I’ve only recently discovered helpers- neat addition.
However, in experimenting with helpers I have quite a few that are meaningless, but I cant figure out how to delete or edit/rename them.
I also have some that were created in configuration.yaml, and later deleted from configuration.yaml, but the helpers are still present. Worse, they are marked as “read only”. How do I delete those?
In Configuration / Devices and Services / Entities tab. Sort by the Status column. Also ensure you aren’t filtering the list (the triangle icon top right).
Tick the check boxes of the items you want to remove then click Remove Selected.
Thanks. Silly me thinking that I would find “delete helpers” in the helpers menu… But I hadn’t made the connection yet that a helper is an entity.
Feature suggestion: How about a “help” button where a tooltip could pop up with such tips? It amazes me how often the answer to my question is in the docs, but knowing where to look is the mystery.
Hi @stevemann, can you please mark this topic as solved?
If you mark this thread as solved by selecting the answer which gave you the solution, other members will not jump in to try to help (like I just did) AND the topic will be useful for others having a similar issue.
Same issue here: I cannot delete the input_boolean helper.
The “cog” icon in Settings > Devices & Services > Helpers shows exact same result as @kychan1121.
Environment:
Home Assistant 2023.7.3
Supervisor 2023.07.1
Operating System 10.3
Frontend 20230705.1 - latest
Principle of least surprise: I expected to be able to delete a “Helper” under the “Helper” menu.
Addendum: deleting from the “Entities” page also does not work:
Go to Entities page to attempt deleting an item created on the Helper page
Search for the helper name
Select item
“Remove Selected”
Result:
Only 0 selected entities can be removed.
You can only remove 0 of the selected 1 entities. Entities can only be removed when the integration is no longer providing the entities. Sometimes you have to restart Home Assistant before you can remove the entities of a removed integration. Are you sure you want to remove the removable entities?
I am wondering if there is a solution to ediit or delete a Schedule Helper.
In one case I want to change the schedule and in another case I want to delete a Schedule helper because I removed the related device.
When I click on remove in the Entities list I get:
