Getting help in languages other than English
As explained in the FAQ this forum is an English language only forum. If you would prefer to converse in your native language rather than using a translator, there are a number of Home Assistant forums for non-English speakers:
French
German
https://forum.heimnetz.de/forums/home-assistant.27/
SmartDome Discord Community
Dutch
Italian
https://forum.hassiohelp.eu/
Polish
Portuguese (Portugal)
Portuguese (Brazil)
Spanish
Danish
Czech
China
There is a Russian Home Assistant channel on Telegram (7K members):
There are also a number of Facebook groups:
Swedish / Sweden (13.1K members)
Danish / Denmark (12.5K members)
France (10.8K members)
Israel (4.4K members)
Japan
Netherlands (6.8K members)
Romania
Taiwan (11.6K members)
Ukraine
The Home Assistant Cookbook - Index
Me sale este error
Node-red werkt niet meer nu upload
Cambio de router , luz led cambio rede wifi
Shelly em Templete
INFO ESPHome 2024.12.2 INFO Reading configuration /config/esphome/living.yaml... ERROR Error while reading config: Invalid YAML syntax: Error reading file /config/esphome/common/base.yaml: [Errno 2] No such file or directory: '/config/esphome/common/base
Schellenberg Integration
Sensor.date
LotusLamp X integration
Insertion planning dans graphique
Sin conexión Node red en Home Assistant
Intégration partiel de mon matériel Smartlife / Tuya dans HA
No hay comunicació con mis dispositivos zigbee
Centrale allarme ip
New forum about HA in tweakers for Quatt Heatpumps integration in HA - Tweakers
Impossible de me connecter en local
Visueller Editor wird für diese Konfiguration nicht unterstützt
Serveur pour home assistant
Support pour instalation home assistant
Connection impossible ha et meme apres reinstallaton
Modification de l'historique des automatisation
Problema copia seguridad en home assistant grenn
Home Assistant Cookbook - Discussion Thread
GoveeLife Heizlüfter Energiesparend, Intelligente Keramik Elektrische Heizung,
This topic can be deleted
Einbindung Speicher von SAX Power mit MODBUS TCP
How to change icon color
No se puede actualizar
Thermostat d'ambiance
Wrong value of entity in history graph
Siemens EQ-700 Counter in Home Connect Integartion fehlt
Home assistent på server
Mi home assistant se desconecto
Home assistant green problem
Removing the zigbee2mqtt plugin
Time input in eshome
Vimar - 14592.0 - Small switch with Zigbee and Bluetooth technology
Batterie Solaranlage - Ladeleistung für Be- und Entladen umrechnen
Kein Backup mehr möglich
myVaillant arotherm Integration in HA, 500 Internal Server Error
Durchschnitt/Formatierung: YAML nicht korrekt
Problemi su HA
Zigbee Leuchte Werte an KNX senden/empfangen
Modbus integration mit packages
Zendure Akku in Homeassistant einpflegen
Automation not work, why? Alexa works
Home Assistant User Groups?
Energy concepts Germany solar storage Ampere.Storage.Pro
Dashbord sur écran tactile Raspberry BI 7"
Errore di rete
Problème d'installation HA sur box yellow (pas de led jaune)
Xiaomi Mi Robot Vacuum 1. Gen - no map (map loading)
Homeassistant virtual machine
Video der Türsprechanlage wird nicht angezeigt
Einrichtung ESPhome secret
Integration SMA inverter don’t work
Customizable energy dashboard
Mitsubishi H.I Smart-M-air
METEO : utilisez l’API de Météo France
[END OF LIFE - ABANDONED - DISMISSED] DSS VoIP Notifier
Integrazione in zha di zgmismart _TZE200_qhlxve78
Regenwahrscheinlichkeit als diagramm
Нужна помощь в написании кода
El dimmer no conecta por la tira led
Bosch heat pump 5800i and Home Assistant
Fantini Cosmi ASPIRVELO AIR ECOCOMFORT 2.0 Smart
Climatizzatore zoning by Madel
Change status for send email
HA speichert meine Automation nicht
Custom Component - Repsol Luz y Gas - Sensor
Getting data from the Solis inverter using API keys
Help please. Can't configure H.A with Stream Deck:(
Night light
How do I implement a lookup table?
