I’ve created a stopwatch with some nice features:
- It allows to Start, Stop and Resume.
- It allows to Reset.
- It allows to save lap values while running.
- It has hundredths of second precission.
- It continues running with restarts of Home Assistant.
- you don’t need to install any other package.
- It can be controlled manually through a Frontend card, or automatically by triggering with
input_boolean.start_stopwatch, input_boolean.reset_stopwatch and input_boolean.lap_stopwatch
v1.0: Initial version.
v1.1: I’ve changed the code to show only hundreds of second when the stopwatch is stopped.
v1.2: trigger simplification.
Note: After creating the stopwatch if it has Unavailable
or Unknown
in its state, press the reset button, to reset it to “00:00:00”.
Here is the code (it can be copied to the package folder):
input_boolean:
start_stopwatch:
# It triggers stopwatch to start/stop(pause)
name: Start/Stop Stopwatch
# initial: off
reset_stopwatch:
# It triggers stopwatch to reset
# initial: off
tictac_stopwatch:
# Pendulum of the stopwatch
# initial: off
lap_stopwatch:
# It triggers stopwatch to show lap time
icon: mdi:camera-outline
# initial: off
template:
- trigger:
# Stopwatch sensor with Start, Stop/Pause, Reset and Lap features. Hundreds of second precission
- platform: state
entity_id: input_boolean.start_stopwatch
- platform: state
entity_id: input_boolean.reset_stopwatch
to: "on"
- platform: state
entity_id: input_boolean.lap_stopwatch
to: "on"
- platform: state
entity_id: input_boolean.tictac_stopwatch
- name: "Stopwatch"
state: >-
{% if is_state('input_boolean.reset_stopwatch','on') %}
{{ '00:00:00' }}
{% elif is_state('input_boolean.start_stopwatch','off') and is_state('input_boolean.lap_stopwatch','off') %}
{% set value = as_timestamp(now()) - state_attr('sensor.stopwatch','initial_time') + state_attr('sensor.stopwatch','elapsed_time') %}
{{ value|float|timestamp_custom("%H:%M:%S", False) + '.' + ((value|float*100)%100)|round(0)|string }}
{% elif is_state_attr('sensor.stopwatch','running','on') %}
{{ value|float|timestamp_custom("%H:%M:%S", False) |string }}
{% else %}
{{ states('sensor.stopwatch') }}
{% endif %}
icon: mdi:timer
attributes:
initial_time: >-
{% if is_state('input_boolean.start_stopwatch', 'on') and is_state_attr('sensor.stopwatch','running','off') %}
{{ as_timestamp(now()) }}
{% else %}
{{ state_attr('sensor.stopwatch','initial_time') }}
{% endif %}
elapsed_time: >-
{{ 0 }}
{{ as_timestamp(now()) - state_attr('sensor.stopwatch','initial_time') + state_attr('sensor.stopwatch','elapsed_time') }}
{% else %}
{{ state_attr('sensor.stopwatch','elapsed_time') }}
{% endif %}
running: >-
{{ states('input_boolean.start_stopwatch') }}
laps: >-
{% elif is_state('input_boolean.lap_stopwatch','on') and is_state_attr('sensor.stopwatch','running','on') %}
{% set data = namespace(laps=state_attr('sensor.stopwatch','laps')) %}
{% set data.laps = (data.laps + [value|float|timestamp_custom("%H:%M:%S", False) + '.' + ((value|float*100)%100)|round(0)|string]) %}
{{ data.laps }}
{% else %}
{{ state_attr('sensor.stopwatch','laps')}}
{% endif %}
- trigger:
# Numeric conversion of input_boolean.tictac_stopwatch to show as a gauge in Frontend
- platform: state
- unique_id: tictac_stopwatch
{% if states('input_boolean.tictac_stopwatch') == 'on' %}
Tic
{% else %}
Tac
{% endif %}
state: >-
{% if is_state('input_boolean.tictac_stopwatch','on') %}
{{ 1 }}
{% else %}
{{ 0 }}
{% endif %}
icon: >-
