My bluetooth dongle stopped working after HAOS recent update.
I removed the configuration of dongle from system and then re-add it (tried also with replugging) and logs are only saying:
Logger: homeassistant.config_entries
Source: components/bluetooth/util.py:78
First occurred: 9:08:22 AM (6 occurrences)
Last logged: 10:48:08 AM
Error setting up entry 04:7F:0E:28:58:FE for bluetooth
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 223, in _async_start
await self.scanner.start() # type: ignore[no-untyped-call]
File "/usr/local/lib/python3.11/site-packages/bleak/__init__.py", line 198, in start
await self._backend.start()
File "/usr/local/lib/python3.11/site-packages/bleak/backends/bluezdbus/scanner.py", line 185, in start
self._stop = await manager.active_scan(
File "/usr/local/lib/python3.11/site-packages/bleak/backends/bluezdbus/manager.py", line 383, in active_scan
self._check_adapter(adapter_path)
File "/usr/local/lib/python3.11/site-packages/bleak/backends/bluezdbus/manager.py", line 209, in _check_adapter
raise BleakError(f"adapter '{adapter_path.split('/')[-1]}' not found")
bleak.exc.BleakError: adapter 'hci0' not found
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 387, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/bluetooth/__init__.py", line 286, in async_setup_entry
await scanner.async_start()
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 210, in async_start
await self._async_start()
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 279, in _async_start
await self._async_reset_adapter()
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 364, in _async_reset_adapter
result = await async_reset_adapter(self.adapter, self.mac_address)
File "/usr/src/homeassistant/homeassistant/components/bluetooth/util.py", line 78, in async_reset_adapter
return await recover_adapter(adapter_id, mac_address)
File "/usr/local/lib/python3.11/site-packages/bluetooth_auto_recovery/recover.py", line 393, in recover_adapter
if adapter and await _power_cycle_adapter(adapter):
File "/usr/local/lib/python3.11/site-packages/bluetooth_auto_recovery/recover.py", line 468, in _power_cycle_adapter
return await _execute_reset(adapter)
File "/usr/local/lib/python3.11/site-packages/bluetooth_auto_recovery/recover.py", line 554, in _execute_reset
power_state_before_reset = await adapter.get_powered()
File "/usr/local/lib/python3.11/site-packages/bluetooth_auto_recovery/recover.py", line 265, in get_powered
response = await self.protocol.send("ReadControllerInformation", self.idx)
File "/usr/local/lib/python3.11/site-packages/bluetooth_auto_recovery/recover.py", line 153, in send
with asyncio_timeout(self.timeout):
TypeError: 'Timeout' object does not support the context manager protocol
I’m using Home Assistant 2023.9.1
