There is no intent
parameter. See here for examples:
https://gist.github.com/mcfrojd/9e6875e1db5c089b1e3ddeb7dba0f304
There is no intent
Iâm using your branch to connect to two Shields using Python ADB. So far the connection is stable and basic commands work. Iâm not at home so I canât do too much testing, but Iâll update if I find problems.
Thanks!
I think a good stress test would be to send the âBACKâ command repeatedly from the services tab (say, 10+ times in rapid succession):
{"entity_id": "media_player.YOUR_ANDROID_TV", "command": "BACK"}
If the media player doesnât become unavailable (check the log for error messages), then the connection is solid!
Done, the only thing I saw in logs was
Data_length 3787 does not match actual number of bytes read: 2872
Data_length 4096 does not match actual number of bytes read: 1424
Not sure how well it worked since Iâm not at home to monitor, but that seemed to be okay.
Jeff thanks for the reply. Can you tell me where i am supposed to actually add these intents? I mean do I create a script and run that or do I need to add a special configuration file somewhere? I tried the call service and pasted that into the relevant entity but it just wouldnât show me anything.
Sorry for the basic question.
deleted: Misplaced release notesâŠ
I think this is in the wrong subject?
addon unifi in adb debugging
I fixed my issue. Thanks for the assistance.
Oops, thanks!
Hi guys, first of all I wanna thank you frenck for this fantastic addon!
Iâm using it on my Toshiba amazon fire tv edition, itâs a bit confusing still because technicly itâs based (like a normal fire tv stick) on android but when use some keys for androidtv not all are working. the thing I really wanna find out is how to get some app working, I can open netflix and other apps with no issues but I canât go straight to the playng part of the video, For example I wanna start the news with my script alarm for the morning but when it turns on the tv doesnât strart to play, if I do it from the fire tv remote app goes straight on to the streaming,what it can be? I tired to get the status of tv while is playing the news but If I copy and paste the whole string âcom.corus.fire.amazon.amazonfirewrapper/com.corus.fire.amazon.amazonfirewrapper.ui.MediaPlayerActivity}â is not giving me the the JSON error but if I call the service doenât work.
Hope somebody of you guys knows a fix, thank you!
Hi, Iâm new to home assistant.
Iâm trying to use this addon to control my nvidia shield but itâs not working
config:
âdevicesâ: [
â192.168.1.25â
âreconnect_timeoutâ: 90,
âlog_levelâ: âinfoâ,
âkeys_pathâ: â/config/androidkeysâ
configuration.yaml
platform: androidtv name: NVIDIA device_class: androidtv host: 192.168.1.25 adb_server_ip: 127.0.0.1
addon log:
Add-on version: 0.4.1
You are running the latest version of this add-on.
System: HassOS 2.12 (armv7 / raspberrypi3)
Home Assistant version: 0.94.2
Supervisor version: 166
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executingâŠ
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] adb.sh: executingâŠ
[cont-init.d] adb.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[10:37:49] INFO: Starting the Android Debug Bridge serverâŠ
[10:37:49] INFO: Connecting to device: 192.168.1.25âŠ
connected to 192.168.1.25:5555
[10:39:20] INFO: Connecting to device: 192.168.1.25âŠ
already connected to 192.168.1.25:5555
[10:40:50] INFO: Connecting to device: 192.168.1.25âŠ
home assistant log:
2019-06-13 08:30:50 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.androidtv
2019-06-13 08:30:50 WARNING (SyncWorker_3) [homeassistant.components.androidtv.media_player] Could not connect to NVIDIA at 192.168.1.25:5555 using ADB server at 127.0.0.1:5037
2019-06-13 08:30:50 WARNING (MainThread) [homeassistant.components.media_player] Platform androidtv not ready yet. Retrying in 60 seconds.
2019-06-13 08:31:51 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.androidtv
2019-06-13 08:31:51 WARNING (SyncWorker_3) [homeassistant.components.androidtv.media_player] Could not connect to NVIDIA at 192.168.1.25:5555 using ADB server at 127.0.0.1:5037
2019-06-13 08:31:51 WARNING (MainThread) [homeassistant.components.media_player] Platform androidtv not ready yet. Retrying in 90 seconds.
2019-06-13 08:33:22 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.androidtv
2019-06-13 08:33:22 WARNING (SyncWorker_13) [homeassistant.components.androidtv.media_player] Could not connect to NVIDIA at 192.168.1.25:5555 using ADB server at 127.0.0.1:5037
2019-06-13 08:33:22 WARNING (MainThread) [homeassistant.components.media_player] Platform androidtv not ready yet. Retrying in 120 seconds.
can you please help me?
This is a general maintenance release.
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
Could you elaborate on this a bit. I have been trying to get this function to work for some time nowâŠ
Command I use:
"entity_id":"media_player.shield_tv",
"command":"plex://IAmAServerID/movie//library/metadata/movieID"
If this is the url I get when playing the video through a web browser:
https://app.plex.tv/desktop#!/server/abcdefghijklmnopqrstuvwxyz0123456789ABCD/details?key=%2Flibrary%2Fmetadata%2F3742
Is the abcdefghijklmnopqrstuvwxyz0123456789ABCD the server and F3742 the movieID?
so the call would look like:
"command":"plex://abcdefghijklmnopqrstuvwxyz0123456789ABCD/movie//library/metadata/F3742"
Or is that incorrect?
I also tried sending with âintentâ instead of command, but it seems that âintentâ is no longer supported?
You are right for the server.
the metadata is only the 4 figures after the F.
But unfortunately, it seems to not be working anymore.
below is what i was using but now plex is only throwing a crash report
"entity_id": "media_player.shield",
"command": "am start -a android.intent.action.VIEW -d plex://abcdefghijklmnopqrstuvwxyz0123456789ABCD/movie//library/metadata/3742"
Do you think this is a Plex issue or an ADB issue?
Hi could someone please help
Iâve been using the add on for months without issue yet since I rebooted this evening Iâm seeing the following error message
2019-06-25 22:37:01 ERROR (SyncWorker_14) [root] ADB device is unavailable; encountered an error when searching for device.
2019-06-25 22:37:01 WARNING (SyncWorker_14) [homeassistant.components.androidtv.media_player] Could not connect to NVidia Shield at 192.168.1.184:5555 using ADB server at 127.0.0.1:5037
Iâm running the latest 5.0 update and it states is connected
How do I get all my apps on android TV ?(miobox 3)
Hi i have a issue with this , the addon connect to my tvbox ,and say connected on log but the media player component on HA , say unavailible , after many reboots when TV Is on , and restarting also ha and the addon , i can see the media player component, but as soon reboot the HA the media player back to unavailible
I donât know why my device looped as image, after restar the hassio addon, but when is looping , i donât see any error or issue on logs
