No matter what I do, I cannot get the ZStick to initialize in OZWCP:
cd /opt/open-zwave-control-panel/ && ./ozwcp -p 8890
Could Not Open OZW Log File.
2017-03-26 15:46:25.804 Always, OpenZwave Version 1.4.2434 Starting Up
webserver starting port 8890
post: key=dev data=/dev/ttyACM0 size=12
post: key=fn data=open size=4
post: key=usb data=false size=5
2017-03-26 15:46:34.421 Info, Setting Up Provided Network Key for Secure Communications
2017-03-26 15:46:34.421 Info, mgr, Added driver for controller /dev/ttyACM0
2017-03-26 15:46:34.421 Info, Opening controller /dev/ttyACM0
2017-03-26 15:46:34.421 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2017-03-26 15:46:34.421 Error, ERROR: Cannot open serial port /dev/ttyACM0. Error code 13
2017-03-26 15:46:34.421 Error, ERROR: Failed to open serial port /dev/ttyACM0
2017-03-26 15:46:34.421 Warning, WARNING: Failed to init the controller (attempt 0)
2017-03-26 15:46:39.421 Info, Opening controller /dev/ttyACM0
2017-03-26 15:46:39.421 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2017-03-26 15:46:39.421 Error, ERROR: Cannot open serial port /dev/ttyACM0. Error code 13
2017-03-26 15:46:39.421 Error, ERROR: Failed to open serial port /dev/ttyACM0
2017-03-26 15:46:39.421 Warning, WARNING: Failed to init the controller (attempt 1)
2017-03-26 15:46:44.421 Info, Opening controller /dev/ttyACM0
2017-03-26 15:46:44.421 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2017-03-26 15:46:44.421 Error, ERROR: Cannot open serial port /dev/ttyACM0. Error code 13
2017-03-26 15:46:44.421 Error, ERROR: Failed to open serial port /dev/ttyACM0
2017-03-26 15:46:44.421 Warning, WARNING: Failed to init the controller (attempt 2)
2017-03-26 15:46:49.421 Info, Opening controller /dev/ttyACM0
2017-03-26 15:46:49.421 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2017-03-26 15:46:49.421 Error, ERROR: Cannot open serial port /dev/ttyACM0. Error code 13
2017-03-26 15:46:49.421 Error, ERROR: Failed to open serial port /dev/ttyACM0
2017-03-26 15:46:49.422 Warning, WARNING: Failed to init the controller (attempt 3)
2017-03-26 15:46:54.422 Info, Opening controller /dev/ttyACM0
2017-03-26 15:46:54.422 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2017-03-26 15:46:54.422 Error, ERROR: Cannot open serial port /dev/ttyACM0. Error code 13
2017-03-26 15:46:54.422 Error, ERROR: Failed to open serial port /dev/ttyACM0
2017-03-26 15:46:54.422 Warning, WARNING: Failed to init the controller (attempt 4)
2017-03-26 15:46:54.422 Detail, contrlr, Notification: DriverFailed
2017-03-26 15:46:54.422 Info, Notification: Driver Failed, homeId 00000000
I can only assume it is based on the first line stating that it is because it cannot open the log file, which is there. I have a symlink from the OZWCP directory to the Home Assistant config directory:
ln -s /opt/open-zwave-control-panel/zwcfg_*.xml /opt/homeassistant/.
Two questions on that:
- How dow I remove that symlink
- Or should I also symlink from Home Assistant back to OZWCP directory?
At this point, that is all I am left with. I don’t know what else it could be.
