Xiaomi Mijia 1C Sweeping Vacuum Cleaner (white) (STYTJ01ZHM)
i managed to get it to work using call service from developer tools… but when i put it in script, it gives an error. what am i doing it wrong?
edit: nvm, i missed “data” after the entity_id
Now I’m trying to get it set up to clean zones using a drop down list with data_template. But I’m not having any luck “extra keys not allowed @ data[‘data_template’]” . Code below using the Dev Call service function (missing indents when posted here)
Backup plan is to use a script instead.
entity_id: vacuum.xoomba
data_template:
zone: >
{% if is_state('input_select.vacuum_areas', 'Entrance') %}
'-1183,1457,865,3624'
{%-elif is_state('input_select.vacuum_area', 'Kitchen') %}
'-3518,11265,-689,12830'
none
repeats: 1’
I also tried the below but nothing happens:
zone: >
none
repeats: 1
Does zone clean require multiple coordinates?
Currently you can only add 1
If I use this code by itself it works. I’m just trying to clean zones using a drop down selection & automation trigger.
zone: '-1183,1457,865,3624'
repeats: 1
your code looks good…but can you check, i saw there is minus sign before your elif…probably that s why it doesnt work?
u wrote {%-elif instead of {% elif
The - isn’t it. I used the same format in another automation which works.
I don’t quite understand why it doesn’t work, but I’ve started using the script method anyway.
Inspired by this thread.
After all the feedback, i have merged the branch so those using hacs should automatically get the zone-cleaning now.
Thanks heaps @concentric. I’ve also now got it set up so I select my desired zone from a dropdown and fire the script to clean that area. Exactly what I was hoping for when I bought this vacuum. Next on my list - testing to see if I can run the vacuum only on local wifi (without talking to the xiaomi servers).
I tried that, on a local only vlan.
The vacuum kept disconnecting from the wifi and made for terrible communication with home assistant.
Maybe with some packet sniffing you could check what it is trying to ping?
Perhaps. I’ll have a play with it tomorrow and share what I find.
what went wrong before that u managed to fix?
I have managed to more or less work with “Lovelace Xiaomi Vacuum Map Card”.
My humble little contribution, I am not an expert, sorry if there is any outrage. These are the modifications of the xiaomi-vacuum-map-card.js file. “Go to Target” does not work.
import CoordinatesConverter from './coordinates-converter.js';
import style from './style.js';
import {
    mode,
    goToTarget,
    zonedCleanup,
    zones,
    run,
    repeats,
    confirmation,
    texts
} from './texts.js'
const LitElement = Object.getPrototypeOf(
    customElements.get("ha-panel-lovelace")
const html = LitElement.prototype.html;
if (typeof loadCardHelpers !== "undefined") {
    loadCardHelpers().then(helpers => {
        if (typeof helpers.importMoreInfoControl !== "undefined") {
            helpers.importMoreInfoControl("light");
class XiaomiVacuumMapCard extends LitElement {
    constructor() {
        super();
        this.isMouseDown = false;
        this.rectangles = [];
        this.selectedRectangle = -1;
        this.selectedZones = [];
        this.currRectangle = {x: null, y: null, w: null, h: null};
        this.imageScale = -1;
        this.mode = 0;
        this.vacuumZonedCleanupRepeats = 1;
        this.currPoint = {x: null, y: null};
        this.outdatedConfig = false;
    static get properties() {
        return {
            _hass: {},
            _config: {},
            isMouseDown: {},
            rectangles: {},
            selectedRectangle: {},
            selectedZones: {},
            currRectangle: {},
            mode: {},
            vacuumZonedCleanupRepeats: {},
            currPoint: {},
            mapDrawing: {},
    set hass(hass) {
        this._hass = hass;
        if (this._config && !this.map_image) {
            this.updateCameraImage();
    setConfig(config) {
        const availableModes = new Map();
        this._language = config.language || "en";
        availableModes.set("go_to_target", texts[this._language][goToTarget]);
        availableModes.set("zoned_cleanup", texts[this._language][zonedCleanup]);
        availableModes.set("predefined_zones", texts[this._language][zones]);
        if (!config.entity) {
            throw new Error("Missing configuration: entity");
        if (!config.map_image && !config.map_camera) {
            throw new Error("Missing configuration: map_image or map_camera");
        if (config.map_image && config.map_camera) {
            throw new Error("Only one of following properties is allowed: map_image or map_camera");
        if (config.base_position || config.reference_point) {
            this.outdatedConfig = true;
            this._config = config;
            return;
        if (!config.calibration_points || !Array.isArray(config.calibration_points)) {
            throw new Error("Missing configuration: calibration_points");
        if (config.calibration_points.length !== 3) {
            throw new Error("Exactly 3 calibration_points required");
        for (const calibration_point of config.calibration_points) {
            if (calibration_point.map === null) {
                throw new Error("Missing configuration: calibration_points.map");
            if (calibration_point.map.x === null) {
                throw new Error("Missing configuration: calibration_points.map.x");
            if (calibration_point.map.y === null) {
                throw new Error("Missing configuration: calibration_points.map.y");
            if (calibration_point.vacuum === null) {
                throw new Error("Missing configuration: calibration_points.vacuum");
            if (calibration_point.vacuum.x === null) {
                throw new Error("Missing configuration: calibration_points.vacuum.x");
            if (calibration_point.vacuum.y === null) {
                throw new Error("Missing configuration: calibration_points.vacuum.y");
        const p1 = this.getCalibrationPoint(config, 0);
        const p2 = this.getCalibrationPoint(config, 1);
        const p3 = this.getCalibrationPoint(config, 2);
        this.coordinatesConverter = new CoordinatesConverter(p1, p2, p3);
        if (config.modes) {
            if (!Array.isArray(config.modes) || config.modes.length < 1 || config.modes.length > 3) {
                throw new Error("Invalid configuration: modes");
            this.modes = [];
            for (const mode of config.modes) {
                if (!availableModes.has(mode)) {
                    throw new Error("Invalid mode: " + mode);
                this.modes.push(availableModes.get(mode));
        } else {
            this.modes = [
                texts[this._language][goToTarget],
                texts[this._language][zonedCleanup],
        if (!config.zones || !Array.isArray(config.zones) || config.zones.length === 0 && this.modes.includes(texts[this._language][zones])) {
            this.modes.splice(this.modes.indexOf(texts[this._language][zones]), 1);
        if (config.default_mode) {
            if (!availableModes.has(config.default_mode) || !this.modes.includes(availableModes.get(config.default_mode))) {
                throw new Error("Invalid default mode: " + config.default_mode);
            this.defaultMode = this.modes.indexOf(availableModes.get(config.default_mode));
        } else {
            this.defaultMode = -1;
        //if (config.service && config.service.split(".").length === 2) {
        //    this.service_domain = config.service.split(".")[0];
        //    this.service_method = config.service.split(".")[1];
        //} else {
            //this.service_domain = "vacuum";
            //this.service_method = "send_command";
            this.service_domain = "xiaomi_vacuum";
            this.service_method = "vacuum_clean_zone";
        if (config.map_image) {
            this.map_image = config.map_image;
        this._map_refresh_interval = (config.camera_refresh_interval || 5) * 1000;
    getConfigurationMigration(config) {
        const diffX = config.reference_point.x - config.base_position.x;
        const diffY = config.reference_point.y - config.base_position.y;
        const shouldSwapAxis = diffX * diffY > 0;
        let unit = shouldSwapAxis ? diffX : diffY;
        if (shouldSwapAxis) {
            const temp = config.base_position.x;
            config.base_position.x = config.base_position.y;
            config.base_position.y = temp;
        const canvasX = config.base_position.x;
        const canvasY = unit + config.base_position.y;
        let x = Math.round(canvasX);
        let y = Math.round(canvasY);
            x = Math.round(canvasY);
            y = Math.round(canvasX);
        return html`
<ha-card id="xiaomiCard" style="padding: 16px">
<div class="card-header" style="padding: 8px 0 16px 0;"><div class="name">Xiaomi Vacuum Map card</div></div>
<h3>Your configuration is outdated</h3>
<p>Migrate it using following calibration settings:</p>
<pre><textarea style="width: 100%; height: 22em">calibration_points:
  - vacuum:
      x: 25500
      y: 25500
    map:
      x: ${config.base_position.x}
      y: ${config.base_position.y}
  - vacuum:
      x: 26500
      y: 26500
    map:
      x: ${config.reference_point.x}
      y: ${config.reference_point.y}
  - vacuum:
      x: 25500
      y: 26500
    map:
      x: ${x}
      y: ${y}</textarea></pre>
</ha-card>`
    getCalibrationPoint(config, index) {
        return {
            a: {
                x: config.calibration_points[index].map.x,
                y: config.calibration_points[index].map.y
            b: {
                x: config.calibration_points[index].vacuum.x,
                y: config.calibration_points[index].vacuum.y
    render() {
        if (this.outdatedConfig) {
            return this.getConfigurationMigration(this._config);
        const modesDropdown = this.modes.map(m => html`<paper-item>${m}</paper-item>`);
        const rendered = html`
        ${style}
        <ha-card id="xiaomiCard">
            <div id="mapWrapper">
                <div id="map">
                    <img id="mapBackground" @load="${() => this.calculateScale()}" src="${this.map_image}">
                    <canvas id="mapDrawing" style="${this.getCanvasStyle()}"
                        @mousemove="${e => this.onMouseMove(e)}"
                        @mousedown="${e => this.onMouseDown(e)}"
                        @mouseup="${e => this.onMouseUp(e)}"
                        @touchstart="${e => this.onTouchStart(e)}"
                        @touchend="${e => this.onTouchEnd(e)}"
                        @touchmove="${e => this.onTouchMove(e)}" />
                </div>
            </div>
            <div class="dropdownWrapper">
                <paper-dropdown-menu label="${texts[this._language][mode]}" @value-changed="${e => this.modeSelected(e)}" class="vacuumDropdown" selected="${this.defaultMode}">
                    <paper-listbox slot="dropdown-content" class="dropdown-content" selected="${this.defaultMode}">
                        ${modesDropdown}
                    </paper-listbox>
                </paper-dropdown-menu>
            </div>
            <p class="buttonsWrapper">
                <span id="increaseButton" hidden><mwc-button @click="${() => this.vacuumZonedIncreaseButton()}">${texts[this._language][repeats]} ${this.vacuumZonedCleanupRepeats}</mwc-button></span>
                <mwc-button class="vacuumRunButton" @click="${() => this.vacuumStartButton(true)}">${texts[this._language][run]}</mwc-button>
            </p>
            <div id="toast"><div id="img"><ha-icon icon="mdi:check" style="vertical-align: center"></ha-icon></div><div id="desc">${texts[this._language][confirmation]}</div></div>
        </ha-card>
        if (this.getMapImage()) {
            this.calculateScale();
        return rendered;
    calculateScale() {
        const img = this.getMapImage();
        const canvas = this.getCanvas();
        this.imageScale = img.width / img.naturalWidth;
        const mapHeight = Math.round(this.imageScale * img.naturalHeight);
        img.parentElement.parentElement.style.height = mapHeight + "px";
        canvas.width = img.width;
        canvas.height = mapHeight;
        this.drawCanvas();
    onMouseDown(e) {
        const pos = this.getMousePos(e);
        this.isMouseDown = true;
        if (this.mode === 1) {
            this.currPoint.x = pos.x;
            this.currPoint.y = pos.y;
        } else if (this.mode === 2) {
            const {selected, shouldDelete, shouldResize} = this.getSelectedRectangle(pos.x, pos.y);
            this.currRectangle.x = pos.x;
            this.currRectangle.y = pos.y;
            if (shouldDelete) {
                this.rectangles.splice(selected, 1);
                this.drawCanvas();
                return;
            if (shouldResize) {
                this.currRectangle.x = this.rectangles[selected].x;
                this.currRectangle.y = this.rectangles[selected].y;
                this.drawCanvas();
                return;
            this.selectedRectangle = selected;
            if (this.selectedRectangle >= 0) {
                this.currRectangle.w = this.rectangles[this.selectedRectangle].x;
                this.currRectangle.h = this.rectangles[this.selectedRectangle].y;
            } else {
                this.currRectangle.w = 0;
                this.currRectangle.h = 0;
        } else if (this.mode === 3) {
