Help with zone cleaning parameters - Xiaomi vacuum
Hello sir! How are you?
Yes, this is a very common problem with this project. Maps gets rotated, mirrored out of the blue.
I’ve been problem-free for months now. My solution was to create a scripts that starts a full cleanup, waits a few seconds and send the vacuum home. This recreates a brand new map and stores it on the current map memory.
You will only see the current location mapped, so you will need to take him for a spin using the manual mode controls on the Xiaomi app so you can take it to every room and map all of it. After this procedure is done, return home and you will have a base map that will not change until if you don’t change the docking station location. If the map is messed up again, just return home and run the recreate map script again.
Now you can use the FloleVac app and get all zones coordinates with the new and correct map generated. Add them to your HA project and test it.
Don’t worry if the map gets messed up, just recreate the map and the coordinates will work just like before, since your docking station is on the same position (ZERO, ZERO coordinate) the vacuum will know were to go.
Here are my configs on a single package file:
    sensors:
      xiaomi_battery_level:
        entity_id: vacuum.aspirador
        friendly_name: 'Bateria do aspirador'
        value_template: '{{ states.vacuum.aspirador.attributes.battery_level | float | int }}'
        unit_of_measurement: '%'
        device_class: battery
switch:
    switches:
      aspirador:
        friendly_name: "Aspirador"
        value_template: "{% if is_state('vacuum.aspirador', 'cleaning') %}on{% else %}off{% endif %}"
        turn_on:
          service: input_select.select_option
          entity_id: input_select.zonas_de_aspiracao
          data_template:
            option: "Casa toda"
        turn_off:
          service: vacuum.return_to_base
        icon_template: mdi:robot-vacuum
input_select:
  estados_de_succao:
    name: 'Tipo de aspiração'
    initial: Balanceado
    options:
      - Silencioso
      - Balanceado
      - Turbo
      - Turbo máximo
      - Pano úmido
  zonas_de_aspiracao:
    name: Qual a zona a aspirar?
    options:
      - Escolher zona
      - Casa toda
      - Sala inteira
      - Tapete
      - Mesa de jantar
      - Entrada
      - Cozinha
      - Banheiro social
      - Banheiro da suíte
      - Quarto
      - Suite
      - Suíte mais banheiro
      - Quartos e banheiros
      - Somente piso
automation:
#Coloca o aspirador em modo silencioso
  - alias: Aspirador - Modo de aspiração
      platform: state
      entity_id: input_select.estados_de_succao
      - service_template: >
          {% if trigger.to_state.state == 'Silencioso' %}
            script.aspirador_set_quiet
          {% elif trigger.to_state.state == 'Balanceado' %}
            script.aspirador_set_balanced
          {% elif trigger.to_state.state == 'Turbo' %}
            script.aspirador_set_turbo
          {% elif trigger.to_state.state == 'Turbo máximo' %}
            script.aspirador_set_max
          {% elif trigger.to_state.state == 'Pano úmido' %}
            script.aspirador_set_mop
#Escolher a zona a aspirar
  - alias: Aspirador - Escolher a zona para aspirar
    hide_entity: True
      platform: state
          {% if states.input_select.zonas_de_aspiracao.state == "Casa toda" %}
            script.aspirador_zona_casa_toda
          {% elif states.input_select.zonas_de_aspiracao.state == "Sala inteira" %}
            script.aspirador_zona_sala_inteira
          {% elif states.input_select.zonas_de_aspiracao.state == "Tapete" %}
            script.aspirador_zona_tapete
          {% elif states.input_select.zonas_de_aspiracao.state == "Mesa de jantar" %}
            script.aspirador_zona_mesa_jantar
          {% elif states.input_select.zonas_de_aspiracao.state == "Entrada" %}
