If I am reading this correctly I need to have mochad running on some other platform? Since I installed Home Assistant OS on my Raspberry Pi I cannot use that to run the mochad?
Use the core mochad integration to connect this server to home assistant and access your devices.
Add-ons are how you run seperate programs and servers on the same hardware as home assistant.
Integrations are how home assistant talks to APIs provided by servers or hubs (running on the same host machine as addons, or as completely seperate stand alone server/hub hardware).
We installed the 3rd party integration and added the mochad information into the configuration.yaml file. We only added one light and one switch for the purpose of testing. The yaml file passed the configuration test successfully. We restarted Home Assistant, saw the pop up saying mochad was starting. However we cannot see any of our added X10 lights and switches on the Home Assistant web page in devices and entities. Mochad does show up.
This is what we see in the mochad integration log file:
Thanks for the reply, As always your expertise and insight is greatly appreciated,
I mis-interpreted what I was seeing in the All Hardware. The directions said I should see something in hardware like ttyAMA0. I did see that but overlooked the fact that there was no physical device associated with the address.
I am now at a complete loss as to how I get HAOS to detect my CM15A.
I have tried both USB 2.0 and USB 3.0 ports. I have tried with two different CM15A modules. I have even tried using different usb wires. I have also tried USB 2.0 and USB 3.0 powered hubs.
Both CM15A modules are readily detected on two different Windows laptops.
My Zooz 800 Z-stick is immediately detected by HAOS in both USB 2.0 and 3.0 ports. All of the USB ports are functional.
Any ideas or suggestions you may have are greatly appreciated.
