Home Assistant - can no longer be started
Kann mir jemand helfen, ich bekomme immer diese Fehlermeldung:
feature disabled
2025-03-09 22:27:58.614 ERROR (SyncWorker_3) [homeassistant.util.yaml.loaderl 2025-03-09 22:27:58.614 ERROR (SyncWorker 3)
[homeassistant.util.yaml.loaderl expected ‘’, but found
in “/ config/configuration. yaml”, line 3, column
2025-03-09 22:27:58.615 ERROR (MainThread) [homeassistant.components.homeassistantl 2025-03-09 22:27:58.615 ERROR (MainThread)
[homeassistant. components. homeassistant] The system cannot reload because the configuration is not valid: Error loading
/config/configuration.yaml:expected ', but found
in “/config/configuration. yaml”, line 3, column
Can you add some additional information?
Did you recently make any changes to include editing the configuration.yaml?
Has your system been up and running prior to this error?
Just a heads up, I edited the title of your post. The main language for this forum is English. Check this guide out.
and…Welcome to the Community!!!
Do you have a question? marki901
This is spam…
Had a feeling after they quickly marked my reply as a solution. :pig2:
No it isn’t. However it is not in English.
@marki901 Please read:
