Home Assistant Add-ons missing from GUI
Same issue here. But I found out, it is because I am running it in docker.
I guess I have to find another hosting solution.
Puh - the answer is : Add-Ons are not supported in container installations according to the setup guide - WTF :frowning:
Is there a technical reason for this? My QNAP is running 24/7 anyway with 16GB of Ram - I don’t want to use a Raspberry - so a VM on the QNap would be a way to get AddOns running for me?
EDIT: After reading a bit into HA-OS - AddOns a seperated in Containers themselves, so that’s why there is not container add-on support? As nested containers are quite new - so is nesting containers on the roadmap or not at all?
I share your disappointment. Like you, I’d prefer not to run Home Assistant on a Raspberry Pi because of the unreliability of SD card storage, opting instead for a container on my QNAP. It makes me wonder why there was even a release for a container-based distribution of Home Assistant. Considering the confusion over missing add-ons, one can only imagine the countless hours people have wasted trying to figure out the issue.
Hi, I too have the problem of missing addons.
my installation is HassOS, some time ago the addons started disappearing now I can’t find anything in the collection anymore.
If I try to re-enter the repo it tells me that it is already installed, but I don’t see anything.
Those already installed continue to work, but the icon has disappeared.
I tried uninstalling Hacs and restarting, but nothing… I can’t get to the bottom of the problem!
Sam issue here on rpi5 with nvme top hat (M2 drive as primary) with HAOS 12. No add-ons (nor ā€œdodatkiā€ as in my polish version) available in settings.
How to enter this ā€œsecretā€ menu ??
I have the same issue. I am using the docker container.
Does anyone have the same issue?
I have same problem in docker container.
Must again install the Home assistant with other way?
HA container (docker) does not have add-ons. Only HA OS and HA Supervised do.
I’m running HA on RPI4 and yesterday after I’ve upgraded to the 2024.4 I’ve not been able to see the Add-Ons and HACS is not loading the UI.
It was just browser cache!
I am having this issue
I just started a VM on my Synology NAS running a supervised HA. (I tried the docker version first only to run into the afore mentioned missing add-ons capability, so now I am running supervised on a VM)
I can install add-ons only by clicking the little ā€œadd-onā€ button found throughout HA documentation, or by manually navigating to the hassio URL
It is missing in the UI. Never was there from the beginning.
Any tips?
Where are you searching ?
settings → add-ons
Yes. It is not there.
Just did a fresh Docker install on Raspberry Pi 3 running 64bit Debian Bookworm. Went looking for the Settings / Addons option to install Samba so I could copy my config backup from the HA VM - and Addons is nowhere to be seen … :frowning:
Docker installs ( HA Container) do not have add-ons
Thanks Francis. The hope had been to have some other processes running on the Raspberry Pi as well, but seeing as how the Container install doesn’t seem to want to do restores either, it seems I’m heading back to HAOS.
{edited}
I just encountered this issue running HAOS on a Ras Pi 5. I opened HA in a new browser window and the Add-Ons are back.
Before:
(see next post for after image due to restrictions)
After:
I don’t understand wy add-ons are not available in the menu on docker installations. Is there an other wy to add eufy add-on in home assistant?
I am just one week over to HA and comming from domoticz. One of the reasons is the many integrations and add-ons. It is a disapointment if it does not work!
Fall here after updating my HA from 2024.2.1 to 2024.12.5… (february to december 2024). It was HA over raspbian with docker, etc.
ADDONS menu dissapear. Not refresh interface, or empty browser cache solve anything.
What solved the problem (Addons, back to menu, etc) has been to update HACS from the left menu. After updating HACS to latest version, addons appeared, etc. I can keep updating the rest of addons after the core update to 2024.12.5 which I can not even see before updating HACS.
Hope it helps.
I am having this issue with a fresh install on RaspberryPi 5.
Below is my system information.