            const selectedZone = this.getSelectedZone(pos.x, pos.y);
            if (selectedZone >= 0) {
                if (this.selectedZones.includes(selectedZone)) {
                    this.selectedZones.splice(this.selectedZones.indexOf(selectedZone), 1);
                } else {
                    if (this.selectedZones.length < 5 || this._config.ignore_zones_limit) {
                        this.selectedZones.push(selectedZone);
        this.drawCanvas();
    onMouseUp(e) {
        if (this.selectedRectangle >= 0 || this.mode !== 2 || this.mode === 2 && this.rectangles.length >= 5 && !this._config.ignore_zones_limit) {
            this.drawCanvas();
            return;
        const {x, y} = this.getMousePos(e);
        const rx = Math.min(x, this.currRectangle.x);
        const ry = Math.min(y, this.currRectangle.y);
        const rw = Math.max(x, this.currRectangle.x) - rx;
        const rh = Math.max(y, this.currRectangle.y) - ry;
        this.currRectangle.x = rx;
        this.currRectangle.y = ry;
        this.currRectangle.w = rw;
        this.currRectangle.h = rh;
        if (rw > 5 && rh > 5) {
            this.rectangles.push({x: rx, y: ry, w: rw, h: rh});
        this.drawCanvas();
    onMouseMove(e) {
        if (this.isMouseDown && this.mode === 2) {
            if (this.selectedRectangle < 0) {
                this.currRectangle.w = x - this.currRectangle.x;
                this.currRectangle.h = y - this.currRectangle.y;
            } else {
                this.rectangles[this.selectedRectangle].x = this.currRectangle.w + x - this.currRectangle.x;
                this.rectangles[this.selectedRectangle].y = this.currRectangle.h + y - this.currRectangle.y;
            this.drawCanvas();
    onTouchStart(e) {
            this.onMouseDown(this.convertTouchToMouse(e));
    onTouchEnd(e) {
            this.onMouseUp(this.convertTouchToMouse(e));
    onTouchMove(e) {
            this.onMouseMove(this.convertTouchToMouse(e));
    modeSelected(e) {
        const selected = e.detail.value;
        this.mode = 0;
        if (selected === texts[this._language][goToTarget]) {
            this.mode = 1;
        } else if (selected === texts[this._language][zonedCleanup]) {
            this.mode = 2;
        } else if (selected === texts[this._language][zones]) {
            this.mode = 3;
        this.getPredefinedZonesIncreaseButton().hidden = this.mode !== 3 && this.mode !== 2;
        this.drawCanvas();
    vacuumZonedIncreaseButton() {
        this.vacuumZonedCleanupRepeats++;
        if (this.vacuumZonedCleanupRepeats > 3) {
    vacuumStartButton(debug) {
        if (this.mode === 1 && this.currPoint.x != null) {
            this.vacuumGoToPoint(debug);
        } else if (this.mode === 2 && !this.rectangles.empty) {
            this.vacuumStartZonedCleanup(debug);
        } else if (this.mode === 3 && !this.selectedZones.empty) {
            this.vacuumStartPreselectedZonesCleanup(debug);
    drawCanvas() {
        const context = canvas.getContext("2d");
        context.clearRect(0, 0, canvas.width, canvas.height);
        context.translate(0.5, 0.5);
        if (this._config.debug) {
            for (const calibration_point of this._config.calibration_points) {
                const {x, y} = this.convertVacuumToMapCoordinates(calibration_point.vacuum.x, calibration_point.vacuum.y);
                this.drawCircle(context, x, y, 4, 'red', 1);
            this.drawCircle(context, this.currPoint.x, this.currPoint.y, 4, 'yellow', 1);
            for (let i = 0; i < this.rectangles.length; i++) {
                const rect = this.rectangles[i];
                context.beginPath();
                if (i === this.selectedRectangle) {
                    context.setLineDash([10, 5]);
                    context.strokeStyle = 'white';
                } else {
                    context.setLineDash([]);
                    context.fillStyle = 'rgba(255, 255, 255, 0.25)';
                    context.fillRect(rect.x, rect.y, rect.w, rect.h);
                context.rect(rect.x, rect.y, rect.w, rect.h);
                context.lineWidth = 1;
                context.stroke();
                this.drawDelete(context, rect.x + rect.w, rect.y);
                this.drawResize(context, rect.x + rect.w, rect.y + rect.h);
            if (this.isMouseDown && this.selectedRectangle < 0) {
                context.rect(this.currRectangle.x, this.currRectangle.y, this.currRectangle.w, this.currRectangle.h);
                context.stroke();
