Previuously, we had tamper/door/motion/call, now we capture ALL possible events and each event is a seperate device trigger now, it also now includes alarm in events
Also much better logging, multiple doorbell support, easier to maintain, it uses images now
Most important, it can also run standalone, for Openhab users or others , thats also the reason we use mqtt now…
No, true, just add it as a second device :+) , you can add as many devices you want, indoor , outdoor, they all now capture events or you can send commands
Definitely my workaround to reject call 5 seconds after notify Scrypted isn’t good as I thought it’d be, but it’s great for notifying me of new calls.
Hey @pergola.fabio looking at Hikvision plugin to Scrypted is difficult to adapt a reject command immediately when I start two-way calling? It could fix almost completely the Doorbells integration with Scypted, after all is possible to give ringing and motions events thankful you plugin and two-way audio is working as well.
You want to modify that script? Yeah you can just setup a new ISAPi command before or after starting two way audio, but this command can only be send to outdoor… Indoor doesn’t accept ISAPi, only SDK…
After the change from baresip to RTSP-APP i noticed that early media is not working for me. I receive the call on linphone or linhome but no early media. (my configuration is exactly the same as the documentation except passwords,sip account etc.) Early media is enabled on apps. What can i do to trace where the problem could be?
You need to use Linphone, not Linhome, linhome doesn’t have the fix yet, will come in 1.2 release…
But if you fire the AGI command, you actually have the call coming in? Try as a test a phone call from a local extension (linphone desktop) to the rtsp user, you should see then video
Just call with a local extension to ‘rtsp’ , that number does an auto answer and shows you an rtsp stream
Ok, tried only with linphone. If i press doorbell or call from local sip linphone to 9000 or 9001 my phone rings but no early media. I have to answer the call and then press the video button in app to view the stream. I noticed that video is choppy or sometimes black screen, like too much delay. While the indoor station (before picking up call from phone) is showing video real time. When i was using your old addon (baresip) and linhome was working fine.