            script.aspirador_zona_entrada
          {% elif states.input_select.zonas_de_aspiracao.state == "Cozinha" %}
            script.aspirador_zona_cozinha
          {% elif states.input_select.zonas_de_aspiracao.state == "Banheiro social" %}
            script.aspirador_zona_banheiro_social
          {% elif states.input_select.zonas_de_aspiracao.state == "Banheiro da suíte" %}
            script.aspirador_zona_banheiro_suite
          {% elif states.input_select.zonas_de_aspiracao.state == "Quarto" %}
            script.aspirador_zona_quarto
          {% elif states.input_select.zonas_de_aspiracao.state == "Suite" %}
            script.aspirador_zona_suite
          {% elif states.input_select.zonas_de_aspiracao.state == "Suíte mais banheiro" %}
            script.aspirador_zona_suite_e_banheiro
          {% elif states.input_select.zonas_de_aspiracao.state == "Quartos e banheiros" %}
            script.aspirador_zona_quartos_e_banheiros
          {% elif states.input_select.zonas_de_aspiracao.state == "Somente piso" %}
            script.aspirador_zona_mop
      - delay: 00:01:00
      - wait_template: "{{is_state('vacuum.aspirador', 'docked')}}"
      - delay: 00:00:15
      - service: input_select.select_option
        data_template:
          option: "Escolher zona"
        data_template:
          option: "Turbo"
  - alias: Aspirador - Avisar quando terminar
    initial_state: True
      - platform: state
        to: 'paused'
        for:
          hours: 0
          minutes: 0
          seconds: 30
      - platform: state
        to: 'docked'
      - platform: state
        to: 'error'
          {% if trigger.to_state.state == 'paused' %}
            script.aspirador_alerta_parado
          {% elif trigger.to_state.state == 'docked' %}
            script.aspirador_alerta_carregando
          {% elif trigger.to_state.state == 'error' %}
            script.aspirador_alerta_erro
script:
  aspirador_set_quiet:
      service: vacuum.set_fan_speed
        fan_speed: Quiet
  aspirador_set_balanced:
        fan_speed: Balanced
  aspirador_set_turbo:
        fan_speed: Turbo
  aspirador_set_max:
        fan_speed: Max
  aspirador_set_mop:
        fan_speed: 105
# Zonas
  aspirador_zona_casa_toda:
    - service: vacuum.send_command
        command: app_zoned_clean
        params: [[17327,20045,27427,32995,1]]
    - service: script.aspirador_alerta_iniciando
  aspirador_zona_sala_inteira:
        params: [[23745,21949,25745,31299,1],[22491,25343,23741,27643,1]]
  aspirador_zona_tapete:
        params: [[23804,23551,25004,25301,2]]
  aspirador_zona_mesa_jantar:
        params: [[23573,26400,25823,28850,1]]
  aspirador_zona_entrada:
        params: [[23620,28957,24920,31307,1]]
  aspirador_zona_cozinha:
        params: [[18839,29577,23689,31177,1]]
  aspirador_zona_banheiro_social:
        option: Turbo
        params: [[18885,25636,21185,26786,1]]
  aspirador_zona_banheiro_suite:
        option: Turbo
        params: [[18815,24240,21115,25390,1]]
  aspirador_zona_quarto:
        params: [[18484,27011,21984,29461,1]]
  aspirador_zona_suite:
        params: [[18931,21286,22581,23936,1],[21250,23964,22100,25464,1]]
  aspirador_zona_suite_e_banheiro:
        params: [[18897,21234,22497,25434,1]]
  aspirador_zona_quartos_e_banheiros:
        params: [[18554,21238,22454,29338,1]]
  aspirador_zona_mop:
        option: Pano úmido
        params: [[18554,21238,22454,29338,1],[22528,25448,25878,27598,1],[25164,22181,25814,25431,1],[18854,29557,24854,31407,1],[23607,27587,25857,29537,1]]
  aspirador_voltar_dock:
    alias: Aspirador casa - Parar e voltar
    - service: vacuum.return_to_dock
# Alertas
  aspirador_alerta_iniciando:
    alias: Aspirador casa - Iniciando
    - service: notify.TUDO
      data_template:
        title: "Alerta Casa"
        message: "O aspirador iniciou a limpeza na zona: {{ states.input_select.zonas_de_aspiracao.state | lower }}."
