Are you looking for how many times it has been on or how long it has been on?
How long has it been on
Ah! That topic seems to be a complicated one for HA!
Iâve just spent the last 6 hours trying to wrap my head around a simple elapsed timer in HA for my car charger. It doesnât exist.
I found a Stopwatch with start/stop/resume, lap and reset solution which uses 4 input_booleans + 2 template triggers + 3 automations, 1 of which runs every second. I did not like that approach eitherâŚtoo much work plus I do not like the idea of an automation firing once every second. There is this solution using input_datetime helpers but you need automation(s) to update the datetime helpers. I moved from HomeSeer over a year ago and it has had timers for many, MANY years where you can create timers which can count UPWARDS unlike HA timers which only count DOWN from a DURATION.
So I had a look over in Node-RED and started searching there. Also somewhat void but I did mange to find a node that I have made work: the interval-length nodeâŚ
And this is the sensor it created in HA:
If youâre not into Node-RED then datetime_helpers + templates + automations seems to be the only solution.
Hope that helps!
Unfortunately you didnât help me much, I really donât know how to create this system. Thank you anyway
Ok. Did you look at Simple stopwatch?&/or Stopwatch with start/stop/resume, lap and reset?
You need two input_datetime helpers, one to store the start time and one for the stop time. Then an automation that fires when the device turns on which updates the start time helper and another automation that fires when the device turns off which updates the stop time. I combined the two automations into one with two triggers and a choose section. Last item is a template sensor whose state is ( end_time minus start_time ) if the timer is stopped, or ( now() - start_time ) if the timer is running. I threw the following together this evening. In the code below Iâm using an input_boolean that I created to trigger & test it. Just replace the input_boolean with the entity_id of the switch you want to track.
templates:
- sensor:
- name: 32A Charging Timer
unique_id: 32a_charging_timer
state: >
{% if is_state("input_boolean.32a_charging_on_off", "on") %}
{{ as_timestamp(now()) - state_attr("input_datetime.32a_charging_start", "timestamp") }}
{% else %}
{{ state_attr("input_datetime.32a_charging_end","timestamp") - state_attr("input_datetime.32a_charging_start","timestamp") }}
{% endif %}
device_class: duration
state_class: measurement
unit_of_measurement: s
Automation:
alias: 32A Charging Timer
description: ""
- platform: state
entity_id:
- input_boolean.32a_charging_on_off
to: "on"
- platform: state
entity_id:
to: "off"
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: input_datetime.set_datetime
timestamp: "{{ as_timestamp(now()) }}"
entity_id: input_datetime.32a_charging_start
- conditions:
sequence:
entity_id: input_datetime.32a_charging_end
mode: single
3 helpers:
And my input_boolean:
HA only updates the templated sensor once every minute but when stopped itâs to the second.
The result:
I posted a solution a year ago (see above). Use a History Stats sensor and the Utility integration.
Iâve used the combination for well over a year and have daily, weekly, monthly, and yearly stats for how long the furnace has been heating and the AC has been cooling.
I believe your system lasts 1 year at most I would like a life timer
Trying it, unfortunately, the sensor is not working every time the entity changes state from âINATTIVAâ to âIN FUNZIONEâ it resets and starts again with zero value.
Sensor
- name: "Contatore Riscaldamento Acceso"
unique_id: "contatore_riscaldamento_acceso"
state: >
{% if is_state("sensor.stato_riscaldamento", "IN FUNZIONE") %}
{{ as_timestamp(now()) - state_attr("input_datetime.contatore_riscaldamento_start", "timestamp") }}
{% else %}
{{ state_attr("input_datetime.contatore_riscaldamento_stop","timestamp") - state_attr("input_datetime.contatore_riscaldamento_start","timestamp") | round(0) }}
{% endif %}
Automation
- id: '1670081715498'
alias: Contatore Riscaldamento Acceso
description: ''
- platform: state
entity_id:
- sensor.stato_riscaldamento
to: IN FUNZIONE
- platform: state
entity_id:
to: INATTIVA
condition: []
- choose:
- conditions:
sequence:
timestamp: '{{ as_timestamp(now()) }}'
entity_id: input_datetime.contatore_riscaldamento_start
- conditions:
sequence:
entity_id: input_datetime.contatore_riscaldamento_stop
mode: single
I started recording long-term statistics for a fan in October 2021. Hereâs its yearly Utility Meter sensor data. You can see it has data for 2022 and 2021.
Ok but as you can see from the graph in January 2022 it restarted from 0
Thatâs simply due to how I chose to graph the data.
Hereâs the cumulative value.
The point is that you claimed it âlasts 1 year at mostâ but it clearly records more than a yearâs worth of data and you can choose how to display it.
Is this correct?
start: "{{ now().replace(hour=0, minute=0, second=0, microsecond=0) }}"
end: "{{ now() }}"
I would like to start at 00:00 and finish at 23:59
How did you configure this daily History Stats sensor?
Thanks, you are very kind!
I think I did everything rightâŚ
One last doubt, graphically after a year, does this Utility Meter Yearly sensor start from scratch or does it show the sum with the previous year?
If you set the sensorâs cycle to yearly it will display the total of the current yearâs data (even though data is recorded for all years and can be graphed as I demonstrated in my previous posts).
According to the documentation, cycle is optional so you can try creating a Utility Meter sensor without the cycle option and, in theory, it should simply display a running total indefinitely. I say âin theoryâ because I have never tried it (because I donât need to display a running total that spans multiple years).
The cycle option is just a way to tell the sensor the time span it should use to calculate its result. It gets the total of every day from the History Stats sensor and uses that to compute a total for day/week/month/year based on whatâs specified for cycle.
With | timestamp_custom("%H:%M:%S", 0)
state: '{{ iif(is_state("input_boolean.32a_charging_on_off","on"), as_timestamp(now())-state_attr("input_datetime.32a_charging_start","timestamp"), state_attr("input_datetime.32a_charging_end","timestamp")-state_attr("input_datetime.32a_charging_start","timestamp")) }}'
attributes:
formatted_time: '{{ states("sensor.32a_charging_timer")|float(0) | timestamp_custom("%H:%M:%S", 0) | regex_replace(find="^[0:]*",replace="") }}'
Thanks, unfortunately I didnât use your method because it gave me some problems as I wrote before
For your requirement (if you have not solved it already), I would create another helper:
input_number.contatore_riscaldamento_accumulated. Then in the automation, change:
- conditions:
sequence:
to:
- conditions:
sequence:
- service: input_number.set_value
data: '{{ states("input_number.contatore_riscaldamento_accumulated") + states("sensor.contatore_riscaldamento_acceso") }}'
entity_id: input_number.contatore_riscaldamento_accumulated
Or something like thatâŚ
