Help with creating current energy use graphs
I am very new to HA, and have setup the energy menu that is integrated into HA.
Now i would like to create a second one with current use (like every 5 seconds for example)
I maneged to get this far:
But the example I found wich i would like to make looks like this:
I just cant get it done, also the example screen looks fullscreen and mine is very small.
Here is my config so far:
type: vertical-stack
cards:
  - type: horizontal-stack
    cards:
      - type: custom:mini-graph-card
        entities:
          - entity: sensor.solaredge_energy_today
        line_color: green
        line_width: 4
        font_size: 80
        entities:
          - entity: sensor.power_consumption
        line_color: orange
        line_width: 4
        font_size: 80
        entities:
          - entity: sensor.power_production
        line_color: red
        line_width: 4
        font_size: 80
    entities:
      - entity: sensor.solaredge_current_power_kwh
        color: green
        color: orange
        color: red
    line_width: 3
    font_size: 100
    show:
      labels: true
      labels_secondary: true
Also, i have some as W and some as kW, all at W would look better I think.
Can someone maybe help me with this?
Set your view in panel mode :+1:
Thanks! did not know about that.
looks better now,
only one Template i made does not seem to work:
  sensors:
    power_consumption_w:
      friendly_name: Power Consumption (W)
      unit_of_measurement: "W"
      value_template: "{{ states('sensor.power_consumption')|float * 1000 }}"
# Calculate Remaining Power
  sensors:
    power_consumption_grid:
      friendly_name: Power Consumption Grid
      value_template: >
        {{ '%0.1f' | format(states('power_consumption_w') | float -
                            states('solaredge_current_power') | float) }}
Read the docs about templates sensors. It should look like this :
template:
  - sensor:
      - name:  power_consumption_w
        state: "{{ states('sensor.power_consumption')|float * 1000 }}"
      - name: Power Consumption Grid
        state: >
          {{ '%0.1f' | format(states('power_consumption_w') | float - states('solaredge_current_power') | float) }}
and it goes to your configuration.yaml directly
I removed the 2 I had in sensors.yaml and placed your in the configuration.yaml.
But it still shows 0
About Templates, must i always place them in the configuration.yaml? i now have them all in sensors.yaml
having templates sensors in sensor.yaml is the old way. You should migrate them all according the new way :slight_smile:
Read the doc here : Template - Home Assistant
Wich one is displaying 0 ? power consumption grid ? Maybe the sensor you are reading is also at 0 ?
Oke thanks, i still need to read and try understand a lot of HA.
The red power consumptin grid shows 0.
This one should show a total from "power consumption - solar energie = total use
example in screenshot:
So lets say I consume 1000 watt, get 500 from solar, it should show a red line to 500 red line (use from net)
i consume 1000, get 2000 from solar, it should show -1000 in a red line.
Found it, these 2 works.
  - sensor:
        state: >
          {{ '%0.1f' | format(states('sensor.power_consumption_w') | float - states('sensor.solaredge_current_power') | float) }}
  - sensor:
      - name: "Power Consumption Grid"
        state: >
          {% set PowerConsumption = states('sensor.power_consumption_w') | float %}
          {% set SolarPower = states('sensor.solaredge_current_power') | float %}
          {{ ((PowerConsumption - SolarPower)) | round(1) }}
But now i wonder, what’s the difference between those. and what meens % or %0.1f
and in the set PowerConsumption, set SolarPower, do those 2 values only exists here or did it create sensors or can i use these global now?
I think both sensors gives you the same output. In the first version you use the the python code 0.1f, meaning the result is formatted as a float value with one decimal.
The % use used within the template to execute the commands I think. You use it in almost all template definitions.
The second sensor converts the state of the input to float with the | float at the end. Better is to use | float(0) though. That also provides a default value of 0 in case the input is unavailable. Currently this still works without the default value, but will need mandatory in the December release I believe.
To your last question… Those variables are only temporary and usable within your template, not outside of it. I am not 100% sure though…
P.S. I see you also use the SolarEdge integration, you may find other useful templates and examples in my project.
Thanks, wil look at it tomorrow!
Last question for today :stuck_out_tongue:
I would like to create a “current cost” for the current energy and gas use.
The energy intereation created:
sensor.energy_consumption_tarif_1_cost
sensor.energy_consumption_tarif_2_cost
I created a total one:
- name: Energy Consumption (tarif total) Cost
      state: >
        {% set EnergyConsumptionTarif1 = states('sensor.energy_consumption_tarif_1_cost') | float(0) %}
        {% set EnergyConsumptionTarif2 = states('sensor.energy_consumption_tarif_2_cost') | float(0) %}
        € {{ ((EnergyConsumptionTarif1 + EnergyConsumptionTarif2)) | round(3) }}
But this one is counting up instead of the “current cost”
is there a way to create something like:
Current cost a hour = kwh price x ‘Power Consumption Grid’
Same for the gas.
So as results I want 4 bars,
1 energy current cost. .
