I have had Hive thermostat\heating integrated on my HA for a while now. As of last night (10pm UK time), it became unavailable.
I have done the usual trouble shooting, Reboot HA, Hive Hub, checked logs etc. I was on on 0.114.4, so as a last ditch effort, I updated to 0.115.6, but still not able to connect.
I removed it from the config and added it back in but still nothing.
I suspect it may be Hive themselves, rather than HA, but I can login fine to the website and App with my credentials.
Same here … all 3 thermostats show unavailable … however my hive app works … so I thought I did something wrong as I was actually working at the configuration for other stuff …
I can`t find nothing wrong … in logs though …
I also have an issue with my ring alarm it wont the component wont install no more …
This is nearly correct…instead of changing “requirements”: [“pyhiveapi==0.2.19.3”], to “requirements”: [“pyhiveapi==0.2.19.4”], which did not work for me, I changed to it “requirements”: [“pyhiveapi==0.2.19.5”], as mentioned below and now works. Excellent
Has anyone fixed this on HA Core? I don’t see hive under custom_components, not under integrations and nothing under HACS. The only reference I have is in my configuration.yaml (username & password) … Do I need to wait for an updated version of HA?
Mine is back working now on core.
Make sure you install HACS via the integration page, then from HACs integration, add Hive.
Keep your config yaml the same.
This should enable you to keep it up to date if they ever change it again.
So now I have to installs HACS?
I don’t have HACS and the last time I installed it I entered into a world of pain… This likley to be fixed in a future release of core?
Amazing. I spent the past few days wondering what I did wrong with my config as all my Hive devices were showing unavailable… I was using the default Hive integration. Installed the Hive Custom Component via HACS, restarted, and all seems to be working fine! No config change required. Thank you!
I don’t know if anyone else is having an issue with this, but with the HACS custom Hive component I can’t successfully login with 2FA enabled. I have to disable it first. I don’t remember having any issues with the core component - after logging in successfully without it, then enabling 2FA, it’s been fine until now. I tried the same with the custom component, but it’s not letting it authenticate. Obviously, it needs somewhere to enter the 2FA code. Do any of you have 2FA enabled? If not, could you enable it and report what happens? This might be worth opening an issue on the git, it could be fixable.
I can tell you what happens with 2FA enabled. You keep getting a text message every few seconds until you turn 2FA off. I have it disabled now. My password is ridiculously long and complex but still I’d like to see an option where the code can be entered.
