Help with reverse engineering WebRTC with VicoHome Camera
I got a few of the Monkey Vision Cube Cameras from Bunnings.
Bunnings Link
Aliexpress Link
Manufactures Link?
They work with the VicoHome or Simple Monkey Vision App (same app, different service)
I’m trying to integrate them with Home Assistant.
Although they beep when scanned by the Tuya app, it doesn’t look compatible.
With the help of this article, I’ve been able to find the API calls to be able to interact with the API. Decrypting Android App SSL Traffic: A Practical Guide for Security Researchers
I’ve created a copy of the APK that allows User Certificates, otherwise it fails to connect when sniffing.
I’ve reached a dead end. It tasks about Turn/Stun/Ice, and I’m not sure where to go now.
I’ve been able to get to this point, but I can’t seem to get any further:
(I’ve obsucated the results as there’s credentials inside)
From the API: “/device/getWebrtcTicket”
traceId               : webrtc-NswDc9j1txxxxxxx
groupId               : 2f701774e1ce08acxxxxxxx
role                  : viewer
iceServer             : {@{url=turn:p-coturn-xxxxxxx.smartvideogo.com:5349; username=1999999989:199999961; credential=Rxxxxxxxxxxxxxxxistk=; ipAddress=152.99.999.999}}
signalServer          : wss://p-signal-99999999.smartvideogo.com
signalServerIpAddress : 54.99.99.99
sign                  : b4623d1735455xxxxxxxxxxxxd
signalPingInterval    : 2
maxAllocationLimit    : 32
appStopLiveTimeout    : 20
deviceSleepTimeout    : 30
time                  : 1702119689105
expirationTime        : 1702378889105
websocketPath         :
accessToken           :
From WireShark, it seems to be streaming on UDP, but I can’t seen to find any RSTP feed. I’m not as proficient in WireShark as I would like.
I’m not entirly sure what WebRTC is either, or how it works through the Turn/Stun/Ice.
If anyone can point me to the right direction I would appreciate. I’m ultimatley looking to get it into Frigate, or similar.
Thankyou.
Ask their support Contact Us - Monkey Vision
Hi Tom,
I’ve asked both Monkey Vision and VicoHome support regarding any API or feeds, and they both don’t offer anything. VicoHome said they may add something in the future.
It’s worth an ask Michael. My guess is as far as “easy” methods go, they seem to encrypt everything within that stream from port 8765 and our only hope is a bootloader method. Must admit I’m suprised how responsive the local view (on app) is if it is all going via cloud and then back to the app, which initially made me think there was some P2P comms going between the cam and client - but no proof so far.
WireShark shows direct UDP stream from the camera to the phone :thinking:
I’ve been trying to work through this same problem. I see the same direct UDP stream in Wireshark that you’ve described, but it seems the video is being displayed through WebRTC. With WebRTC, the camera (and the connecting device) are each a random port greater than 37000 or so for the duration of the stream. If you end the stream and start it again, the ports will change. I’m guessing this functionality is built directly into the camera to create a local stream?
At any rate, I’m afraid I’m at a dead end. I’ve also tried scanning the camera with nmap, but it shows no open ports, so no easy way to grab a video feed there. VicoHome does advertise some integration with Google Assistant/Alexa, so it’s not completely closed off, but there doesn’t seem to be much documentation.
I’d be very interested if there was any further development on this topic.
I have a bird feeder with cg122 caméra from vicohome.
Interrested in any progress
Laurent
Same here.
Any luck on this? I am also trying to integrate Vison Well camera that works with VicoHome app.
same here. Vicohome.
Works?
I don’t know if this might help someone but I ran across a recent blog post (Jul 17) from a VicoHome dev regarding WebRTC and something new called IoT-RTC. Not much in the way of technical details but it may mean there are hooks in place that weren’t there before.
https://vicohome.app/introduce-webrtc-into-ip-cameras-for-the-1st-time-worldwide/
I have one of these too. Any luck?
