Hikvision Doorbell / Videointercom integration
Does the hangup work while the call is still ringing? I thought it only worked if you do an answer first?
I’ll test next week and then add it
The unlock id is now an attribute of the relay switch entity, when door opened, the door relay is on for 2 sec and the attribute is then updated… It’s called “control source”
Thank you! I noticed that if you open the lock from the Hikconnect app or using the indoor panel, then this field is empty :frowning:
In the previous version it was like this:
Hikconnect: 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Indoor Panel: 49,48,48,49,48,49,49,48,48,48,49,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Home Assistant: 97,98,99,100,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 (now 9798991, its Ok!)
Yeah, opening door from Hikconnect or indoor, is probably done by SIP, so indeed different value…
And yes, we made string more shorter now , to read it better
But it should not be empty, what do you see in the addon log when opening from indoor/Hikconnect? Do you see the unlock event?
Edit, we are removing the ending 00, so indeed it should be empty when using Hikconnect, that’s correct, but the indoor should work?
yes, I’m sorry! when opening from home, everything is fine. Zeros are cut too! Fine!
Ok , perfect , it’s better this way?
Yes, it’s more convenient, of course! Thank you!
I will now rewrite the telegram bot … and change the id of the all keys (11) in the database)))
But you don’t see an attribute when Hikconnect was used? Or just a blanc string? Maybe it’s better to change to “0” ? Or leave it with “” ?
Oh. Better to change to “0”, of course. If possible, that would be great!
Ok, will change that in next beta
hey @hoicj @VCTGomes
## 3.0.0-beta.19 - 2022-04-15
### Added
- Added hangup button
- Changed unlock record attribute for switch relay to "00" when it was empty when using Isapi/... for open door
I tested it sometimes ago and it does. Hang Up is also excellent to finish the call.
Excellent news! I’ll be waiting for.
Omg! So fast! You’re awesome, Fábio! Thank you!
Hi! What entity can I use to know the ID from who unlock the door?
it is shown as an attribute in the relay switch, …
i dont know how its created, maybe a combination of timestamp, not sure if its static, i dont use it, but its probaly static, since @hoicj is using those values todo something :slight_smile:
in my case, hangUp doest work at all, I always receive error 29 , …
What device do you have? are you using it to send to indoor or outdoor station ?
I’m using a 6113 (B). Definitely I received the Error while hanging up call: (‘Error while calling ISAPI /ISAPI/VideoIntercom/callSignal?format=json’, 23, ‘Device does not support this function.’).
Weird. I used to use it sometime ago when I developed an Scrypted in Python to send the ringing command to Scrypted… I really dunno what happened, but I’ll do more tests after.
When I used my Python Scrypted I was with no indoor panel, but now I have one, however I get data directly from doorbell
maybe the command is different , now i use SDK to send ISAPI commands, maybe its not supported
Hmm… makes sense!
Yes, these IDs are unique! I use them to identify the people who opened the door.
