Hi Community
I am very new with the Home Assistant and Raspberry pi.
I got brand new Raspberry Pi 4B 8Gb It come with Raspbian in it working fine.
Installed home assistant to 8Gb USB flash disk and tried to boot it from USB disk. everything is going normal but at the end it is giving this issue. How can I fix the issue. is it compulsory to use micro SD card?
Thanks for the helps.
You can try entering “login” into the prompt and waiting. It worked for some people: [WARN] Home Assistant CLI is not running! Jump into emergency console… - #8 by Ismoo
