yeah, not sure where its coming from, not find a way to disable that, just set DBG SDK log to “NONE” , and then its gone , sdk log is not needed, just for troubleshooting
Hello Guys
Thanks Fabio for all your help
I am new here I want to take a hikvision what do you recomment for 1 apartement ?
The histroy is so long that I think it is a good idea to have a small resume
Is there some hikvision that support Google Home or a way to do it ?
I was thinking to DS-KD8003-IME1 what do you think
Thank you for the great work! I am using a Docker image and it is working well. I can confirm that the Home Assistant app is able to display the status of a call and the lock state. Whenever I open the door using a Mifare or the app, the status gets updated accordingly. However, if I open the door using an external ‘Exit’ button located within the perimeter, the doorbell indicates that ‘The door is opened’, but the status in Home Assistant does not change. Is there a bug that needs to be fixed?
Hmm, that possibly another type of event , do you see something in the log when you open the door with the exit button? It’s probably classified as an alarm I/O event… You can also build automations based on this type of event
