Hi all! there is any entity or way to use the front button in the KD8003? I already use video / two way audio frigate card etc… but the most important thing… THE BUTTON I can’t find any way to detect that!.. Thanks a lot!!
Last firmware in the kd8003 . Hikvision beta (last one). Hikvision Addon
If you want to initiate a call, simulating the front button, that’s not possible, calls are based on private sip, has
nothing to do with the sdk for events
Why do you want a button anyway to initiate a call
remotely? I don’t see the point of that? Maybe It can be don’t with the sdk, but I don’t see any advantage to initiate a call remotely if you are not at the door?
And dont use the beta anymore, switch to the stable release
Yeah, that’s your issue, calling failed, means there is no incoming call…!!
Do you have an indoor station? 8003 can’t work without indoor station, or you need to setup PVC/SIP
any text or document to read? I really don’t want an indoor station because I will use a tablet for all the HA dashboard… looks like I will send the doorbell back! thanks Fabio for the amazing job!!!
I have been looking years into tapping into my DS-KH6310-WL. This time with HA it seems very near!
Unfortunately the situation is not very standard. I regained control over my apartment’s unit but the main door station is out of my control.
So far connection seems setup (connection over wifi, main door via lan, different subnets), the only command that seems to work is “Reboot”. Is there any ways for this device to relay to HA: main doorbell, apartment’s doorbell, video (live view), audio, send open command?
According to the logs, sending scene fails and answer call is not supported
In theory it should work, but not on your device, its an older model, that doesnt support ISAPI
if you had an 9310/9510 device, you would have more buttons , like scenes/open door
I think for you its best to use the HikConnect Cloud interation, its on HACS
You will have a call sensor, you can open door
The only thing is the camera , that will never work, the owner of the hikconnect integration is not able to reverse engineer the camera feed from hikconnect app
Wow that’s excellent, just managed to Hik-Connect my indoor station and Hik-Connect to HA.
Never knew that these devices will call home as soon as they get public internet access
hmm, maybe i can do something with that, to send an device trigger alert … so you know it freezed
Can you make an issue on github, so its in the todo list?
Part 2 of enormous thread is already closing into 1000 posts…
From reading large chunks of this thread I’m tempted to go pick up a DS-KV6113-WPE1(C). Question is - are the “direct from China” versions on EBay the same as official? Will they take official firmware?
A few years back I installed Hikvision CCTV kit for a mate, and was warned that Ebay sourced cameras could be a problem with firmware.
The SIP solution here to talk to the doorbell is a huge plus to me. I assume I can adjust my firewall to only allow the SIP comms, but block the Hikvision from otherwise phoning home?
Thanks, I’ll think I’ll take a pop on one and see how it goes. I’m only planning on exposing the SIP side to the internet so will take my luck with the firmware.
