Is anyone else seeing this issue when attempting to configure the hive integration with the latest HA version?
Logger: homeassistant.config_entries
Source: components/hive/__init__.py:89
First occurred: 10:39:52 (2 occurrences)
Last logged: 10:43:22
Error setting up entry {my email address} for hive
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 339, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/hive/__init__.py", line 89, in async_setup_entry
devices = await hive.session.startSession(hive_config)
File "/usr/local/lib/python3.9/site-packages/apyhiveapi/session.py", line 493, in startSession
await self.getDevices("No_ID")
File "/usr/local/lib/python3.9/site-packages/apyhiveapi/session.py", line 416, in getDevices
await self.hiveRefreshTokens()
File "/usr/local/lib/python3.9/site-packages/apyhiveapi/session.py", line 303, in hiveRefreshTokens
result = await self.auth.refreshToken(
File "/usr/local/lib/python3.9/site-packages/apyhiveapi/api/hive_auth_async.py", line 544, in refreshToken
result = await self.loop.run_in_executor(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/botocore/client.py", line 391, in _api_call
return self._make_api_call(operation_name, kwargs)
File "/usr/local/lib/python3.9/site-packages/botocore/client.py", line 691, in _make_api_call
request_dict = self._convert_to_request_dict(
File "/usr/local/lib/python3.9/site-packages/botocore/client.py", line 739, in _convert_to_request_dict
request_dict = self._serializer.serialize_to_request(
File "/usr/local/lib/python3.9/site-packages/botocore/validate.py", line 360, in serialize_to_request
raise ParamValidationError(report=report.generate_report())
botocore.exceptions.ParamValidationError: Parameter validation failed:
Invalid type for parameter AuthParameters, value: ({'REFRESH_TOKEN': 'eyJjdHkiOiJKV1QiLCJlbmMiOiJBMjU2R0NNIiwiYWxnIjoiUlNBLU9BRVAifQ.npLdJLtWX5l1PYOqoZCySfqLoWkBh1BVm0eUpz93xtoGEo2TYqpST2MZpRQwBK-hgv9MCkSZGVUV5nq5AfRBSJ0rwCxw-f50f_n0k1Vycs1kqSYwZvVR4PjeJ11ed93XhCoJGffoT-Yq1xJe73SMVH9D6Vcw4PoZcqa9TQt1VKIULoMx04xme-osB8bs3aD6ZTRmSoczDD-qzNhkA5LSnmsB9x9KHdz0ojdloJrzJpoSex1H03UZdh4Xl2Lv01eMpf17pt-IzO_We-yxVh_UcUFiq_SSVHbTOmaUy3EX5LrLasIsIU8JOqz6m5szefWeWvahUi1VzYezLjbaD-w4KQ.v2_FDwvXa81hGkP-.Ql5LhC2KDV-5b__xqHoLxpQO8Mh8NP1PXSKm21q7FLP0svc0kGkAlnhbbrxXz7iOSH0TfoJCDM4fvzZ04DwrO9_BSuEr46nveXwWwbaflNEwZrOugBTt0C-gueCuFytt2ft5ar6beijfoUmgum-8oik15Duej4hwvK577QeILo7rMRDGihy5XRT5T6EjvX1tzbKVxqqM7l9QMV9ALMW9hVlc24C6yHh5dhsQwBmuX--t3VsiwibISqR1A0Tw5aPadZMyujz8odoz4elBpapy0TnJtI8B974mbTWpw9dskaYPPOEXl00qjaoRK3FssZuEfwa-xfIN-pcEXJkmYnDXoepddEfQ7fcNOx8Jgm4Q5Pl3wutOdjIbGIv_hwBKamNswf4vFL_MpUEpMT3XbTy52sw5MhbTH1Rmi81mejkp2kVkd4mxFHe2uTBN15Z1MxvqyLRBpb5tF-mlj1Umau_o28VJO17_24fB9kWLBHCvFpkQEgQ808om3ADdS8_0NXT1uPYW9S5BF7bdSbwYeDz2m5qCBkWMyl04zoypUi9PumMKlHWjD4JnafOGCkZ4ZGjRSFf8z4czkVA-1yyYXB3plOxsWHe6tyEZTHtnjIEwK5KwNGk11W9lWzKWNLStSaiOHPOys-WIS75JELY3m6CzRf1trcYwtO5AAWk9RkbTiJSEDoim2QlluMxan_sYG_LKPh3fCO02CF3c7IJoevflZewdDAueES1V6LCNMyJK0TRAZGznAuUPUojl4BNgr_n7nYLwzE4TQdRr9ic4OfxHRv2W-FUe52kkIfkD8W29VgfvzSDp5AZY173WRV9FMokZWF5bSFfJXHLQbbLqSeIhe5PlskUMr-bl_uDS85StlmWFkl0qhO_sM0aLvk5NPJOtHhCruRjmyWV-ZsgRkyOFAyVdUcVe6kJTxraSEj_3SUd66NktnlylfuXhF0vAtr2cHCQtcPMUr8T3gqxWknybUZhWlQCzRpCpzF9gUGpq8Z3Qohk7gw8hJ0z90La8TjggV_1puHb7m_KaxPplilFpDTkc6AxFYTsGnne95Ooobi1m5R2Tyt1I1QBq-phrwkEoGmlmJ9fll-3bHcr6bNOSRNhZOJ5j3ByhSnHghm6M7V3rg1Y0l3EQDKOIXE1Texq8VDHJ5mHfmasT96JEjiaUTX3SdKRw3ZbbhpPvui2ynz5r8D34gHhLBL7RLM_uACWIdAJrq_OBTMzuswAWs2VDGDTKqEZ7UjD6sp8FSc2Z2oWvW-eToW__iHImLkO-bWOVyO96UzF4QUKFiodeeqW0QSgnUWZ9VuzLIj3wfL67RoVQdtinZAXy7qzEkbaBflJ5N-wrLJWL7y3xv-kQ6NnHMAjmo9dD6Qs4mvMcBIQ8qwd0SgTicHcmAP4Dxohi_bXBRM9gQDwmVANeRZ4XPn_iUl3qozpCViRtPO6087zs6Q.pL989JPWdu-GuLb3Pm0leA'},), type: <class 'tuple'>, valid types: <class 'dict'>
