Help with Zigbee devices
Good day,
After two days of googling, searching and trying a whole host of things I have ran out of options and only ended up with more problems. Currently I am trying to get 8 Sonoff SNZB-02D working in home assistant. To help with range I got 5 Ikea Trekakt in my house. Prior to getting those, I also tried placing the Raspberry Pi module with Sonoff Zigbee Dongle plus in various locations. Sadly a lot of extra problems showed up after Home Assistant went down.
Currently I am running into the following issues:
  • some devices(sonoff SNZB-02D’s) seem to not want to sync with home assistant after initial pairing. Sometimes pushing the button to go in pairing mode send the temperature and moisture content again but it also sometimes leads to the device becoming entirely disconnected requiring repairing and deletion. For some it has worked before but that is prior to me moving the raspberry pi, also prior to moving the raspberry pi, I did not have the IKEA Tretakts
  • One device(sonoff SNZB-02D’s) simply refuses to configure again and seems to be stuck in configuring when pairing.
As for details on the installation:
  • Raspberry pi 5
  • Sonoff zigbee 3.0 dongle plus
  • Installed since monday, has HACS, localTuya, file editor, advanced SSH
  • Not external facing
  • Did try to get Zigbee2MQTT working but wasn’t very successful so uninstalled it. This was after any of the previous mentioned problems started.
Any advice or help is welcome!
Hi, welcome to the forums. Read this thread, it contains a lot of good advice.
Don’t use ZHA integration until it’s stable enough and less buggy, experiences comes after I tried it for 2 months. Z2M is much more stable.