    - service: persistent_notification.create
        title: "Alerta Casa ({{now().strftime('%H:%M')}})"
        message: "O aspirador iniciou a limpeza na zona: {{ states.input_select.zonas_de_aspiracao.state | lower }}"
    - condition: state
      entity_id: input_boolean.boa_noite
      state: 'off'
    - service: media_player.volume_set
      entity_id: media_player.sala, media_player.suite
        volume_level: 0.7
    - service: tts.amazon_polly_say
      data_template:
        message: <speak><amazon:auto-breaths frequency='medium'>E lá vai ele... Iniciando a limpeza na zona {{ states.input_select.zonas_de_aspiracao.state | lower }}.</amazon:auto-breaths></speak>
  aspirador_alerta_parado:
    alias: Aspirador casa - Parado
      data_template:
        message: "O aspirador parou. Estava limpando a zona: {{ states.input_select.zonas_de_aspiracao.state | lower }}. {% if 'error' in states.vacuum.aspirador.state %}Código de erro: {{ states.vacuum.aspirador.attributes.error }}.{% else %}{% endif %}"
    - condition: state
      state: 'off'
        volume_level: 0.7
      data_template:
        message: <speak><amazon:auto-breaths frequency='medium'>O aspirador parou limpando a zona {{ states.input_select.zonas_de_aspiracao.state | lower }}. {% if 'error' in states.vacuum.aspirador.state %}Código de erro é {{ states.vacuum.aspirador.attributes.error }}.{% else %}{% endif %}</amazon:auto-breaths></speak>
  aspirador_alerta_carregando:
    alias: Aspirador casa - Voltou para casa
    - condition: template
      value_template: "{% if is_state('input_select.zonas_de_aspiracao', 'Escolher zona') %}False{% else %}True{% endif %}"
      data_template:
        message: "O aspirador terminou seu trabalho na zona {{ states.input_select.zonas_de_aspiracao.state | lower }}. Limpou cerca de {{ states.vacuum.aspirador.attributes.cleaned_area }} metros quadrados durante {{ states.vacuum.aspirador.attributes.cleaning_time }} minutos e está carregando no momento."
    - condition: state
      state: 'off'
        volume_level: 0.7
      data_template:
        message: <speak><amazon:auto-breaths frequency='medium'>Olha quem está de volta! O aspirador terminou seu trabalho na zona {{ states.input_select.zonas_de_aspiracao.state | lower }}. Limpou cerca de {{ states.vacuum.aspirador.attributes.cleaned_area }} metros quadrados durante {{ states.vacuum.aspirador.attributes.cleaning_time }} minutos e está carregando no momento.</amazon:auto-breaths></speak>
  aspirador_alerta_erro:
    alias: Aspirador casa - Erro
      data_template:
        message: "O aspirador está parado e acusou erro limpando a zona {{ states.input_select.zonas_de_aspiracao.state | lower }}."