I see the following when I go to the Add-on Store:
I also see the following information in the logs:
2025-07-16 17:35:31.250 INFO (MainThread) [supervisor.store.git] Update add-on /data/addons/git/a0d7b954 repository from https://github.com/hassio-addons/repository
2025-07-16 17:35:31.251 WARNING (MainThread) [supervisor.store.git] No valid repository for https://github.com/music-assistant/home-assistant-addon
2025-07-16 17:35:31.251 WARNING (MainThread) [supervisor.store.git] No valid repository for https://github.com/esphome/home-assistant-addon
2025-07-16 17:35:31.255 INFO (MainThread) [supervisor.store.git] Update add-on /data/addons/git/cebe7a76 repository from https://github.com/sabeechen/hassio-google-drive-backup
2025-07-16 17:35:31.257 INFO (MainThread) [supervisor.store.git] Update add-on /data/addons/git/cb646a50 repository from https://github.com/hacs/addons
2025-07-16 17:35:31.307 INFO (MainThread) [supervisor.store.git] Update add-on /data/addons/core repository from https://github.com/home-assistant/addons
Any advice?
System Information
version core-2025.7.2
installation_type Home Assistant OS
dev false
hassio true
docker true
container_arch aarch64
user root
virtualenv false
python_version 3.13.3
os_name Linux
os_version 6.12.25-haos-raspi
arch aarch64
timezone America/Toronto
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
HACS Data ok
GitHub API Calls Remaining 5000
Installed Version 2.0.5
Stage running
Available Repositories 2106
Downloaded Repositories 1
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 16.0
update_channel stable
supervisor_version supervisor-2025.07.1
agent_version 1.7.2
docker_version 28.3.0
disk_total 234.0 GB
disk_used 5.2 GB
healthy true
supported true
host_connectivity true
supervisor_connectivity true
ntp_synchronized true
virtualization
board rpi5-64
supervisor_api ok
version_api ok
installed_addons Home Assistant Google Drive Backup (0.112.1), Get HACS (1.3.1)
Dashboards
dashboards 2
resources 0
views 0
mode storage
Network Configuration
adapters lo (disabled), end0 (enabled, default, auto), hassio (disabled), docker0 (disabled), vethb2b40cd (disabled), vethbe67b3b (disabled), vethfa17e96 (disabled), veth35a0fbb (disabled), veth98887e5 (disabled), vethf2e3310 (disabled), veth5cf83af (disabled)
ipv4_addresses lo (127.0.0.1/8), end0 (192.168.86.128/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), vethb2b40cd (), vethbe67b3b (), vethfa17e96 (), veth35a0fbb (), veth98887e5 (), vethf2e3310 (), veth5cf83af ()
ipv6_addresses lo (::1/128), end0 (fd44:73a6:b5e2:2e25:aa23:5e9d:4704:d3a2/64, fe80::590c:cd09:98a1:d2da/64), hassio (fe80::f423:80ff:fe52:7c83/64), docker0 (fe80::bcbb:c2ff:fe12:bdfb/64), vethb2b40cd (fe80::2072:a9ff:fe0e:71dc/64), vethbe67b3b (fe80::6897:19ff:feb1:8974/64), vethfa17e96 (fe80::a878:9bff:fe4a:1019/64), veth35a0fbb (fe80::cc79:9fff:fe18:a21e/64), veth98887e5 (fe80::d0e5:65ff:fe92:381f/64), vethf2e3310 (fe80::8023:5bff:febb:1c9d/64), veth5cf83af (fe80::ac4c:7aff:fe44:d385/64)
announce_addresses 192.168.86.128, fd44:73a6:b5e2:2e25:aa23:5e9d:4704:d3a2, fe80::590c:cd09:98a1:d2da
Recorder
oldest_recorder_run July 16, 2025 at 7:47 PM
current_recorder_run July 16, 2025 at 5:23 PM
estimated_db_size 1.49 MiB
database_engine sqlite
database_version 3.48.0
