Can confirm that the WX2 works nicely with this custom component.
Have mapped the dps for the second tap/outlet as follows:
{ dps:
{ ‘101’: 0,
‘102’: 0,
‘103’: 10,
‘105’: ‘2’,
‘106’: ‘0’,
‘107’: 8,
‘108’: true,
‘113’: ‘0’,
‘115’: false,
‘117’: false,
‘120’: 0,
‘125’: false,
‘127’: ‘HOL9H005-061-000-000’,
‘150’: 0,
‘151’: 0,
‘152’: 7, // amount of water used last time
‘153’: ‘1’, // 1 when runs water, 0 when stopped, 3 when stopped and time/rain delay active
‘154’: 5, // minutes set for manual run,
‘155’: false, // starts manual countdown when false
‘160’: ‘0’,
‘161’: false,
‘162’: false,
‘166’: false },
cid: ‘B41’ }
Note: for me I had to remove the ‘Beta’ tag from the manifest.json of [darek-margas] custom_component to have the component pass some (new in 2022.3) validity check for it to load.
Thanks for your great effort for making the Holman Tap Timer working on LocalTuya. I have bought the WX2 which has 2 outlet, and set this up successfully based on the dps meaning shared by other user in this thread. After that I bought another WX1 and want to connect to the same WiFi hub, then the problem comes.
Most of the dps of WX1 is actually same as dps of the outlet 1 of WX2, looks like LocalTuya of your fork doesn’t route the message to the correct CID but just rely on the DPS. Below is the scenario
DPS 106 - tap open/closed status
DPS 108 - tap manual countdown on/off (i.e. tap on/off)
both DPS number are same between WX1 and WX2’s 1st outlet.
When I switch on DPS 108 of WX1, both WX1 and WX2 DPS 106 show the tap is opened, and vice versa. However, only the WX1 tap is actually switched on but not WX2, although status of WX2 DPS106 shows this is running. Looks like the status going back to HA UI has not distinguish the CID.
Would you mind looking into this and see if this is possible to have a fix?
Hi everyone… similar issues… I know this thread is a bit old now but…
status of one tap seem to be reflected onto my other two, and vice versa - if I turn one tap on the other two show as on. Did anyone find a fix for this?
Has anyone had an issue where HA won’t turn on/off the taps until you activate them using the Tuya app first? Its like it thinks the devices are unavailable until then.
I have 3 controllers connected to the hub. I have tried adding all three of them in same format but with different device IDs. 2 of 3 shows the state and 1 of 3 stays unavailable. The 2 of 3 which are showing state in HA are somehow changing when I change the state of any 1. Like if I turn on the tap/controller 1 it shows state of 2nd as on aswell although its not ON. I am assuming that the dps ids must be different hence causing issue but I could be wrong. Could you please suggest what can be the issue here or how to check the dps id for each of the 3 controllers ?
Hi @rdg2020 I actually only have one WX1 at the moment so haven’t been able to play around with multiple at the same time. @darecki created this using a dormant (maybe?) PR so I would guess the issue is related to the original PR code.
There’s been a lot of work on another PR #739. Both knifehandz and leeyuentuen have spun off code, it’s not recommended as stable but you might be able to play with them to see if they work any better for you. Leeyuentuen’s has recent activity. I haven’t been able to try them out as I’ve packed my setup up temporarily. If you have a tinker with them, let us know how you go.
Just about to buy a WX2 for the explicit use of filling my pool up, how easy does the manual water ON switch integrate with HA? is it just a simple switch? Want to set up an automation where it goes on for a minute every 10-15, easy enough?
also what is Tuya? Does that need another physical hub purchase or is it just an integration? thanks in advance
I just got this working moments ago, it is just a simple switch.
Tuya is the ODM that Holman uses. Essentially lots of IoT manufacturers just license Tuya software and hardware and build a brand around it. Darek’s build of local tuya (Which can control devices locally rather than going via the cloud) can handle the WX series of Holman devices.
You’ll need Tuya-Cli installing and your devices will need to be setup in the official Tuya app. You’ll also need a cloud account which I think is documented on the Local Tuya Github. It’s not technically required to have the cloud account configured but it’s a pain the neck to get some of the info from the devices if you don’t have it set up.
It’s not super straightforward I know, but it’s the best we have right now.
Unfortunately, I’m not sure any of the localtuya branches will get past the need to do the tuya-cli step. That’s how you get the key to listen to communicate with each device. If you’re happy with cloud integration, you may eventually be able to use the regular tuya integration, which connects to the tuya cloud service to control the local devices. Unfortunately, though, for right now, this integration does not support gateway sub-devices (like with the Holman WX1 and WX2), and this isn’t something they’ve bothered to look at yet.
hmmm so cloud Tuya could work, but the cloud integration doesnt support WX1/2??
im looking at the Orbit BHyve… looks like HACS out of the box and no complaints for performance in terms of battery usage like some others. Only 1 tap and american plug but may have to live with it
