Hi all,
I just installed the telegram platform and it apparently works, but I suspect it misses some notifications and my home_assistant.log
is flooded every few seconds by these error messages:
2020-03-09 19:50:59 ERROR (updater) [telegram.ext.updater] Error while getting Updates: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running (409)
2020-03-09 19:51:05 ERROR (updater) [telegram.ext.updater] Error while getting Updates: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running (409)
2020-03-09 19:51:11 ERROR (updater) [telegram.ext.updater] Error while getting Updates: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running (409)
2020-03-09 19:51:18 ERROR (updater) [telegram.ext.updater] Error while getting Updates: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running (409)
2020-03-09 19:51:33 ERROR (updater) [telegram.ext.updater] Error while getting Updates: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running (409)
2020-03-09 19:51:38 ERROR (updater) [telegram.ext.updater] Error while getting Updates: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running (409)
2020-03-09 19:51:44 ERROR (updater) [telegram.ext.updater] Error while getting Updates: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running (409)
2020-03-09 19:51:51 ERROR (updater) [telegram.ext.updater] Error while getting Updates: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running (409)
2020-03-09 19:51:59 ERROR (updater) [telegram.ext.updater] Error while getting Updates: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running (409)
2020-03-09 19:52:09 ERROR (updater) [telegram.ext.updater] Error while getting Updates: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running (409)
I followed the official guide and here is my structured configuration.yaml
integrations/telegram_bot.yaml
telegram_bot:
- platform: polling
api_key: !secret telegram_bot_api_key
allowed_chat_ids:
- !secret telegram_bot_piero_chat_id
integrations/notify.yaml
notify:
- name: telegram_piero
platform: telegram
chat_id: !secret telegram_bot_piero_chat_id
automations.yaml
(generated by the WEB UI):
- id: '1583691545817'
alias: Corona virus
description: ''
- entity_id: sensor.italy_coronavirus_confirmed
platform: state
condition: []
- data:
message: 'Corona virus confirmed Italy: {{ states("sensor.italy_coronavirus_confirmed")
service: notify.telegram_piero
automations/notify_failed_logins.yaml
alias: "Notify failed logins"
initial_state: true
- platform: state
entity_id: persistent_notification.http_login
condition:
- condition: template
value_template: "{{ trigger.to_state.state != 'None' }}"
- service: notify.telegram_piero
data_template:
title: "{{ states.persistent_notification.http_login.attributes.message }}"
message: 'url: https://whatismyipaddress.com/ip/{{ states.persistent_notification.http_login.attributes.message.split ("from ") [1]}}'
- service: persistent_notification.dismiss
notification_id: 'http_login'
automations/notify_new_devices.yaml
alias: "Notify new devices"
initial_state: true
- platform: event
event_type: device_tracker_new_device
data_template:
message: '{{trigger.event.data.entity_id}}'
title: New device
Please help me to sort out this.
Thanks,
Piero
