I am still waiting to try and get my car added, but being one of the two main contributors to custom brand icons, these will be added by tomorrow
So besides tronity, currently there is no way to receive battery level with fractions? Cause consumption calculation can be quite off for short trips
In my HA was few day’s sensor working then they miss. After newest HA update they came back.
I have still one problem. car battery will charge till 80% and not able to continue. I have tried to push treshold button, but not continue. it could be continued minute or some thing, but after that stopped.
I have a same problem. Where is the file “config.ini” ?
I like so much your card configuration for your car. Is it possible to share your configuration pls?
Can you somehow issue a command and force the charging? Let’s say I want to start charging at night at different times (e.g. when the electricity spot prices are cheapest), without changing the deferred time every time.
I plug the car in, the wallbox charging is disabled, and after couple of minutes the OCPP reports that state is EVSuspended
And if I start charging, nothing happens until I physically unlock the car.
Can this somehow be done via API? Without changing the deffered charging time every time?
Tried the following commands, don’t seem to help?
curl localhost:5000/wakeup/VIN
curl localhost:5000/charge_now/VIN/100
Hello, I also get all the data displayed under PSA Controller. But in the dashboard I do not get them displayed. Where do I hang?
IS there anyway that these values could be set in the Addon config page in future releases?
I’ve tried everything to get 2222 access and it’s just not happening. As a result I can’t gain access to the charging cost settings etc.
Frist of all, a big merci for this great work - everything works for me & my DS7 still one question,
how can I have access to these informations as sensors so that I can embded them in my own dashbord ?
Merci
any takers ?
FROICi,
you need to “pull in” the data into HAssio…
have a look here, its explained how.
regards,
D
I am trying to switch on pre conditioning but it is never activated (on a Citroen C5X). My car info dashboard is working perfectly. Does anyone have a hint how I get pre-conditioning working?
Setup in config:
'rest_command:
c5x_wakeup:
url: "http://192.168.10.39:5000/wakeup/VIN#13"
c5x_change_charge_threshold:
url: "http://192.168.10.39:5000/charge_control?vin=VIN#13&percentage={{ states('input_number.c5x_charge_threshold_slider') | int }}"
method: GET
c5x_activate_preconditioning:
url: "http://192.168.10.39:5000/preconditioning/VIN#13/1"
method: GET
c5x_stop_preconditioning:
url: "http://192.168..xx.xx:5000/preconditioning/VIN#13/0"
method: GET
input_number:
c5x_charge_threshold_slider:
name: Adjust new charging threshold
initial: 100
min: 50
max: 100
step: 1
unit_of_measurement: "%"
input_button:
c5x_apply_charge_threshold_button:
name: Set new charging threshold
icon: mdi:battery-charging
c5x_activate_preconditioning_button:
name: Activate preconditioning
icon: mdi:play
c5x_stop_preconditioning_button:
name: Stop preconditioning
icon: mdi:stop'
and then automation to start pre-conditioning:
'alias: C5X - activate - preconditioning
description: “”
I use Peugeot e208 with PSA controller, its slow but it works, what’s the issue you are referring to?
Hey folks, I couldn’t find a way to update the costs (price per kwh) when using home assistant add-on, could you help me? Everything else is working correctly.
Try to follow the instructions to edit the config files:
Hi all,
Trying to log in for the first time after installing psa, getting this mesage after submit, any thoughts?
Traceback (most recent call last): File “/usr/local/lib/python3.9/dist-packages/psa_car_controller/psa/setup/app_decoder.py”, line 78, in firstLaunchConfig res_dict = res2.json()[“success”] KeyError: ‘success’ {“code”:“495”, “message”: “Invalid or expired client certificate”}
client certificate has expired.
We need to wait for flobz to fix it
So flobz fixed it yesterday, note that you need to follow activity.log when registering a car before doing otp, it happened to me that response was temporary unavailable but that didn’t show in the frontend, so don’t do otp untill login really completed!
Hi.
I am driving a Jeep Avenger, which is also from the PSA/Stellantis group. It is not using uConnect as far as I understand, it uses myconnect.jeep.com.
Any idea if this could be added to the PSA add on?
