Hi all,
I am trying to improve the functionality of the FLOORPLAN component by allowing service_templates. I want to be able to click on an element and have the action defined by a service_template. The original file ha-floorplan.html is here: ha-floorplan/www/custom_ui/floorplan at master · pkozul/ha-floorplan · GitHub
I have done some initial modifications as follows and I have access to the service_template BUT because I don’t know much about the backend of Home Assistant initially I had thought the service_template would already be parsed by the time it got to here but it isn’t. I then tried to replicate code I could see for a data_template but this is just giving me a script error. So the question is can someone point me in the direction of or provide a solution to what I need to add to get the service_template parsed to its final value? This is what is coming in as the service_template:
{% if is_state(‘light.meals_room’, ‘on’) %}turn_off{% else %}turn_on{% endif %}
This is where I am at the moment:
onEntityClick(e) {
e.stopPropagation();
let entityId = this.entityId;
let entityConfig = this.instance.entityConfigs[entityId];
if (entityConfig.group.action) {
let action = entityConfig.group.action;
let service = action.service ? action.service : {};
if (action.service_template) {
this.instance.warn(action.service_template);
let entities = this.instance.hass.states;
let entityState = entities[entityId];
let result = this.instance.assemble(action.service_template, entityState, entities);
service = JSON.parse(result);
if (service) {
let domain = action.domain ? action.domain : entityId.substr(0, entityId.indexOf('.'));
domain = (domain == 'group') ? 'homeassistant' : domain;
let data = {};
if (action.data) {
data = action.data;
if (action.data_template) {
let result = this.instance.assemble(action.data_template, entityState, entities);
data = JSON.parse(result);
if (!data.entity_id) {
data['entity_id'] = entityId;
this.instance.hass.callService(domain, service, data);
else {
this.instance.fire('hass-more-info', { entityId: entityId });
else {
No the issue was there are a couple of rooms which have multiple bulbs grouped together. Occasionally these get out of sync and using toggle just results in them staying out of sync.This solution ensures that if any lights do stay on then another press on the floorplan will result in them turning off. If it happens when I turn them on then, yes, I will have to turn them all off and then turn them back on. I do have another page where all the bulbs are individually accessible but this will hopefully speed the process by allowing me to stay on my main screen.
All I see is a single Lovelace action that doesn’t distinguish between on and off. It simply toggles the state of light.rear_hallway (a lightHue group).
The difference is if you call the script it will only toggle off the state. If you call the script, it will always toggle on the individual state, not the entire group.
current group state: on
You call either the script or toggle to turn it off:
Using Developer Tools > Services, I called script.dining_room_toggle to turn the two lights on/off. I repeated the test with light.toggle. The lights behaved the same way; no difference.
Then I used light.turn_on to turn on just one of the two lights and compared the behavior of using the script versus light.toggle. The lights behaved the same way; no difference. If either light is on, both lights are turned off.
Not disputing your experience but with my lights this doesn’t happen. If just one light is on and I call light.toggle then the light that is on goes off and the light that was off goes on. This is what @petro is trying to explain.
Petro’s explanation doesn’t describe my Hue group’s behavior. However, it does apparently describe your Hue group’s behavior. It’s this difference that interests me.
If you are also interested, and would like your Hue group to operate like my Hue group, I’m willing to compare notes so we can determine how our respective systems differ. On the other hand, if you prefer the way your Hue group behaves, then I guess we’re done here because I much prefer the way my Hue group responds to light.toggle.
I’d be willing to bet it’s hardware related (e.g. rev 1 vs rev 2). I have to have these ‘smart_toggles’ for old devices on my system. New devices are smart enough to understand grouping if they have associated devices.