    - condition: state
      state: 'off'
        volume_level: 0.7
        media_content_id: 'https://DDNS/local/audio/tts/alerta_aspirador_parado_erro.mp3'
        media_content_type: 'audio/mp3'
# HomeKit scripts
  aspirador_homekit_zona_toda_casa:
    alias: Aspirador casa - Aspirar zona casa toda
      data_template:
        option: "Casa toda"
    - delay: 00:00:10
  aspirador_homekit_zona_sala:
    alias: Aspirador casa - Aspirar zona sala inteira
      data_template:
        option: "Sala inteira"
    - delay: 00:00:10
  aspirador_homekit_zona_mesa_jantar:
    alias: Aspirador casa - Aspirar zona mesa de jantar
      data_template:
        option: "Mesa de jantar"
    - delay: 00:00:10
  aspirador_homekit_zona_tapete:
    alias: Aspirador casa - Aspirar zona tapete
      data_template:
        option: "Tapete"
    - delay: 00:00:10
  aspirador_homekit_zona_entrada:
    alias: Aspirador casa - Aspirar zona entrada
      data_template:
        option: "Entrada"
    - delay: 00:00:10
  aspirador_homekit_zona_cozinha:
    alias: Aspirador casa - Aspirar zona cozinha
      data_template:
        option: "Cozinha"
    - delay: 00:00:10
  aspirador_homekit_zona_quartos:
    alias: Aspirador casa - Aspirar zona quartos e banheiros
      data_template:
        option: "Quartos e banheiros"
    - delay: 00:00:10
  aspirador_homekit_zona_mop:
    alias: Aspirador casa - Aspirar zona somente piso
      data_template:
        option: "Somente piso"
    - delay: 00:00:10
# Outros
  aspirador_recriar_mapa:
    alias: Aspirador casa - Recriar mapa
    - service: vacuum.start
    - delay: 00:00:08
    - service: vacuum.stop
    - delay: 00:00:02
    - service: vacuum.return_to_base
# Customize
homeassistant:
  customize:
    switch.aspirador:
      icon: mdi:robot-vacuum
    input_select.estados_de_succao:
      icon: mdi:speedometer
    input_select.zonas_de_aspiracao:
      icon: mdi:map-marker
    input_number.aspirador_passadas:
      icon: mdi:shuffle-disabled
    script.aspirador_recriar_mapa:
      icon: mdi:home-map-marker
This is my current UI:
Here is the lovelace config:
- type: entities
  title: Aspirador
  show_header_toggle: false
  entities:
    - entity: vacuum.aspirador
      secondary_info: last-changed
    - sensor.xiaomi_battery_level
    - entity: script.aspirador_recriar_mapa
    - input_select.estados_de_succao
    - input_select.zonas_de_aspiracao
    - type: custom:entity-attributes-card
      heading_name: Status
      heading_state: Valor
      filter:
        include:
          - key: vacuum.aspirador.cleaning_time
            name: Tempo limpando (último)
            unit: minutos
          - key: vacuum.aspirador.cleaned_area
            name: Área limpa (último)
            unit: metros
          - key: vacuum.aspirador.main_brush_left
            name: Escova principal
            unit: horas
          - key: vacuum.aspirador.side_brush_left
            unit: horas
          - key: vacuum.aspirador.filter_left
            unit: horas
          - key: vacuum.aspirador.sensor_dirty_left
            unit: horas
It has been months now without any problems with zone cleaning. If I need to clean it up by removing the vacuum manually from the dock, I just need to recreate the map using the script and all works just fine.
And yes, some of these scripts has more than one zone on the same command, works just fine.
Sorry that everything is in portuguese, I hope you can understand the main idea here.
Hope it helps!
Try with this:
'{{ ("[[30914,26007,35514,28807" + "," + (states("input_number.vacuum_passes") | int | string + "]]") )}}'
  vacuum_cucina:
        entity_id: vacuum.xiaomi_vacuum
        params: '{{ ("[[30914,26007,35514,28807" + "," + (states("input_number.vacuum_passes") | int | string + "]]") )}}'
    - service: script.vacuum_alert_start
Hi @Schneider,
thanks again for your great post, it helped me a lot.
I was trying to test your notify part (notify tudo). It wasn’t on your code posted.
Could you kindly share with me ?
Many thanks !
And ,do you know if it’s possible to activate the carpet mode? Or it’s activated by default ?
Hello sir! I am glad I could help you!
No worries. This notify part is a “notify group” that I’ve created to send a message to a few devices (all mobile phones, Google Home Minis, TVs, and so on), you can set they way you want to be notified with your setup.
The carpet mode is activated automatically but I suggest you set the vacuum power to max anyways if you had created a zone that contains only your carpet.
Another great tip is that fan_speed 105 sets the vacuum in to MOP mode, you can check on your mobile app that the mopping mode is selected.
Let me know if you need anything else.
Good luck!
Hi Schneider! Good news I found a valetudo branch with clickable zoned cleaning .I compiled this piece of software and will test and report … then it should be possible to select zoned cleaning within a map . But u need complete map before which includes full clean and don’t carry your robot around :wink: I’ll report tomorrow if it works well
Amazing stuff mate! Good luck!
