v2.2.53 build 220108
Странно я проверил у меня работат. Попробуйте переустановить интеграцию может поможет.
Strange, I checked, it works for me. Try reinstalling the integration, it might help.
Hmm, dont think your device is sending the Callsensor with SDK, you can only poll it with ISAPI i think
The alarm you see is probably something else
Ok. I’ll try
But does it work with my doorbell version?
Well, if there is no RING event in de SDK log, then probably your device is not supported? Maybe try updating firmware on it? If still not work, please make an issue on Github
If you see the callsensor changing by ISAPI method, maybe we can add this polling method too in the Addon, for older devices , what command do you do for the ring ?
Thanks. I’ll do that.
I tried to reinstall everything, but it continues with no status (Idle). Door is unlocking over SKD and I’m able to reject calls too
2023-03-18 12:58:59.626 | INFO | doorbell:authenticate:68 - Connected to doorbell: doorbell
2023-03-18 12:58:59.627 | INFO | event:__init__:76 - Setting up event handler: Console stdout
2023-03-18 12:58:59.628 | INFO | mqtt:__init__:91 - Setting up event handler: MQTT
2023-03-18 12:59:25.811 | INFO | doorbell:unlock_door:113 - Door 1 unlocked by SDK
2023-03-18 13:02:04.014 | INFO | doorbell:unlock_door:113 - Door 1 unlocked by SDK
2023-03-18 13:02:43.103 | INFO | mqtt_input:_reject_call_callback:98 - Received reject command for doorbell: doorbell
2023-03-18 13:02:57.419 | INFO | mqtt_input:_reject_call_callback:98 - Received reject command for doorbell: doorbell
2023-03-18 13:03:01.660 | INFO | doorbell:unlock_door:113 - Door 1 unlocked by SDK
The only problem is the Call Status not working, but I’ll open an issue on GitHub as you said.
I can see Ringing status when I open ISAP through Json page 192.168.2.62/ISAPI/VideoIntercom/callStatus?format=json
Ok, maybe we can indeed add an optional mode for polling callstatus based on older devices… But have you tried updating firmware?
Yeah. I checked it on HikConnect and it says doorbell up to date. I’m at v2.2.53 build 220108
I am despairing. I installed the Hikvision add-on with the Asterisk add-on exactly according to the instructions and i use the sipjs-card. How do I recognize with the DS-KV8213 whether a call is parked. For me, the bell works completely normally during the test for some time and then a few hours later there is only a busy character when ringing. I don’t quite understand how to set this up with parked calls and use it with home assistant?
Yeah, sip is not easy to configure, it’s trial and error, anyway , the addon has no relationship with asterisk, so for SIP questions, best to join discord, leave this thread related to addon questions please
Has anyone tried the MQTT addon with DS-KB8113-IM? For me, the addon opens the door every 5 minutes.
That’s not possible, then you have somewhere an automation that’s doing this in HA itself, there is no 5 min timer in this addon … Or maybe an Easter egg
I don’t know why, but in my integration, the Hikvision Doorbell (Beta) add-on opens the door and rings itself.
Show me the log of the addon
Look in the source code, opening door can only be triggered when you put the output relay to “on” , that’s the only way to open a door, so you must be triggering this somewhere in some kind of automation, check your HA logs and addon logs, you have something screwed up
Thank you, so I have an error.
Logs:
2023-03-18 22:36:32.335 | INFO | event:video_intercom_alarm:109 - Video intercom alarm from bramka
2023-03-18 22:36:38.956 | INFO | mqtt:video_intercom_event:199 - Door 1 unlocked by , updating sensor Door 1 relay
2023-03-18 22:36:38.960 | INFO | event:video_intercom_event:98 - Video intercom event from bramka
2023-03-18 22:36:45.824 | INFO | mqtt:video_intercom_alarm:236 - Doorbell ringing, updating sensor
settings: mqtt=MQTT(host=‘core-mosquitto’, username=‘addons’, password=‘eish3’, client_name=None, tls_key=None, tls_certfile=None, tls_ca_cert=None, discovery_prefix=‘homeassistant’, state_prefix=‘hmd’) entity=SensorInfo(component=‘sensor’, device=DeviceInfo(name=‘bramka’, model=‘DS-KB8113-IME1’, manufacturer=‘Hikvision’, sw_version=‘V2.2.51’, hw_version=‘0x0’, identifiers=‘6883457566564949514573776949484950485049485649508282715349525248565355’, connections=None, configuration_url=None), device_class=None, enabled_by_default=None, entity_category=None, expire_after=None, force_update=None, icon=‘mdi:bell’, name=‘Call state’, object_id=‘bramka_call_state’, qos=None, unique_id=‘6883457566564949514573776949484950485049485649508282715349525248565355-call_state’, unit_of_measurement=None) debug=False manual_availability=True
topic_prefix: sensor/bramka/Call-state
config_topic: homeassistant/sensor/bramka/Call-state/config
state_topic: hmd/sensor/bramka/Call-state/state
wrote_configuration: True
2023-03-18 22:36:45.829 | INFO | event:video_intercom_alarm:109 - Video intercom alarm from bramka
2023-03-18 22:36:52.592 | INFO | mqtt:video_intercom_alarm:239 - Call dismissed, updating sensor
I don’t see any error there? The addon on first start just downloads a backlog of past events, just give it a while
Now I have Connection status: keeps ringing. Logs:
2023-03-18 22:51:44.637 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:51:51.194 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:51:57.780 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:52:04.358 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:52:10.933 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:52:17.518 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:52:24.100 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:52:30.716 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:52:37.316 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:52:43.924 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:52:50.528 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:52:57.113 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:53:03.694 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:53:10.316 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:53:16.872 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:53:23.444 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:53:29.963 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:53:36.539 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:53:43.157 | INFO | event:motion_detection:87 - Motion detected from bramka
2023-03-18 22:53:49.724 | INFO | event:motion_detection:87 - Motion detected from bramka
Yes , that’s the motion sensor , that’s normal if there is motion, turn off motion if not needed on your doorbell or just lower the sensitivity
