Afterwards you see a new button, but you need to press on it manually on incoming call , then you will see the extra caller_info as attributes on the call sensor…
If it works, you can make an automation for it …
Good afternoon. Tell me if it is possible to check the status of the alarm output, whether the sensor is open or closed, in order to be able to understand whether the door is open or not.
Thank you.
I know how it works, thank you for this opportunity. I just hope that in the future it might be possible to use these brake inputs as sensors with the ability to track whether the circuit is closed now or not. So that you can see whether the door is closed or not. And use them in the alarm map as sensors.
Hi, I’ve got this set up with my DS-kd8003, I’ve got a bunch of buttons/ call, reject etc but I don’t have an open door button, I have relay 1 and 2 but what I really need is an open door button, have I done something wrong? Or am I missing something, any and all help will be appreciated
Hi Fabio, I have paired the kd8003 with the indoor station kh6320 with I’ve connected to a my dvr, the 8003 and 6320 are both powered by POE
When I press the relay buttons the indoor station makes a clicking sound with I’m assuming is the driver to open the the door but the door doesn’t open when using home assistant
No, those COM 1/2 ports on the indoor dont open the door, those are spares ons to hook up alarm hardware…
Your need to press the “relay 1” switch on your 8003 integration, not on your 6320
Hi everyone. I have setup frigate and i am also using frigate card for my outdoor station as of the examples. I can communicate from the internal network but when i am hanging up, i noticed that the mic light on the external station stays on. Is there a solution? I have set up something wrong? Also what is needed to have two way audio from outside my network? I can only hear from the frigate card but they can not hear me. ( i have the DS-KV8413-WME1 unit)
Thank you in advance.
Can explain the command? I am already using go2rtc. Do i need to port forward any ports? And its not speaker that remain on but the mic on the external unit.
