Help with Person Card for Newb
I’ve been trying to come up with a person card for my dashboard with this criteria:
  • Entity Picture
  • Phone battery level (either via dynamic icon or a %)
  • location status (ie. home or away)
    -distance or time to home (or both)…I already have the waze travel time integration installed.
    So far this is what I’ve come up with (on two cards)
    dashboard
Here is the code I used for the person card:
aspect_ratio: 3/1
custom_fields:
  battery: |
      return `${
        states['sensor.iphone_battery_level'].state
entity: person.eric
layout: icon_name
show_entity_picture: true
show_name: true
state:
  - name: 🏡 Eric (Home)
    styles:
      name:
        - color: '#7DDA9F'
    value: home
  - name: 🏃‍♂️ Eric (Away)
    styles:
      name:
        - color: '#93ADCB'
    value: not_home
  - styles:
      name:
        - color: gray
    value: unknown
styles:
  custom_fields:
    battery:
      - position: absolute
      - left: 140px
      - border-radius: 50%
      - height: 30px
      - width: 30px
      - font-size: 14px
      - line-height: 30px
      - padding: 5px
      - color: |-
            return states['sensor.iphone_battery_level'].state > 20
            ? 'white'
            : 'black'
      - background-color: |-
              ? '#7DDA9F'
              : 'red'
  icon:
    - width: 60%
type: custom:button-card
No help from anyone? I was trying to take examples from multiple places, but when I copy and paste code (even insuring the entities are right), I get errors that aren’t very comprehensive.
I was following this thread: Person Cards - Show Off Yours
I tried copying the code from the OPs first post, but the problem is there have been updates and the process to do several things seems to have changed. Also, it’s apparetnely not as simple as just creating a custom card and dropping the code in there…it seems you have to use templates, decluttering cards etc. I may just be over my head.
I can’t help you as I came here looking for the same help. I’ll likely pay someone on fiverr to help me out if the price is right
The easiest I found is to use the custom button mod from HACS - GitHub - custom-cards/button-card: ❇️ Lovelace button-card for home assistant
Custom Card Button
This allows you to do quite a bit without having to go in the template and decluttering space, install the custom button card via hacs, refresh the browser, go to a view where you want to add the card, add a custom button card
it will pop up with something in it, like this:
next you paste this yaml in it:
entity: person.franco
aspect_ratio: 1/1
show_name: false
hold_action:
  action: none
state:
  - value: home
    styles:
      custom_fields:
        icon:
          - border-color: '#77c66e'
  - value: not_home
    styles:
      card:
        - background-color: '#dedede'
      custom_fields:
        icon:
          - border-color: '#EF4F1A'
  - value: Work
    styles:
      custom_fields:
        icon:
          - border-color: deepskyblue
styles:
  card:
    - background-color: lightblue
    - border-radius: 5%
    - padding: 5%
    - color: gray
    - font-size: 10px
    - text-shadow: 0px 0px 0px black
    - text-transform: capitalize
    - justify-self: end
    - align-self: middle
  grid:
    - grid-template-areas: '"icon status" "n n" "battery proximity" "wifi ss" "sd sd"'
    - grid-template-columns: 2fr 1fr
    - grid-template-rows: 1fr min-content min-content min-content min-content
  name:
    - font-size: 15px
    - justify-self: start
    - padding-bottom: 10px
  custom_fields:
    icon:
      - clip-path: circle()
      - width: 60%
      - pointer-events: none
      - display: grid
      - border: 5px solid
      - border-color: gray
      - border-radius: 500px
      - margin: 0 +10% 0 0
      - justify-self: end
      - opacity: 1
    status:
      - align-self: start
      - justify-self: end
      - color: gray
    proximity:
      - padding: 0.5em 0px
      - color: gray
    wifi:
      - color: gray
      - '--text-wifi-color-sensor': >-
          [[[ if (states["sensor.m2101k6g_wifi_connection"].state == '<not
          connected>') return "#aaaaaa"; ]]]
    battery:
      - color: gray
      - '--text-color-sensor': >-
          [[[ if (states["sensor.m2101k6g_battery_level"].state < 50) return
          "#EF4F1A"; ]]]
custom_fields:
  icon: >
