I can’t get this to work (on Home Hub) as I just get the ‘Not Connected’ message under the ‘HA luvs Nabu Casa’ graphic. The demo works fine though. I have SSL enabled via DuckDNS.
However, I cannot access HA on my internal local network using the DuckDNS address - I have to use the machine name or IP instead. I believe this might have something to do with my router not handling NAT loopback/hairpinning.
Could that also be preventing Cast from working i.e. the Hub is trying to access HA using the ‘external’ address but both devices are on the internal network? Or do I need to add a CORS entry to my config…?
I had the same problem, no loopback available. What I did to make it work :
Use Pihole as DNS server and reroute my hassio url (ex for me : xxxx.synology.me:8123 to my local ip adress) (you can do this with a simple dnsmasq too)
As Google Chromecasts use hard coded Google DNS (8.8.8.8 & 8.8.4.4) , on my router I made 2 static routes 8.8.8.8 --> My local Pihole DNS Server and 8.8.4.4–> My local Pihole DNS Server
This ist just awesome, i bought a nest Hub.
Now i would like to cast my hass.io Installation tonit. Can anyone give me a short Tutorial how to Setup the HTTPS configuration only for local Access ( have a vpn running)?
I read so much threads but could Not find a suitable solution for my problem. Sorry for this noob question, i am a HA beginner.
Thanks in advanve guys.
I’ve not touched base here for a little while, is there the ability to use HA Cast in automations yet? Love the thought/possibilities of HA Cast when it can integrate as a notification target. e.g. motion detected at front door, automatically throw up a lovelace screen on the Nest Display Hub.
I’d love for this to happen as well, and I’ve read somewhere in this thread that this is one of the devs goals. I’d love to be shown the alarm keypad if it is ever triggered.
I’m having trouble finding my Nest Hub as a destination. Logging in to cast.homeassistant.io I can only see one chromecast, and one of my Google home minis. Anyone who has an idea what could be wrong?
I don’t have any problem launching the cast from the website but when I try to add the card to my configuration I get a message cast API unavailable any ideas ?
I can see a Nest Hub having higher SAF (Spousal Acceptance Factor) because of its finish and ergonomics - it will sit nicely on a kitchen bench, bedside table etc with OK sound, camera etc and all the standard Google stuff.
