Hide text for badges in picture-elements card
Hi all,
I’m afraid i might be overlooking something but cannot get it to work the way i would like it.
In my floorplan i added some badges for temperature. I would like to only see the badge and not the text below that.
This is the configuration:
  - entity: sensor.temperatuur_woonkamer
    style:
      font-size: 10px
      left: 32%
      top: 55%
    type: state-badge
I tried adding title: but it does not change a thing.
Hoping someone can help me out.
Geert
Have you found any solution? The picture-elements card doc says:
title
(string)(Optional)
State badge tooltip. Set to null to hide.
But it does not work for me. Tried:
    - type: state-badge
      title: null
      entity: sensor.bathroom_temperature
      style:
        top: 65%
        left: 73%
        transform: 'translate(-50%, -50%) scale(0.5, 0.5)'
        font-size: 17px
But it always says “Bedroom T” (see screenshot).
Please, help to get rid of that text
Same for me. I just let it be. If somebody knows how to solve this that should be great!
Would love an answer too. The ‘title’ attribute is for the tooltip and not the text
Also interested in a solution.
In the meantime, in your exemple, you can define the text the same color as your bed-sheet, it will blend nicely. But for me, on a 3D gradient background, this technique isn’t working.
    - type: state-badge
      style:
        color: '#808080'
        top: 65%
        left: 73%
        font-size: 17px
Regards
Also searching for a way to do this.
try:
color: rgba(0,0,0,0)
the last zero sets opacity to 0 so the other zeroes doesnt really mather (0-255)
doesn’t work on all browsers
https://caniuse.com/#search=rgba
this works for me!
Browser is Google Chrome.
Any update on this?
I’m also trying to get rid of the text beneath a badge on a picture elements card.
The issue with this solution is that the text is still there so the mouse cursor change when the text is hovered and it can be clicked.
Regarding the title attribute, the documentation says it’s for the tooltip (the text shown when the mouse is left over the element a few seconds) so it won’t help.
I managed to crop the element using height and overflow:
type: picture-elements
elements:
  - type: state-badge
    entity: binary_sensor.salon_salle_a_manger_presence
    style:
      top: 28%
      left: 40%
      height: 11%
      overflow: hidden
Great!
I tested your solution and it works for me on:
  • Chrome (Android)
  • Chromium (Raspberry)
YOU WERE SO CLOSE!
I got it because of you, thank you!
style:
  color: transparent
Hmm, when I’m using the HA App on Android the text is shown.
Works for me, Thanks :+1:
My problem with the above solutions is that using transparant text the alignment is still affected by the text, and fixing the height seems to be unstable on what height to set.
I finally settled on setting the font size to 0, this way the alignment of the elements is not affected by the non-visible text.
elements:
  - type: state-badge
    entity: sensor.temperature
    style:
      top: 28%
      left: 40%
      '--ha-label-badge-title-font-size': 0em
Thank you!
this is the best solution
editing in YAML and adding name: ' ' should work
Struggling with the same problem and none of the suggested solutions here work in 2024.12.5.
Tried both title: null and name: ' '
type: state-badge
title: null
style:
  left: 45%
  top: 65%
entity: climate.vp_enhetstermostat
type: state-badge
style:
  left: 45%
  top: 65%
