I have the same problem. I downgraded the os to 5.9 to solve the problem.
Looking for a way to change title dynamically according to the current state and effect chosen to run at the moment.
Default behaviour is to display “First LED Hardware instance” of course because this is the default name of Hyperion-NG setup
Any chance I can put some %state_variable% in the title field?
Hi all,
has anyone managed to solve the issue of using Hyperion via home assistant?
I’m seeing the same error:
[hyperiond LEDDEVICE] (ERROR) Device disabled, device ‘ws281x’ signals error: ‘Failed to open. Error message: Failed to create mailbox device’
Wondered if anyone had a solution?
Tony
I updated my OS to version 6, i have still the same problem. Downgrade to 5.10 over shell is not possible anymore
and if there is an update Hyperion will it update automatically in home assistant?
i think yes when you have activate this option for hyperion
Updatet to the latest Hyperion alpha 10, same problem, nothing changed.
I skipped through the whole post and might have missed something, but maybe someone can give me a hint for my setup.
I have some LEDs attached locally to the HAOS host. The issue is that the add-on cannot see the device. As far as I understand the matter I need to add a ws281x
device. Can this be achieved somehow, or would the add-on need to be updated?
Thanks for bearing with me, it is late and my head is spinning by now.
did anyone ever work out how to add ws281x LEDs ? or potentially update to a newer version of hyperion
Hyperion add-on was just updated to 2.0.12 today.
following thread
I’m just lazy to include it every time for any content. I decided to automate the work of hyperion I will share my version of how hyperion can be automated.
has something to do with the add-on priviliges. when I run it with “full_access”: true option the error disappears
Would it be possible to somehow use Home Assistant to set the LED’s to white when playing DRM protected content such as Netflix?
Currently I am running hyperion ng on RPI and am not using HA to automate the LED’s. I am new to HA and might be posting in the incorrect thread?
So to summarize I would like to get HA running to set the LED’s to white via hyperion when running DRM protected content such as Netflix. This would get me ambilight for apps such as Plex and would get me white bias lighting when watching DRM content.
ps. Im using the native Netflix app on my android tv.
If your TV is an android TV you can use the home assistant android TV integration to see what app is running, and if it’s playing or paused. And then create an automation where the trigger is based on Netflix playing, and the action is to set the wled light to white.
Jonathan, can you pm me to talk off topic for a few lines? Thanks. Paul
