HiLetgo ESP32 *with 38 pins* which board to use?
Hi Everyone
I am using this board:
Curiosly it has 38 pins and I can’t get it working when I try to collect temperature using a DHT11 !!!
I was able to write the firmaware, I can ping and see this board using wifi and HA ESPHome and I am able to flash things using OTA/ESPHome but I can’t get DHT11 to work.
I believe the problem could be:
  • The “board” type I am using:
esphome:
platform: esp32
board: esp32dev
  • The pin I am using
  • platform: dht
    pin: 21
    temperature:
    humidity:
    model: DHT11
In my board, I read P21 but I am receiving this error:
[14:56:38][W][dht:162]: Requesting data from DHT failed!
[14:56:38][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number).
Do you have some idea or suggestion?
Please post your code properly quoted.
Can you switch a led or a relay with pin21?
Hi @nickrout
I will try with this led. Good idea.
My apologies ref the code. Here we go:
esphome:
  platform: esp32
  board: nodemcu-32s
wifi:
  manual_ip:
    static_ip: 192.168.9.999
    gateway: 192.168.9.1
    subnet: 255.255.255.0
  ssid: "999999999999"
  password: "9999999"
  ap:
    ssid: "Ip227 Fallback Hotspot"
    password: "99999999"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "999999"
ota:
  password: "99999"
  - platform: dht
    pin: 21
    temperature:
    model: DHT11