Nvr + telecamere wifi
Non fonctionnement HEIMAN HS2WD-E sur appel service
Infos de AQARA smoke JY-GZ-01AQ remonte pas dans Z2M
Home assistant refuse la connection
Current for Bluetti AC200MAX AC-Charger decrease
Home Connect wil niet werken in NL
ESp32 Bh1750 LED
ESP Home & NTC 8x
Vimar View
Nouveau venu dans le monde HA
Configurazione interrotta dopo il 2024.6.0
Kamera Bild auf Ipad beim Klingeln
Récupérer l' heure d'un événement dans une zone de texte
ESP32-A1S Audio Kit Media Player
Fehler beim Update 2024.11.3
Get EDF Tempo information
HomeAssistant URL cannot be accessed via Wireguard/Pihole
Descarga de imagen ISO HASO
History_stats setzt nach Neustart auf nicht nachvollziebare Werte zurück
Czujnik RH01Z humidity_report_interval
Spotify media player ne marche pas
Integrazione Cozylife
Bentel KYO32 Alarm System Integration
Looking for a freelance developer
Home asistan Green
Ou configurez vous vos entités?
这个homeassistant怎么这样难玩。。
LG ESS Inverter custom integration
Unresolved Tag: !input bei jeder Blueprint
Aggiornamento home assistant core su raspberry pi
Pas d'image recu sur Telegram de Frigate
Récepteur infrarouge connecté pour télévision non connecté
Installazione Home Assistant su server Ubuntu
Dispositivo shelly condiviso tra due accout alexa tramite home assistant
Why russian thread was closed by Admin?
Google Calendar Event/Message as a condition in Automation
Camera Dashboard
Problema di configurazione home assistant mac silicon
Offset scheduler
Tasmota with 2 IR read heads on ESP32 UE
Eliminare un entita dal grafico energia
Instalacja
Accès a HA avec Swag sur Apk Android
PV Überschuss mit bitshaker - Easee Wallboxen und Tesla
Integrating the Anker SOLIX Solarbank Max AC into an Existing Fronius System
GUITION 4" 480x480 ESP32-S3-4848S040 Smart Display with LVGL
VW Connect integration updatet nicht
Adminrechte
Problemas de acceso remoto
PROBLEMI smlight SLZB-06M con 2mqtt
TZE204_x9usygq1 not supported
Wibutler HA integration
Ha-ppc-smgw
Problems with Mobus connection:
IKEA Remotes - Control anything
My Zigbee2Mqtt seems broken
Need Daikin Wifi? Use the Open-Source Faikin ESP32 Hardware instead of the official wifi Modules
Ademco/Honeywell/Vista ESPHome custom component with an esp32/esp8266
A welcome to a newcomer that didn't post in English
Croatian weather and air quality components (DHMZ & Eko Karta Zagreb)
Getting Live Electric Consumption from Hydro Quebec Meters
Tado doesn't work
Network card does'nt work propely
Automower husqvarna
How can i do? Login?
Harita Kartı Takip Sistemi
HomeAssistant for russians / для русских
Einschaltverhalten von Hue Lampen ändern
Tuya gold bar slim blumfeldt
Kein MQTT an OpenWB Daten kommen nicht an
Problems with connection Ha on raspberry pi
Wärmemengenzähler, Stromzähler m-bus
Nvme error on nuc in home assistant os
Installazione home assistant 2024.5
Home Assistant interaction with Alexa media player
Automatyzacja
Waiting for home assistant cli to be ready : Pb
Test pour minimot-mini
Bouton poussoir fonctionnant en simple double clic et appui long
Zustandsabhängige Farbe eines Labels
Add no compari
Integrazione Alexa con Home Assistant
Automatizaciones 2024.2.1
Overkiz : "account already configured"
Foto notte e giorno luce
Recarga Pública Iberdrola
Installazione Home Assistant su PC Raspberry Pi
Mosquito que solucion podria tener esto
Permanent state change
Bleuprint heeft een uitroepteken
Iberdrola Distribución (i-DE) - Energy Monitor (Custom Integration Released)
Collegamento diretto S18B20 a Raspberry con HA OS
HA über seperatem Nginx erreichen
The link for the Dutch forum doesn’t work anymore.
Is it possible to change it to: https://tweakers.net/merk/11286/home-assistant/forum/
Community guides operate like a wiki. Anyone can edit the first post. I’ve edited it for you this time.
The old link linked directly to the home assistant topic, your link links to the home automation subforum.
Hi Tom, sorry, didn’t know that. I will do it myself the next time it’s needed.
Could you please add a German Discordserver: SmartDome Community
It’s a server for Smart Home enthusiasts.
Is it Home Assistant specific?
I feel that the pages after redirecting from links in China are quite rough, leaving little desire to share them.
