I talked to the developer about the app log for ConnectIQ other apps.
From WindowsOS>Enduro2>Garmin>Apps
Copy the name of the app to create a .txt file
WindowsOS>Enduro2>Garmin>Apps>LOGS
If you save it, the log will accumulate.
However, the logarithms did not build up.
Is there a problem?
When I rebooted, the log did not accumulate.
But through CIQ_LOG.BAK
I found a meaningful log.
In response to this, there is a problem
Can it be a solution?
Just in case, E1225038.txt
I checked it by putting it in the LOGS folder
Logs have not piled up.
Not presently, hmm probably worth raising an issue for. We are now on the edge of what we can pack into the design without dropping old devices, so can’t promise anything.
We have just released v2.4 of the GarminHomeAssistant application & widget. This will be the last feature release as we think:
We have completed the wish list
We have run out of room without removing support for older devices. (In particular widgets on old watches)
Future updates will be bug fixes only.
The new features mean that you can now display the status of any entity providing you define the text to be shown via the Home Assistant template syntax, hence these menu items are of type template. These new menu items can optionally have a tap action too. The simpler tap and toggle items remainm along with group. All action menu items can have an optional confirm for the request.
Please share you ideas on how these features as a whole can be combined to provide useful functions! We are interested in showing off a range of ideas in our revised documentation at https://github.com/house-of-abbey/GarminHomeAssistant/blob/main/README.md as examples for others to follow. We’ll provide your preferred attribution to any samples we copy.
Thanks for another awesome release!
Just a small idea: would it be possible to set a different battery refresh rate for during charging? I have currently set to only send battery info every 60 minutes as that is good enough. But it would be nice if I could configure it to update every 5 minutes when the watch is charging.
That is an interesting idea, but unfortunately, it is impossible. We cannot detect when charging starts and the way background services work, changing them would be a nightmare anyway.
Hi, is it possible that after today homeassistant update stop working? Only black screen.
Problem was that today first: I have updated ap. Then change configuration to display entity status and it works fine. But ewening I have updated home assistant and then ap stop working.
Only black screen and after minute write that it is possibikity wrong adresse in configuration. And no phone connection.
So this part sounds like the watch does not have an Internet connection, e.g. through your phone. There is a known issue with the Connect IQ app on iPhones, such that when the phone no longer has the Connect IQ app in the foreground the watch loses it ability to connect to Home Assistant. This problem is beyond our control and we can’t fix it.
If that does not sound like your situation then I need to investigate a possible bug. What device are you using? And what’s your JSON configuration? Feel free to private message me with your JSON to avoid tell the whole world ! I can then run some checks, e.g. your JSON in the simulation of your device.
