KoKolaj
(zak)
July 29, 2023, 6:27am
1
Good day.
Please advice on how to connect sensor HLK-LD2411 with D1mini for use in Home assistant.
I tried Yaml for the LD2410, but of course non -functional.
Without ESPHOME support, will it not work?
athua
(Gus)
July 29, 2023, 11:10am
2
Just noticed this thread which may help you:
I have got some new sample modules from HiLink to try and integrate to Home Assistant.
LD2411S was one of them.
[1459]
It’s a 24GHz mmwave motion and presence sensor with Bluetooth capabilities.Could be considered as the successor of the LD2410 .
The first results show that it is more accurate and precise, since it’s using 4 RX and TX Antennas instead of 1.
It can recognise targets in motion (30-600cm) or static (30-350cm) in between the adjustable distance range, exposing motion and presen…
jtauscher
(Jtauscher)
January 22, 2025, 1:00pm
3
you can simply use the OUT Pin (high/low) so its like a usual PIR Sensor. very easy and useful!