Bump :slight_smile: im really interested too.
Following. Have a bird feeder camera that connects to the Vicohome app. Would love to figure out how to get the feed to display through Home Assistant.
Screenshot 2025-01-13 at 3.15.25 PM
I got one of these for Christmas and with no effort Home Assistant seems to have found it… but I have no idea how to get a PIN number for it?
Hi everyone,
I’m been following this thread with great interest as I also have a VicoHome camera and am keen to enable local streaming, specifically RTSP, for use with TinyCam Monitor or similar applications.
I have a VicoHome CG6F camera, which is sometimes also listed as CG625A2-TN4.
Here’s the information I have about my camera:
  • Model: CG6F (CG625A2-TN4)
  • Firmware Version: 1.9.10
  • MCU Version: 0.7.12
  • Wi-Fi Module: Sichuan AI-Link Technology Co., Ltd.
  • Streaming Protocol: WebRTC (as expected, no RTSP natively)
  • Resolution: 2304x1296 (2K)
  • Cloud Service: VicoHome (api-eu.vicohome.io)
Like others here, my primary goal is to get an RTSP stream working for local access. I understand custom firmware is likely the most promising route, but identifying the chipset is the first hurdle.
My main questions for the community are:
  • Has anyone managed to open a VicoHome CG6F (or CG625A2-TN4) and identify the chipset used? Knowing the chipset would be incredibly helpful for exploring custom firmware compatibility, particularly with projects like OpenIPC.
  • Are there any known custom firmware projects, even in early stages, that might be relevant to VicoHome cameras or similar models?
  • Has anyone made progress in reverse-engineering the WebRTC stream from VicoHome cameras, or found alternative methods to achieve local streaming?
    I’m technically inclined and willing to help explore solutions. If identifying the chipset requires opening the camera, I’m prepared to do that carefully if needed.
Any insights, information, or pointers you can share would be hugely appreciated!
Thanks in advance for your help and collaboration.
my HA never finds mine… i even tried to manually find it and it won’t
I have 16 of this Vicohome GG6S cameras, because they are very cheap and work on battery for months, I want to integrate all of them into my HA, I will keep an eye on this post.
I have the Vicohome CG625-TN7. I’ve opened it up; the SoC is the Ingenic T23, (I think) NAND memory, and wifi chip set is the WF-H861L-SSA1. There is an open source firmware called thingino, however it doesn’t support the memory or wifi. Like everyone else I also tried doing packet captures but to no avail, I will try editing the app to support user certs so I can mitm the TLS connection. Has anyone tried setting up in hotspot mode instead of network?
SoC and wifi:
I wasn’t able to successfully rebuild the APK to intercept the TLS calls to their API, for some reason no matter what it fails trusting PCAPDroids mitm cert, but I did see in the STUN payload that Vicohome is using the Coturn TURN server. I also found someone else trying to reverse engineer their API: GitHub - dydx/vico-cli: My attempts at reverse engineering the vicohome.io api to get my bird data. Using their example in auth.go I was able to authenticate to their API and get a token with curl -X POST -d '{"email":"<<username>>","password":"<<password>>","loginType":0}' -H 'Content-type:application/json' -H 'Accept:application/json' https://api-us.vicohome.io/account/login.
From what I’ve read, TURN requires a username and password, however it’s advised to use an API to randomly generate one for each connection, so it seems I need to figure out how to get their API to do this for me, then I think I can authenticate to the STUN server running on the camera, however I’m not really sure what to do after that. I did figure out I can test authentication to their TURN servers using Trickle ICE.
Any hints on why the Vicohome app refuses to trust my CA cert? I’ve installed it on my phone and went through gist.github com/luciopaiva/aa9cb30863804fb2ac3ed1ccd11c95c7 and gist.github com/luciopaiva/809f198e8c96781ad1db63c01732e985 to repack it but regardless of SDK version or what’s in network_security_config.xml it doesn’t want to trust it and all TLS calls fail.