Tested the new feature.it seems to work but still in beta.as soon as there was a cleanup of the code and integration in valetudo I’ll make a post here
Hi, I’m right, that you’re all using Valetudo?
For me the zoned cleaning via hass.io isn’t working at all. I have the following script for example:
vacuum_wohnzimmer:
    alias: Wohnzimmer saugen
          entity_id: vacuum.roborock
          params: [22250,27500,29400,25000,1]
When I run it the vacuum says “starting zone cleaner”, boosts up, than without driving says “finished zone cleaning going back to dock.”
If I’m using Valetudos new Zone Website it works perfectly…
Does anybody has an idea?
Btw: Goto works great.
vacuumgoto:
    alias: Vacuum go to
          command: app_goto_target
          params: [29300, 27300]
Found my issues…
params have to be
params: [[22250,27500,29400,25000,1]]
and on my other script i typed
data_template:
Which has to be “data”. If one of this typos are in the script the roborock seems to start cleaning, but the values aren’t right, so it cancels then.
I submit a pull request with a new service xiaomi_clean_zone_start
Download this file xiaomi_miio.py and put it in /custom_components/vacuum until my pull request will be approved.
Example of use with automation:
- id: '1546608481220'
  alias: Test vacuum zone
  - event: start
    platform: homeassistant
  condition: []
  - data:
      reps: 3
      zone: [[23510,25311,25110,26361]]
    service: vacuum.xiaomi_clean_zone_start
Here my github pull request: https://github.com/home-assistant/home-assistant/pull/19777
Is this working for you? Just seen, that you tried to set the value using a template, which I’m trying to do with my vacuum since 2 days for setting the volume.
When I’m inserting my input_number into your script like this:
    data_template:
      command: change_sound_volume
      params: '{{ ("[" + (states("input_number.vacuum_volume") | int | string + "]") )}}'
Still nothing happens. Currently my guess is, that the „vacuum.send_command“ doesn’t support data_template, as not even „params: [10]“ or similar is working is working then…
Thank’s for your job! Works like a charm!
PS. For those who will use this component
warning: do not confuse date: and data_template:
If you use variables you must always put data: as examples here: https://github.com/home-assistant/home-assistant/pull/19777
Does this allow you to resume a zoned cleanup? If it gets stuck, errors, or paused?
I never tried It…
Is your PR with xiaomi_clean_zone_start also supporting zones as templates?
Currently I had to create 8 scripts to clean every single room. Adding input_booleans for each of them and then run a script mentioned in the “Howto: Xiaomi vacuum zoned cleaning” to run the scripts that are having activated input_booleans.
If the xiaomi_clean_zone_start supports also zones as templates I could include them as a list when calling the cleaning script and and short my scripts by 1/8.
Greets
No… in this moment you can only use repeats as template.
Okay, would it be possible by home assistant design to use templates in zone, too?
after PR is approved, I will work on it
I have now used a version update in the next code to send the robot to a certain area. Since last update (0.86.3) this code has not been working. Is there an alternative to this?
script:
  vacuum_all_home:
      alias: "Vacuum All The House Space"
            entity_id: vacuum.xiaomi_vacuum_cleaner
            params: [[23341,19451,32741,30201,1]] ## כל הבית ##
  vacuum_bedroom:
        alias: "Vacuum Corridor"
              params: [[28489,22014,30139,26214,1]] ## פרוזדור ##
  vacuum_dining_room:
        alias: "Vacuum Dining Room"
              params: [[26253,21948,28503,25948,1]] ## פינת אוכל #
  vacuum_kitchen:
        alias: "Vacuum Kitchen"
              params: [[26115,19477,28315,22027,1]] ## מטבח ##
  vacuum_living_room:
        alias: "Vacuum Living Room"
              params: [[23327,21890,26077,26040,1]] ## סלון ##
  vacuum_guestroom:
        alias: "Vacuum Dogs area"
              params: [[28624,25960,31574,30260,1]] ## אזור הכלבים
I think the service app_goto_target not need a zone but is still necessary a point (x,y)
