Home Assistant Add-on: X10 to MQTT Gateway
This add-on allows for on and off control of X10 via a CM11a (serial) interface using MQTT.
I’m not sure how many of us still have X10 in our smart homes (I don’t), but I wrote this for a friend who has a handful of them still left and was stuck in a venv environment because of the need for the ‘heyu’ executable.
Note that this supports and was tested with the CM11a, which is a RS232 serial device and uses the legacy ‘heyu’ for control under the covers. You can easily connect this using a USB-to-serial cable. It may work with the CM17 “Firecracker”, but that has not been tested as I don’t own one.
It does NOT support direct USB interfaces like the CM15 or others.
If there is interest in CM15 support (which is usually handled by ‘mochad’), I would be willing to package that up as an add-on as well, although I have no way to test as I don’t have a CM15. Let me know if you’re interested and would be willing to help test.
Installation
This is currently in my own repository. Within Home Assistant, select Supervisor -> Add-On Store -> … (upper right) -> Repositories. Add the following URL:
https://github.com/mmotley999/hassos-addons
The “X10 to MQTT Gateway” add-on should appear at the bottom of the Add-On list.
Installation is just like any other Add-On and supports all the typical platforms with pre-built Docker Hub containers using the Home Assistant add-on build script: armhf, armv7, aarch64, amd64, and i386. It was tested on aarch64 (Rpi 4).
Configuration
There are a few items to configure that are outlined in the documentation, specifically the serial port that is connected to the CM11a and MQTT details like hostname, authentication, and topics for commands and status.
If using the Mosquitto add-on, you can leave the host at the default (‘core-mosquitto’). MQTT username and password is technically optional, but the Mosquitto Add-On requires authentication by default.
Operation
Add either switch or light MQTT components in Home Assistant. Only ON and OFF are supported. Sorry, no support for dimming.
Example for house code G7 using the default command and state topics:
switch:
- platform: mqtt
state_topic: "x10/stat/g7"
command_topic: "x10/cmd/g7"
payload_on: "ON"
payload_off: "OFF"
retain: false
The Add-On will also continually monitor for X10 commands that happen outside of Home Assistant (for example, from X10 remote control devices) and update the status of the Home Assistant entity accordingly via the MQTT state topic. NOTE: The state topic is published with the Retain flag so that the entity status is correct when Home Assistant restarts.
Support
Feel free to use this community topic for comments or suggestions, or if you found it useful in your setup!
This is my very first Add-On, and frankly my first real Python script (which is the main process that runs), so be easy on me.
