n msg.group_members[i-1] = '\"' + msg.payload[i].entity_id + '\"';\n }\n}\n\nmsg.group_members = msg.group_members.join(\",\")\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":140,"wires":[["703f711e0835ed75","feb90444894a2eb9"]]},{"id":"703f711e0835ed75","type":"api-call-service","z":"2daf88a8cb1e7dfd","name":"Group Sonos Speakers","server":"fcf9b76b.256a88","version":5,"debugenabled":true,"domain":"media_player","service":"join","areaId":[],"deviceId":[],"entityId":[],"data":"{\"entity_id\":\"{{sonos_master}}\",\"group_members\":[{{{group_members}}}]}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1110,"y":140,"wires":[["88d2898f6579fa51","0fae693f4a27e55e"]]},{"id":"b93fc264f3f032ba","type":"function","z":"2daf88a8cb1e7dfd","name":"Next Speaker","func":"return msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1360,"y":200,"wires":[["88d2898f6579fa51"]]},{"id":"24b9feaaaeb5e7a3","type":"api-call-service","z":"2daf88a8cb1e7dfd","name":"Set Volume","server":"fcf9b76b.256a88","version":5,"debugenabled":false,"domain":"media_player","service":"volume_set","areaId":[],"deviceId":[],"entityId":["{{payload.entity_id}}"],"data":"{\"volume_level\":\"{{audio_volume_level}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1590,"y":200,"wires":[["b93fc264f3f032ba"]]},{"id":"88d2898f6579fa51","type":"array-loop","z":"2daf88a8cb1e7dfd","name":"Loop Through List","key":"al88d2898f6579fa51","keyType":"msg","reset":false,"resetValue":"value-null","array":"loop_through","arrayType":"msg","x":1370,"y":140,"wires":[[],["24b9feaaaeb5e7a3"]]},{"id":"feb90444894a2eb9","type":"debug","z":"2daf88a8cb1e7dfd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1050,"y":220,"wires":[]},{"id":"0fae693f4a27e55e","type":"debug","z":"2daf88a8cb1e7dfd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1310,"y":300,"wires":[]},{"id":"8fa424986cca3c5d","type":"ha-get-entities","z":"2daf88a8cb1e7dfd","name":"ID Sonos Speakers","server":"fcf9b76b.256a88","version":0,"rules":[{"property":"entity_id","logic":"is","value":"(?<=media_player)(.*)(?=_sonos$)","valueType":"re"}],"output_type":"array","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":550,"y":140,"wires":[["fad4e56c0cae913a"]],"info":"The name of all Sonos speakers installed in the house ends with _sonos. Use a filter to identify and build an array of all active speakes."}]