            for (let i = 0; i < this._config.zones.length; i++) {
                const zone = this._config.zones[i];
                for (const rect of zone) {
                    const {x, y, w, h} = this.convertVacuumToMapZone(rect[0], rect[1], rect[2], rect[3]);
                    if (!this.selectedZones.includes(i)) {
                        context.strokeStyle = 'red';
                        context.fillStyle = 'rgba(255, 0, 0, 0.25)';
                    } else {
                        context.strokeStyle = 'green';
                        context.fillStyle = 'rgba(0, 255, 0, 0.25)';
                    context.rect(x, y, w, h);
                    context.fillRect(x, y, w, h);
                    context.stroke();
        context.translate(-0.5, -0.5);
    drawCircle(context, x, y, r, style, lineWidth) {
        context.arc(x, y, r, 0, Math.PI * 2);
        context.strokeStyle = style;
        context.lineWidth = lineWidth;
        context.stroke();
    drawDelete(context, x, y) {
        this.drawCircle(context, x, y, 8, 'black', 1.2);
        const diff = 4;
        context.moveTo(x - diff, y - diff);
        context.lineTo(x + diff, y + diff);
        context.moveTo(x - diff, y + diff);
        context.lineTo(x + diff, y - diff);
        context.stroke();
    drawResize(context, x, y) {
        const diff = 4;
        context.lineTo(x + diff, y + diff - 4);
        context.lineTo(x + diff - 4, y + diff);
        context.lineTo(x - diff, y - diff + 4);
        context.lineTo(x - diff + 4, y - diff);
        context.lineTo(x - diff, y - diff);
        context.stroke();
    getSelectedRectangle(x, y) {
        let selected = -1;
        let shouldDelete = false;
        let shouldResize = false;
        for (let i = this.rectangles.length - 1; i >= 0; i--) {
            if (Math.pow(x - rect.x - rect.w, 2) + Math.pow(y - rect.y, 2) <= 64) {
                selected = i;
                shouldDelete = true;
                break;
            if (Math.pow(x - rect.x - rect.w, 2) + Math.pow(y - rect.y - rect.h, 2) <= 64) {
                selected = i;
                shouldResize = true;
                break;
            if (x >= rect.x && y >= rect.y && x <= rect.x + rect.w && y <= rect.y + rect.h) {
                selected = i;
                break;
        return {selected, shouldDelete, shouldResize};
    getSelectedZone(mx, my) {
        let selected = -1;
        for (let i = 0; i < this._config.zones.length && selected === -1; i++) {
                if (mx >= x && my >= y && mx <= x + w && my <= y + h) {
                    selected = i;
                    break;
        return selected;
    getCanvasStyle() {
        if (this.mode === 2) return html`touch-action: none;`;
        else return html``;
    vacuumGoToPoint(debug) {
        const mapPos = this.convertMapToVacuumCoordinates(this.currPoint.x, this.currPoint.y);
        if (debug && this._config.debug) {
            alert(JSON.stringify([mapPos.x, mapPos.y]));
        } else {
            this._hass.callService(this.service_domain, this.service_method, {
                entity_id: this._config.entity,
                command: "app_goto_target",
                params: [mapPos.x, mapPos.y]
            }).then(() => this.showToast());
    vacuumStartZonedCleanup(debug) {
        //const zone = [];
		var zone = "";
        //alert("HOLA");
        for (const rect of this.rectangles) {
            //zone.push(this.convertMapToVacuumRect(rect, this.vacuumZonedCleanupRepeats));
			zone = zone + this.convertMapToVacuumRect(rect, this.vacuumZonedCleanupRepeats);
		//alert(JSON.stringify(zone));
        } else {
                //command: "app_zoned_clean",
                //params: zone
				zone: zone,
				repeats: this.vacuumZonedCleanupRepeats
			//alert(zone);
    vacuumStartPreselectedZonesCleanup(debug) {
        //const zone = [];
		var zone = "";
        for (let i = 0; i < this.selectedZones.length; i++) {
            const selectedZone = this.selectedZones[i];
            const preselectedZone = this._config.zones[selectedZone];
            for (const rect of preselectedZone) {
                //zone.push([rect[0], rect[1], rect[2], rect[3], this.vacuumZonedCleanupRepeats])
				zone = zone + rect[0] + "," + rect[1] + "," + rect[2] + "," + rect[3];
        } else {
                //params: zone
				zone: zone,
    getCardSize() {
        return 5;
    convertMapToVacuumRect(rect, repeats) {
        const xy1 = this.convertMapToVacuumCoordinates(rect.x, rect.y);
