I am trying to setup grott, i’ve looked at a couple posts about grott but havent found anything that could resolve my issue.
I have an shine wifi stick s which i’ve configured through server.growatt, the domain i’ve set to homeassistant.
But grott isnt making any new sensors nor do i see anything in the mqtt.
Who can help me with this?
I am using Grott stable branch (2.7)
this is my config sofar
Try following the steps in Growatt Inverter - What to do now? - #7 by mrfixit1. Afaik #1 is only possible locally in the datalogger, not with the shine wifi stick or on the Growatt server. Your last screen is from the Grott integration, which you don’t need if you use the add-on and mqtt.
