I’ve already installed Home Assistant on Ubuntu Server (Xenial) but in the Hassbian version I haven’t neither the snapshot option and neither the add-ons.
Well… how I can migrate with all add-ons? for the config is obiouvlsy simply… just copy all the config files… but for the addons and relative configs?
Or it’s possible to install HASS.io over an Atom board?
In this case I will install Home Assistant, not HASS.io … so would mean that I would not have addons and other special features of HASS.io… it’s correct?
You could install in a vm, but at that point why are you running hass.io on an ubuntu server. You were obviously running hass.io on a Pi before, so I’d just go back to that over a vm.
There are no plugins for home assistant, and the configs for the plugins are not really useful outside of hass.io. So, you’ll have to install each component you want and configure it.
If you want an easier way to setup samba, ssh, fail2ban, and more, you could install webmin which I really like for configuring my ubuntu server.
Hass.io is just a Docker management tool, so it should be possible to manual run the same Docker images that are used by the hass.io addons.
Or, choose a different management tool, for instance Rancher, like I’m doing (Rancher as an alternative to HASS.io).
Next time I will trying to run HASS.io on a VM as described here https://resin.io/blog/no-hardware-use-virtualbox/
Now I would want to try the Home Assistant on Ubuntu Server… for the moment I’ve Home Assistant running on this machine and I’ve already copied all the config files that I’ve on the HASS.io on RPi3 but I got some error that I can’t explain:
2018-01-02 11:39:14 ERROR (MainThread) [homeassistant.loader] Unable to find component hue
2018-01-02 11:39:14 ERROR (MainThread) [homeassistant.setup] Setup failed for hue: Component not found.
2018-01-02 11:39:16 ERROR (Thread-5) [homeassistant.components.notify.nma] Wrong API key supplied: Your IP exceeded the maximum number of API calls per hour allowed.
2018-01-02 11:39:16 ERROR (MainThread) [homeassistant.components.notify] Failed to initialize notification service nma
2018-01-02 11:39:19 ERROR (Thread-11) [homeassistant.util.package] Unable to install package https://github.com/jabesq/netatmo-api-python/archive/v0.9.2.zip#lnetatmo==0.9.2: Command "/home/igor/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-x6otmjl1-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-ikgs6h17-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/igor/homeassistant/include/site/python3.5/lnetatmo" failed with error code 1 in /tmp/pip-x6otmjl1-build/
2018-01-02 11:39:19 ERROR (MainThread) [homeassistant.setup] Not initializing netatmo because could not install dependency https://github.com/jabesq/netatmo-api-python/archive/v0.9.2.zip#lnetatmo==0.9.2
2018-01-02 11:39:19 ERROR (MainThread) [homeassistant.setup] Setup failed for netatmo: Could not install all requirements.
2018-01-02 11:39:19 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.netatmo. Setup failed for dependencies: netatmo
2018-01-02 11:39:19 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.netatmo: Could not setup all dependencies.
2018-01-02 11:39:23 ERROR (Thread-9) [homeassistant.util.package] Unable to install package google-api-python-client==1.6.4: Command "/home/igor/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-uex0kl7g/httplib2/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-s53c5zjp-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/igor/homeassistant/include/site/python3.5/httplib2" failed with error code 1 in /tmp/pip-build-uex0kl7g/httplib2/
2018-01-02 11:39:23 ERROR (MainThread) [homeassistant.setup] Not initializing google because could not install dependency google-api-python-client==1.6.4
2018-01-02 11:39:23 ERROR (MainThread) [homeassistant.setup] Setup failed for google: Could not install all requirements.
Many thanks @Tinkerer! now is almost all working fine… remain Philips Hue that won’t work… why?
2018-01-03 10:06:34 ERROR (MainThread) [homeassistant.loader] Unable to find component hue
2018-01-03 10:06:34 ERROR (MainThread) [homeassistant.setup] Setup failed for hue: Component not found.
2018-01-03 10:06:38 WARNING (Thread-2) [pyW215.pyW215] Failed to open url to 192.168.1.41
2018-01-03 10:06:45 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
2018-01-03 10:06:45 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2018-01-03 10:06:47 WARNING (MainThread) [homeassistant.components.switch] Setup of platform fritzdect is taking over 10 seconds.
2018-01-03 10:07:10 WARNING (Thread-10) [pyW215.pyW215] Failed to open url to 192.168.1.41
2018-01-03 10:07:23 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from fritz took longer than the scheduled scan interval 0:00:12
2018-01-03 10:07:25 WARNING (Thread-9) [netdisco.ssdp] Error fetching description at http://192.168.0.254:49152/wps_device.xml
2018-01-03 10:07:28 WARNING (Thread-9) [netdisco.ssdp] Error fetching description at https://192.168.1.40/HNAP1/
There should be more errors further up, near the beginning of the startup, that help identify it. You may want to use the likes of https://hastebin.com/ to share the first 50 lines or so after startup.
Philips Hue and Netatmo it’s the only two component that are not working for me.
This is all the logs that I saw from “Info” page: https://hastebin.com/qutiliwezi.sql
