Hikvision Doorbell / Videointercom integration
I do have core mosquitto instyalled
When I cancel MQTT configuration I receive this error
Failed to save add-on configuration, Missing option ‘mqtt’ in root in Hikvision Doorbell (aff2db71_hikvision_doorbell). Got {‘doorbells’: [{‘name’: ‘Cancello14’, ‘ip’: ‘192.168.1.76’, ‘username’: ‘admin’, ‘password’: ’ vvvv’}, {‘name’: ‘Cancello12’, ‘ip’: ‘192.168.1.74’, ‘username’: ‘admin’, ‘password’: ‘vvvvy’}], ‘system’: {‘log_level’: ‘INFO’, ‘sdk_log_level’: ‘NONE’}}
Ok, I uninstalled the addon, reinstalled, without putting mqtt information, now I ahve not the previous error. But The devices are still not there.
The communication with the device I think are fine, but I have no devices/entities created
2024-09-06 17:18:29.531 | INFO     | doorbell:authenticate:79 - Connected to doorbell: Cancello14
2024-09-06 17:18:29.616 | INFO     | doorbell:authenticate:79 - Connected to doorbell: Cancello12
2024-09-06 17:18:29.616 | INFO     | event:__init__:87 - Setting up event handler: Console stdout
2024-09-06 17:18:29.616 | INFO     | mqtt:__init__:114 - Setting up event handler: MQTT
2024-09-06 17:18:43.009 | INFO     | mqtt:update_door_entities:300 - Door 1 unlocked by 494848494849494848484900 , updating sensor and device trigger
2024-09-06 17:18:43.051 | INFO     | mqtt:handle_device_trigger:487 - Invoking device trigger automation{'name': 'Door unlocked', 'type': 'door open', 'subtype': 'door 0', 'payload': {'control_source': '494848494849494848484900'}}
2024-09-06 17:18:43.052 | INFO     | event:video_intercom_event:109 - Video intercom event from Cancello12
Maybe refresh your mqtt integration? Should be there :-), otherwise the addon doesnt start
You can see in your log, that it’s updating the sensor
Had do do a reboot, now all devivces are shown
Hello i am sorry for bad engilsh i have hikvision ds-kb8112im door bell i am add this device in the your addon but i am getting an error
2024-09-16 14:05:46.396 | INFO | doorbell:authenticate:79 - Connected to doorbell: Ev_Domofon
2024-09-16 14:05:46.397 | INFO | event:init:87 - Setting up event handler: Console stdout
2024-09-16 14:05:46.397 | INFO | mqtt:init:114 - Setting up event handler: MQTT
2024-09-16 14:05:46.685 | ERROR | main::101 - Error while listening to events in Ev_Domofon: Not enough resource on the device. Error code:28
why am i getting this error please help me thanks you.
Hi , try rebooting your device? I think it’s stuck
thanks you for reply , yes i try reboot it a fiwe times but i getting same problem Do you have any other suggestions?
hmm, maybe you have other devices connected to it? or maybe a firmware upgrade can help ?
not sure why you device is saying 'not enoygh resources", maybe its busy with something else? some rtsp stream in background?
yes i am add the device frigate with rtsp for two way audio it work without problem only there is problem this addon i need this addon for listen call status
Hi @pergola.fabio i am planning to buy a new hikvision DS-K1T341AM. Would it compatible with your integration for answering calls, viewing camera, unlock the door etc?
Other people have it working, however, the call event is not triggered with K1T devices, so not sure about that one, maybe you can poll it using the Isapi command
Also not sure if you can abort the call, to start two way audio…
Someone else who owns this device should answer your question
hi thanks you for helping i solved the those problem i deleted device in mqtt inteqration and reboot hikvision doorbell addon it work.Now i want to When I press this button, in order to end the incoming call from the device, the call reject or call answer button within the addon should be pressed and the microphone and sound should be activated. can you help me do this?
Screenshot 2024-09-17 085657
Hi, on my GitHub page, I have a complete example with code how todo this;-)
please can you send me github link i do not find it thanks you
thankis you for all help
i am so sorry i try do this but i getting an new error again added script in the configuration.yaml i check configuration getting this error
thanks you
follow this to add scripts:
thanks you
since this is a new install, we only want a door station which operates independently without the indoor video station as the home assistant tablet will be used as the internal video station or the HIK app.
which one would be the most compatible with this addon and home assistant?
any recommendations?