        const xy2 = this.convertMapToVacuumCoordinates(rect.x + rect.w, rect.y + rect.h);
        const x1 = Math.min(xy1.x, xy2.x);
        const y1 = Math.min(xy1.y, xy2.y);
        const x2 = Math.max(xy1.x, xy2.x);
        const y2 = Math.max(xy1.y, xy2.y);
        //return [x1, y1, x2, y2, repeats];
		return x1+","+ y1+","+ x2+","+ y2;
    convertMapToVacuumCoordinates(mapX, mapY) {
        const {x, y} = this.coordinatesConverter.convertAB(mapX / this.imageScale, mapY / this.imageScale);
        return {x: Math.round(x), y: Math.round(y)};
    convertVacuumToMapZone(vacuumX1, vacuumY1, vacuumX2, vacuumY2) {
        const {x: x1, y: y1} = this.convertVacuumToMapCoordinates(vacuumX1, vacuumY1);
        const {x: x2, y: y2} = this.convertVacuumToMapCoordinates(vacuumX2, vacuumY2);
        let x = Math.min(x1, x2);
        let y = Math.min(y1, y2);
        let w = Math.abs(x2 - x1);
        let h = Math.abs(y2 - y1);
        return {x, y, w, h};
    convertVacuumToMapCoordinates(vacuumX, vacuumY) {
        const {x: vX, y: vY} = this.coordinatesConverter.convertBA(vacuumX, vacuumY);
        const x = Math.round(vX * this.imageScale);
        const y = Math.round(vY * this.imageScale);
        return {x, y};
    getMapImage() {
        return this.shadowRoot.getElementById("mapBackground");
    getCanvas() {
        return this.shadowRoot.getElementById("mapDrawing");
    getPredefinedZonesIncreaseButton() {
        return this.shadowRoot.getElementById("increaseButton");
    getMousePos(evt) {
        const rect = canvas.getBoundingClientRect();
        return {
            x: Math.round(evt.clientX - rect.left),
            y: Math.round(evt.clientY - rect.top)
    convertTouchToMouse(evt) {
        if (evt.cancelable && this.mode === 2) {
            evt.preventDefault();
        return {
            clientX: evt.changedTouches[0].clientX,
            clientY: evt.changedTouches[0].clientY,
            currentTarget: evt.currentTarget
    showToast() {
        const x = this.shadowRoot.getElementById("toast");
        x.className = "show";
        setTimeout(function () {
            x.className = x.className.replace("show", "");
        }, 2000);
    updateCameraImage() {
        this._hass.callWS({
            type: 'camera_thumbnail',
            entity_id: this._config.map_camera,
        }).then(val => {
            const {content_type: contentType, content} = val;
            this.map_image = `data:${contentType};base64, ${content}`;
            this.requestUpdate();
    connectedCallback() {
        super.connectedCallback();
        if (this._config.map_camera) {
            this.thumbUpdater = setInterval(() => this.updateCameraImage(), this._map_refresh_interval);
    disconnectedCallback() {
        super.disconnectedCallback();
            clearInterval(this.thumbUpdater);
            this.map_image = null;
customElements.define('xiaomi-vacuum-map-card', XiaomiVacuumMapCard);
I think someone will be able to improve this code.
I didn’t manage to fix my template code. I read something about data_template passing strings where the vacuum needs arrays. I ended up using my plan B, which was to write a script for each zone, then calling the script using a drop down list and automation trigger.
Oooh. Watching with interest…
So I tried disconnecting the internet access for the whole house, just keeping the lan running.
Home Assistant is able to control the vac for a few seconds.
Then it refuses to listen to any commands
But after maybe 30 seconds, it responds again, then another cycle of non-responsiveness, then I sent it back to the dock.
I haven’t worked out how to sniff packets through my router yet, but I’ll look into it when I have spare time. My main interest was in zone cleaning which is working amazingly well now.
@concentric, my HA is a bit broken at the moment, I am trying to get it back up so I can test the update. Will provide feedback as soon as I have a working config…
I have the same as @altagraft
But when I use the xiaomi_vacuum.vacuum_clean_zone, I don’t get the Entity
You will have to type it
entity_id: vacuum.robin
zone: '3019,2063,7424,6105'
repeats: 1
download
Awesome!
I have my scripts working and running the automation on the dropdown menu for the zones. So far so good!
Thanks @concentric, you are legend man!
A little bit off topic. I have exposed the scripts to Google Assistant. I then functions as “Start Vacuum Kitchen” With some routines, you can change that to simply go “Hey Google, Vacuum Kitchen”