1 energy costs today
1 gas current cost
1 gas cost today
I think you should use the utility_meter integration. This creates a new sensor based on a selected input, and can be reset on an hourly, daily, monthly, yearly basis.
In your case you would create 2 meters which reset hourly and use that for the multiplication. That starts from 0 each hour.
I tried, but that does not work. it still counts, so only at the full hour it shows the energy price.
I think i just manualy set the energy price in it. Example 0.50 cent X current grid power.
Just have to find a way to switch between prices when daytime and negative (back to grid) values
Is there also a way to get the icons in here?
example:
Hi Ricks88,
I red your topic and that’s just what I need… :wink:
Could I have your final code, it would save me a lot of time ?
Thanks !
This is all the layout code:
cards:
  - type: custom:gap-card
    height: 5
    cards:
      - type: custom:apexcharts-card
        header:
          title: Energie verbruik
          show: true
          show_states: true
          colorize_states: false
        graph_span: 2h
        layout: minimal
        series:
          - entity: sensor.power_consumption_w
            unit: ' Watt'
            color: '#00648e'
            opacity: 0.5
            type: area
            curve: smooth
            stroke_width: 2
        apex_config:
          stroke:
            show: true
          legend:
            show: false
          yaxis:
            show: false
          chart:
            height: 175px
        header:
          title: Oplevering Zonnepanelen
          show: true
          show_states: true
        graph_span: 2h
        layout: minimal
        series:
            unit: ' Watt'
            color: '#ffaa5b'
            opacity: 0.5
            type: area
            curve: smooth
            stroke_width: 2
        apex_config:
          stroke:
            show: true
          legend:
            show: false
          yaxis:
            show: false
          chart:
            height: 175px
        header:
          title: Netto verbruik
          show: true
          show_states: true
        graph_span: 2h
        layout: minimal
        series:
          - entity: sensor.power_consumption_grid_pos
            unit: ' Watt'
            color: '#9a001d'
            opacity: 0.5
            type: area
            curve: smooth
            stroke_width: 2
          - entity: sensor.power_consumption_grid_neg
            unit: ' Watt'
            color: '#8756cb'
            opacity: 0.5
            type: area
            curve: smooth
            stroke_width: 2
        apex_config:
          stroke:
            show: true
          legend:
            show: false
          yaxis:
            show: false
          chart:
            height: 175px
      - type: entity
        entity: sensor.solaredge_storage_level
        state_color: true
  - type: custom:stack-in-card
    mode: vertical
    cards:
      - type: entities
        entities: []
        graph_span: 6hours
        header:
          show: true
          show_states: true
          colorize_states: true
        series:
            color: '#00648e'
            opacity: 0.3
            type: area
            color: '#ffaa5b'
            opacity: 0.4
            type: area
            color: '#9a001d'
            opacity: 0.3
            type: area
            name: Netto Teruglevering
            color: '#8756cb'
            opacity: 0.3
            type: area
        now:
          show: true
          color: red
          label: Nu
        apex_config:
          stroke:
            show: true
            width: 2
            curve: smooth
          legend:
            show: true
          yaxis:
            show: true
          chart:
            height: 550px
        height: 5
Thats what you needed?
Thank you…could you alsof give me the definitions of the sensors you use in this layout ?
Can i send a file somehow?
Or try this:
# Power Consumption Grid
# Bereken Energie verbruik - Opbrengst Zonnepanelen = netto verbruik
  icon: "mdi:transmission-tower"
  state: >
    {% set PowerConsumption = states('sensor.power_consumption_w') | float(0) %}
    {% set SolarPower = states('sensor.solaredge_current_power') | float(0) %}
# Power Consumption Grid Negative only = Teruglevering
# Bereken Energie verbruik - Opbrengst Zonnepanelen = Netto Verbruik, show positive only dus alleen Teruglevering
  name: Power Consumption Grid (Neg)
  icon: "mdi:transmission-tower-export"
  state: >-
    {% set PowerConsumptionGridNeg = (PowerConsumption - SolarPower) | int %}
    {{ ([-10000, PowerConsumptionGridNeg, 0] |sort) [1] }}
# Power Consumption Grid Positive only
  name: Power Consumption Grid (Pos)
  icon: "mdi:transmission-tower-import"
  state: >-
    {% set PowerConsumptionGridPos = (PowerConsumption - SolarPower) | int %}
    {{ ([0, PowerConsumptionGridPos, 10000] |sort) [1] }}
# Power Consumption in Watt, kWh to W
  icon: "hass:lightning-bolt"
Sorry for my late reaction.
First of all : thank you !
One problem : I presume I have too much data, cause when I put these graphs on my dashboard my computer is in trouble… I’m working with the Slimme Meter (via ESPHome).
Editing the data can be very slow, but on my Raspberry Pi 4b it is no problem…
I do not use ESPHome, just ‘SlimmeLezer’ P1 port.
It should only show data for 4hours or 6 in the big graph?
