I want to turn on (restart) my wood pellet stove when I’ve determined it has failed, which it does often for multiple reasons. Mostly, and most annoyingly, it shuts off with a “Goodbye” message for no apparent reason. It happen multiple times a day and night.
The only trigger I’ve been able to get to work at all is when the room temp falls below a specific value. That works. None of my attempts at Template sensors work.
The. Automation
alias: "Fix wood stove error "
description: ""
value_template: >-
"{{ states('sensor.esph_house_stove_current_temp')|float(0) +4 <=
states('sensor.esph_house_stove_set_temp')|float(0) }}
- platform: state
entity_id:
- sensor.stove_error
to: "true"
- platform: numeric_state
entity_id: sensor.esph_house_stove_current_temp
below: 64
condition: []
- service: climate.set_hvac_mode
hvac_mode: heat
entity_id: climate.house_wood_pellet_stove
- service: notify.mobile_app_jeffs_128gb_ipad
message: >-
Stove Error. House Temp={{
states('sensor.esph_house_stove_current_temp')}}. Set
temp={{states('sensor.esph_house_stove_set_temp')}}
- service: notify.mobile_app_jeffs_iphone_se
message: >-
temp={{states('esph_house_stove_set_temp')}}
mode: single
The sensor i created trying another way:
stove_error:
value_template: "{{ states('sensor.esph_house_stove_current_temp')|float(0) +4 <= states('sensor.esph_house_stove_set_temp')|float(0) }}"
This isn’t rocket science but it won’t fire. The stove_error sensor goes from false to true and my template in the automation does the same in the template inspector.
From this
To this:
And in the template inspector
What am I doing wrong???