    [[[ return entity === undefined ? null : `<img
    src="${states[entity.entity_id].attributes.entity_picture}" width="100%">`;
  status: |
      if (states['person.franco'].state =='not_home') {
      return `<ha-icon icon="mdi:home-export-outline"
        style="width: 20px; height: 20px; color: '#888888';">
        </ha-icon><span> Away</span>`;
      if (states['person.franco'].state =='home') {
      return `<ha-icon
        icon="mdi:home"
        style="width: 20px; height: 20px; color: 888888;">
        </ha-icon><span> ${entity.state}</span>`;
      } else {
      return `<ha-icon
        icon="mdi:map-marker-radius"
  proximity: |
      return `<ha-icon
        icon="mdi:map-marker-distance"
        style="width: 20px; height: 20px; color: #888888;">
        </ha-icon>  <span>\<span style="color: var(--text-color-sensor);">${states['proximity.home'].state} Kms</span></span>`
  battery: |
      if (states['sensor.m2101k6g_battery_state'].state =='charging') {
        return `<ha-icon
        icon="mdi:battery-charging"
        </ha-icon> <span><span style="color: var(--text-color-sensor);">${states['sensor.m2101k6g_battery_level'].state}% battery</span></span>`;
      } else {
        return `<ha-icon
        icon="mdi:battery"
  wifi: |
      if (states['sensor.m2101k6g_wifi_connection'].state =='<not connected>') {
        return `<ha-icon
        icon="mdi:wifi"
        style="width: 20px; height: 20px; color: var(--text-wifi-color-sensor);">
        </ha-icon> <span><span style="color: var(--text-wifi-color-sensor);">Disconnected</span></span>`;
      } else {
        return `<ha-icon
        icon="mdi:wifi"
        </ha-icon> <span><span style="color: var(--text-color-sensor);">${states['sensor.m2101k6g_wifi_connection'].state}</span></span>`;
replace all instances of person.franco with your person.xxxx details, replace all sensor.m2101k6g_battery_level with the appropriate sensors that is tied to that persons card. I am still working on the waze bit, it should not be too difficult to add, o yes you end up with something like this:
image_2023-03-01_093404911
Still some tweaking to do
hi
verry nice card, but i have some problem with mine.
can you help me?
entity: person.george_stoica
aspect_ratio: 1/1
show_entity_picture: false
show_name: true
hold_action:
  action: none
state:
  - value: home
    styles:
      custom_fields:
        icon:
          - border-color: '#ffff'
  - value: not_home
    styles:
      card:
      custom_fields:
        icon:
  - value: Work
    styles:
      custom_fields:
        icon:
styles:
  card:
    - border-radius: 3%
    - padding: 2%
    - color: gray
    - font-size: 18px
    - text-shadow: 1px 1px 1px dark_grey
    - justify-self: end
  grid:
    - grid-template-areas: '"icon status" "battery proximity" "n n"'
  name:
    - font-size: 35px
    - padding-bottom: 20px
  custom_fields:
    icon:
      - width: 100%
      - display: grid
      - border: 5px solid
      - margin: 0 -8% 0 0
      - justify-self: end
      - opacity: 1
    status:
      - align-self: start
      - justify-self: end
      - color: gray
    battery:
      - padding: 0.5em 10px
      - color: gray
          [[[ if (states["sensor.huawei_p30_pro_battery_level"].state < 20)
          return "#EF4F1A"; ]]]
    wifi:
      - padding: 0.1em 0px
      - color: gray
          [[[ if (states["sensor.huawei_p30_pro_wifi_connection"].state == '<not
custom_fields:
  icon: >
  status: |
      if (states['person.george_stoica'].state =='not_home') {
      if (states['person.george_stoica'].state =='home') {
      return `<ha-icon
        icon="mdi:home"
      } else {
      return `<ha-icon
  battery: |
      if (states['sensor.huawei_p30_pro_battery_state'].state =='charging') {
        return `<ha-icon
        </ha-icon> <span><span style="color: var(--text-color-sensor);">${states['sensor.huawei_p30_pro_battery_level'].state}% battery</span></span>`;
      } else {
        return `<ha-icon
        icon="mdi:battery"
  wifi: |
      if (states['sensor.huawei_p30_pro_wifi_connection'].state =='<not connected>') {
        return `<ha-icon
        icon="mdi:wifi"
      } else {
        return `<ha-icon
        icon="mdi:wifi"
        </ha-icon> <span><span style="color: var(--text-color-sensor);">${states['sensor.huawei_p30_pro_wifi_connection'].state}</span></span>`;
