Fairly new to Home Assistant and was wondering since the Growatt API has stopped working has anyone been successfully in getting Grott working?
I would like to setup Grott and haven’t been successful yet.
What I’m using and what I’ve done so far
HA OS on Vmware 8.0
It has MQTT already in use on it as I’ve got a few solar projects running on it
I install grott on a ubuntu VM and started it as a service
Changed the IP address on the Growatt datalogger
Grott on that ubuntu server sees traffic from the datalogger
Now I just need to get the data from that Grott server to Home Assistant?
As obviously many newbies I have spent hours of frustration with Homeassistant and Grott.
I am a semi retired electrical master engineer of 62 years and have my 10kVA PV 1fase 230V System in Spain set up with 10kWh Lifepo4 from Pylontec plus 10kWh from Orientpower on 2 new SPF 5000 and am controlling the load or demand side with 5 SSR plus some Shelly and ESP.
My question is should I give up on GROTT and HOMEassistant and switch all analog ?
I get problems with depression from GROTT and Home Assistant as I have already spent 100+ hours and several month on it and it seems this is not likely to work ever.
can somebody set up Grott for 200€ for me via teamviewer? the young German HA guy who I know was not able to achieve much or did not really want to work.
So… I am not too young myself but no clue whar Orientpower Pylontec SSR etc…
The idea of grott is to receive the data via a shine-thing or sniff network, then put that to a MQTT
Assuming you are using a shine-thing then is this connected to the same network (segment) as your grott server? Have you installed grott as a separate container? Any logs from grott? If grott is starting up correctly and connects to MQTT…can you send me the config?
Have you been able to change the server IP to the grott one on the shine-thing?
So, I have the container version and in the persistent volume there is a grott.ini.
Aside the mapping to mqtt and mapping to the growatt could (if one wants this) most was left as-is
Please specify what HA version you use, how you set Grott up etc. difficult guessing
EDIT: this is my setup
My growatt connects via shine stick to a wifi range extender
My grott is a container on my HA server (also container version)
The shine stick is configured to map to my grott container…this was the most tricky thing I found
On the same HA server I also have MQTT and grott connects to that
If you reached this point then from there on it is simple as HA can get the data from MQTT
Apparently one can skip the connection shine > grott by sniffing network trffic but never tried it
But I have two inverters with different device serial number and now they end up in the same entities.
Do you know how to seperate them into a different entity per ‘device’?