{% if states('input_boolean.tictac_stopwatch') == 'off' %}
mdi:clock-time-nine
{% else %}
mdi:clock-time-three-outline
{% endif %}
# Start/Stop(Pause) button
- button:
- unique_id: 'start_stop_stopwatch'
icon: >-
{% if states('input_boolean.start_stopwatch') == 'off' %}
mdi:play-circle-outline
{% else %}
mdi:stop-circle-outline
{% endif %}
press:
service: input_boolean.toggle
automation:
- id: tic_tac_stopwatch
alias: "Tic Tac Stopwatch"
description: "It toggles input_boolean.tictac_stopwatch every second"
- platform: time_pattern
seconds: /1
condition:
- condition: state
state: 'on'
- service: input_boolean.toggle
mode: single
- id: reset_stopwatch
alias: "Reset Stopwatch"
description: "It reset input_booleans when input_boolean.reset_stopwatch is set to on"
- platform: state
to: "on"
- service: input_boolean.turn_off
mode: single
- id: lap_stopwatch
alias: "Lap Stopwatch"
description: "It turns off input_boolean.lap_stopwatch when it is turned on"
- platform: state
to: "on"
mode: single
I’ve create two alternative Lovelace cards with animated seconds hand:
type: vertical-stack
cards:
- type: entity
entity: sensor.stopwatch
- type: horizontal-stack
cards:
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: button.start_stop
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: input_boolean.lap_stopwatch
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: input_boolean.reset_stopwatch
cards:
- type: markdown
content: |-
**Laps:**
{% for i in range(state_attr('sensor.stopwatch','laps')|length) %}
{{ (i+1)|string + ': ' + state_attr('sensor.stopwatch','laps')[i]}}
{% endfor %}
- type: gauge
entity: sensor.template_tictac_stopwatch
min: 0
max: 1
needle: true
and this one:
cards:
cards:
- type: entity
- show_name: true
show_icon: true
type: button
tap_action:
action: none
show_state: false
icon_height: 40px
cards:
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
- type: markdown
content: |-
**Laps:**
{% endfor %}
If you use Mushroom integration, (you can install through HACS) it can be used for the card instead of previuos ones. In that case, you won’t need the button section of the stopwatch code, so you can safely remove and create several stopwatches without problems.
The card code with Mushrrom is:
cards:
- type: entity
cards:
primary: |-
{% if is_state('input_boolean.start_stopwatch','off') %}
{% if is_state('sensor.stopwatch','00:00:00') %}
Start
{% else %}
Resume
{% endif %}
{% else %}
Pause/Stop
{% endif %}
secondary: ''
icon: |-
{% else %}
mdi:pause-circle-outline
{% endif %}
{% else %}
{% endif %}
entity: input_boolean.start_stopwatch
icon_color: |
green
{% else %}
orange
{% endif %}
{% else %}
red
{% endif %}
hold_action:
action: none
double_tap_action:
action: none
primary: Lap
secondary: ''
icon_color: |-
grey
{% else %}
blue
{% endif %}
hold_action:
action: none
double_tap_action:
action: none
primary: Reset
secondary: ''
icon: mdi:close-circle-outline
icon_color: |-
grey
{% else %}
red
{% endif %}
{% else %}
red
{% endif %}
hold_action:
action: none
double_tap_action:
action: none
cards:
- type: markdown
content: |-
**Laps:**
{% endfor %}
- type: gauge
min: 0
max: 1
needle: true
I hope anybody finds it useful.
Note: I recommend to remove all the entities created from recorder, as it’s useless to record them in database. To do that, add next lines to recorder
in configuration.yaml
recorder:
exclude:
entity_globs:
- automation.*stopwatch
- input_boolean.*stopwatch
- sensor.*stopwatch
